Convertor recommendations 46RH w/lockup
#3034179
04/16/22 05:45 PM
04/16/22 05:45 PM
Posts: 1,515 AZ
Mike P
AZ
Figured I'd ask here first. I just got my 354 Hemi built and running. I stuffed a reasonably healthy cam in it and am planning running a 46RH w/lockup convertor behind it with a 4.30 rear gear. It will likely be going in a car with a weight of around 3500 pounds. It will mostly be used for cruising with occasional highway trips. I'm thinking it would probably like a 15-1700 stall convertor. Is there such a convertor out there and who would be a good source. Any recommendations would be appreciated.
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold 1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold 1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears) under construction
Re: Convertor recommendations 46RH w/lockup
[Re: Mike P]
#3034204
04/16/22 06:46 PM
04/16/22 06:46 PM
Posts: 2,871 Pattison Texas
CSK
Pattison Texas
PATC, Transmission center is who built mine, works great
[Re: BDW]
#3036279
04/23/22 11:44 AM
04/23/22 11:44 AM
Posts: 19,591 north of coder
moparx
if it has a lockup clutch, i would go for a 2500-3000 stall speed. my opinion, 17-1800 is too low. just my opinion. your mileage will vary.
[Re: moparx]
#3036284
04/23/22 12:09 PM
04/23/22 12:09 PM
Posts: 3,092 Michigan
A727Tflite
if it has a lockup clutch, i would go for a 2500-3000 stall speed. my opinion, 17-1800 is too low. just my opinion. your mileage will vary. Agreed. Using a healthy cam probably means killing some of the low end torque. Even with a 4:30 gear, a tad more stall will help the driveability. Once it is in lockup the stall is not an issue.
