Fazio with Hoven at ATCO... #3035738
04/21/22 03:14 PM
04/21/22 03:14 PM
Fulton County, PA
CMcAllister Offline OP
Mr. Helpful
Mr. Helpful
Fulton County, PA
Re: Fazio with Hoven at ATCO... [Re: CMcAllister] #3035749
04/21/22 04:01 PM
04/21/22 04:01 PM
Portage,michigan
B3422W5 Online content
B3422W5  Online Content
Portage,michigan
Hard leaving car off the foot..lol
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Fazio with Hoven at ATCO... [Re: CMcAllister] #3035770
04/21/22 05:36 PM
04/21/22 05:36 PM
I'm surprised that car would be legal for NHRA stock, NHRA didn't allowed aftermarket intakes in stock or any modified intakes when I race back in the 1970 to 2000s shruggy
What say those that know the current rules on intakes allowed in NHRA "stock" now? help
I use to help two NHRA SS class racers that raced a original 1965 A990 Plymouth Hemi Belvedere SS/BA and a clone 1968 Hemi Dart stick shift SS/A in the late 1980 and 1990s.
They were allowed to race with aftermarket manifolds that were approved by NHRA to use in the SS classes back then shruggy
Both of them set their class records for a short time in the early 1990s boogie bow
Re: Fazio with Hoven at ATCO... [Re: CMcAllister] #3035790
04/21/22 06:26 PM
04/21/22 06:26 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
We’ll see if they got the car repaired and are back for another attempt at it this weekend.
Re: Fazio with Hoven at ATCO... [Re: Cab_Burge] #3035798
04/21/22 06:48 PM
04/21/22 06:48 PM
Fulton County, PA
Mr. Helpful
Mr. Helpful
Fulton County, PA
Classification guide shows a dual carb race Hemi deal legal for Stock in a factory SS car. Rated at 450HP. Would have to use OE intake and valve lift, no funny business with the heads, among other things. Not sure how but it's there. I'll have to ask folks who do know.
The single four NASCAR combo, rated at 428, has been there. The Carp car used to run that I think.
Different parts allowed on those cars with different engines - steel vs. aluminum, hood scoops, different wheelbases, etc.
Re: Fazio with Hoven at ATCO... [Re: fast68plymouth] #3035800
04/21/22 06:52 PM
04/21/22 06:52 PM
Fulton County, PA
Mr. Helpful
Mr. Helpful
Fulton County, PA
Blew the tires off first run. Put it on the bumper second. Yes, these cars are adjustable.
Re: Fazio with Hoven at ATCO... [Re: CMcAllister] #3035892
04/22/22 06:16 AM
04/22/22 06:16 AM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Wheelie bars up on the bumper. Not sure if that's the way to go to set a NHRA record.
Re: Fazio with Hoven at ATCO... [Re: Sammy] #3035974
04/22/22 11:43 AM
04/22/22 11:43 AM
Fulton County, PA
Mr. Helpful
Mr. Helpful
Fulton County, PA
Shouldn't be hard on the bars, or on them at all, when it's right. Not supposed to go that high. Went over center on the chassis when it blew the tires off first run. Hooked and then some on the second.
Re: Fazio with Hoven at ATCO... [Re: CMcAllister] #3036011
04/22/22 12:50 PM
04/22/22 12:50 PM
So. Burlington, Vt.
So. Burlington, Vt.
The big wheelie was last weekend. Resulted in some front end damage....... hopefully they got it all fixed up.
One of my friends is down there...... said there is a little head wind this morning.
Re: Fazio with Hoven at ATCO... [Re: fast68plymouth] #3036297
04/23/22 12:47 PM
04/23/22 12:47 PM
So. Burlington, Vt.
So. Burlington, Vt.
I didn’t see Hoven on the q sheet from yesterday.
After thinking about it for a bit....... I doubt they would go for the record at a “Divisional” race, since it would likely result in a HP hit from the AHFS.
Last week was an “open”, where the AHFS doesn’t apply.
Re: Fazio with Hoven at ATCO... [Re: fast68plymouth] #3036387
04/23/22 04:28 PM
04/23/22 04:28 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
425 426 DP 12.5 2-4 Holl R-3116,4235,4236 (2) 2536768 1.56 I M 167.7 14
1.52 E M
Carb sizes - 1686x1686/1375x1437
14 - Alt intake manifold P4532265
Floyd Lippencott IV
Re: Fazio with Hoven at ATCO... [Re: mr_340] #3036395
04/23/22 04:52 PM
04/23/22 04:52 PM
So. Burlington, Vt.
So. Burlington, Vt.
Apparently Todd injured his back when the car came down....... so he’s in recovery mode for a little while.
