Dead 4.7 Dakota #303646
04/30/09 11:10 AM
04/30/09 11:10 AM
Ridgeland, WI, 54763
Curt57 Offline OP
Curt57  Offline OP
I have a 2000 Dakota with a broken piston. What are the chances of just replacing that piston? Reman engines are around $3000. Or could I possibly change it over to a 318 magnum. I know it would mean alot of change over parts. But is the trans the same? THANKS, Curt
Re: Dead 4.7 Dakota [Re: Curt57] #303647
04/30/09 12:28 PM
04/30/09 12:28 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
What are the chances of finding a good used engine at a salvage yard? That's the first place I would go if piston replacement isn't an option.
Re: Dead 4.7 Dakota [Re: Curt57] #303648
04/30/09 12:42 PM
04/30/09 12:42 PM
Seattle WA
RichV Offline
RichV  Offline
Seattle WA
I really am glad that I have run my low compression 4.7 on midgrade or premium fuel for all these years now. The 2000 model year 4.7 don't have knock sensors and will ping when hot on low octane fuel. You may be able to find used pistons and rods from someone who has tweaked ther engine, because the hypereutectic pistons with the high mounted compression rings are relatively fragile. So they swap them out for forged rods an pistons.
Re: Dead 4.7 Dakota [Re: Curt57] #303649
04/30/09 12:47 PM
04/30/09 12:47 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Are you sure the cylinder is junk? I'd try to fix it if not. I only use the cheapest gas I can find on mine, and never hear a peep out of it. 130k so far.
Re: Dead 4.7 Dakota [Re: buildanother] #303650
04/30/09 01:15 PM
04/30/09 01:15 PM
Marion,Indiana
Seth_Jones Offline
Seth_Jones  Offline
Marion,Indiana
I have a 2000 Dakota 4.7 with 190K miles on it and have run nothing but 87 octane.I have never heard it spark knock.I think I would just go buy the lowest mileage used engine and swap them.They are pretty darned good engines.
Re: Dead 4.7 Dakota [Re: Seth_Jones] #303651
04/30/09 04:26 PM
04/30/09 04:26 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Use a reputable salvage yard used engine.
Keep old mopars alive.
Re: Dead 4.7 Dakota [Re: 2boltmain] #303652
04/30/09 04:49 PM
04/30/09 04:49 PM
Curt57 Offline OP
Curt57  Offline OP
THANKS, Curt
Re: Dead 4.7 Dakota [Re: Curt57] #303653
04/30/09 09:03 PM
04/30/09 09:03 PM
S.E.Ohio
Magnumguy Offline
Magnumguy  Offline
S.E.Ohio
Too bad you don't live around here, I know a good mostly-Mopar yard near me, you can count on his stuff being good, or he makes it good.
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: Dead 4.7 Dakota [Re: Magnumguy] #303654
04/30/09 10:04 PM
04/30/09 10:04 PM
70duster340 Offline
70duster340  Offline
Don't mean to hijack this post, but where is this mostly Mopar salvage yard? I live in Ohio (NE Ohio), but would drive the distance for parts if I knew where it was!
