Re: Lets talk Heads.....
[Re: fast68plymouth]
#3040140
05/05/22 10:43 PM
05/05/22 10:43 PM
Posts: 3,084 Michigan
A727Tflite
The TF270 vs EZ295 vs EZ325, on a 800hp type 540+ short block would be a fun dyno shoot out. Then finish it off with some 440-1 cnc345’s. Where do a set of maxed out B-1 heads fit in this line up? Imo, “Maxed out” B-1’s wouldn’t even be part of the conversation unless one was shooting for, and building something capable of over 900hp. Was wondering because several years ago a 451 using Modern’s B1 heads ran 9 teens - was wondering if these other heads were a power loss compared to the B1’s.. Looks like they are.
[Re: AndyF]
#3040160
05/06/22 12:01 AM
05/06/22 12:01 AM
Posts: 2,117 Cleveland Ohio
10secGTX
Cleveland Ohio
The launch looks very square for no anti roll bar. You must have the chassis dialed in right.
The engine should live at 7500 rpm but I think you're well past the power peak so that might be slowing you down a tad. 3.90 gears would probably drop you back into the 7000 range which is right around the peak. Changing to a taller tire might be less work, just depends if there is one available that fits your car. I have very limited tire selection at this time so the gear change is easier, I have a Super Victor with a 1150 Ultra Dominator
[Re: 10secGTX]
#3047993
06/05/22 10:12 AM
06/05/22 10:12 AM
Posts: 10 ohio
hangemhigh
ohio
Great read, and info. guys....I searched out this post to query the experts here on my own situation. Currently running an iron 286 max wedge head, lightly rubbed on, and cast mw crossram, which I'm not changing. It's a period correct thing. The EZ-1 not only saves weight, but exhaust port location also allows me to keep the stainless headers that I prefer to only purchase once. I'm not rich, but am also not averse to buying the 325 EZ-1's, rockers, and/or investing in port/machine work to pick up some et. Current package is 511, @3700#, best 10.30@131, 1.31 60 on a 9" tire. Appreciate any input. Thanks.
[Re: hangemhigh]
#3048201
06/06/22 08:31 AM
06/06/22 08:31 AM
Posts: 4,058 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
Great read, and info. guys....I searched out this post to query the experts here on my own situation. Currently running an iron 286 max wedge head, lightly rubbed on, and cast mw crossram, which I'm not changing. It's a period correct thing. The EZ-1 not only saves weight, but exhaust port location also allows me to keep the stainless headers that I prefer to only purchase once. I'm not rich, but am also not averse to buying the 325 EZ-1's, rockers, and/or investing in port/machine work to pick up some et. Current package is 511, @3700#, best 10.30@131, 1.31 60 on a 9" tire. Appreciate any input. Thanks. IMO your stuff runs pretty good for the parts you are using. I'd be willing to bet if you swapped on the new INDY crossram that would gain you MORE increase than swapping heads!!! Cheaper too.
[Re: jwb123]
#3048273
06/06/22 12:45 PM
06/06/22 12:45 PM
Posts: 19,373 Las Vegas
Al_Alguire
Las Vegas
[spoiler][/spoiler]Why flow numbers mean as much as dyno numbers. Most high end head porters care way more about cross section and port CC than a flow number. Its usually the customers pushing for that number because they read it on the interwebs.
A dyno is just a tool. I now guys that will wear there junk out on the dyno and just toss it in the car and expect a miracle to occur. Been pretty rare that a great tune on the dyno was what the car wanted on the track.
As for Hardcores engine on an honest dyno I would say its a 700ish HP piece. But it was also not in the car long enough to be fully sorted out. But MPH tells the tale whether ET does or not. But that same engine on other dynos could make 800, its a tool not a be all end all.
[Re: Al_Alguire]
#3048540
06/07/22 09:21 AM
06/07/22 09:21 AM
HardcoreB
Shelby Twp. Mi
As for Hardcores engine on an honest dyno I would say its a 700ish HP piece. But it was also not in the car long enough to be fully sorted out. But MPH tells the tale whether ET does or not. But that same engine on other dynos could make 800, its a tool not a be all end all. Yes, it'd 'showed' low-mid 7xx. That was my point, like most other combo's, they are unsorted as far as adjusting in the car. On the dyno, I'm pretty sure it'd dyno better than it showed. Which is for the few in here that wonder if it has been/can be done. To better show, with an example, of what it took to get better numbers out of similar 'core' parts. Among other places, I have learned from here what goes with what. And it's caused many delays in WHEN I finally decided to 'commission' what i wanted mostly because, I didn't want something 'common'. But there are probably many here that wouldn't stack the same parts together.
[Re: HardcoreB]
#3048605
06/07/22 01:09 PM
06/07/22 01:09 PM
Al_Alguire
Las Vegas
Dynos are simply a tool, some tools are better than others. No different than a flow bench, desk top dyno or whatever. One can tell when a car is an over achiever vs and under achiever. But certain things are pretty concrete. Like MPH and Weight, they dont lie as a true measure of HP. People chasing dyno numbers and flow numbers rarely have the fortitude to fully sort out their combos and are content to quote meaningless HP and flow numbers....
