68 Dodge pickup VIN and SO# locations #3036391
04/23/22 04:46 PM
04/23/22 04:46 PM
Minnesota
Hemi_Joel Offline OP
Minnesota
Hi, on a 68 Dodge pickup, does anyone know if the VIN and/or SO# is stamped anywhere on the body? Besides the tag on the drivers side door lock pillar tag and the VIN n the frame?
Thanks,
Joel
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: 68 Dodge pickup VIN and SO# locations [Re: Hemi_Joel] #3036456
04/23/22 09:09 PM
04/23/22 09:09 PM
okla.
sam64 Offline
sam64  Offline
okla.
Not sure on body but right front frame has it stamped.
Re: 68 Dodge pickup VIN and SO# locations [Re: sam64] #3036517
04/24/22 08:28 AM
04/24/22 08:28 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
Re: 68 Dodge pickup VIN and SO# locations [Re: Moparite] #3036527
04/24/22 09:25 AM
04/24/22 09:25 AM
Des Moines IA
Soopernaut Offline
Soopernaut  Offline
Des Moines IA
The SO numbers are not stamped on the body. The data plate and frame are the only places you will find the numbers on the truck. Some trucks have a tag attached to the cowl and another on the bed. These each have a number that corresponds to numbers on the build sheet, but aren't really useful if you don't have the build sheet. If you have the build sheet the tag numbers don't really matter either, other than to see if they match.
1970 Dodge d100/eventually going on a 77 D100 frame
