Page 2 of 4 1 2 3 4
Re: Lets talk Heads..... [Re: Dragula] #3036135
04/22/22 08:48 PM
04/22/22 08:48 PM
AndyF Offline
AndyF  Offline
Valvetrain had good parts in it but nothing really exotic. The heads and valves were box stock. We changed the valve springs and used T&D rocker arms. Here is one of the articles: https://www.motortrend.com/how-to/dyno-tested-vacuum-pump-help-engine-make-power/
Re: Lets talk Heads..... [Re: gregsdart] #3036165
04/22/22 10:35 PM
04/22/22 10:35 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
Down the road goals, I guess, I am not sure as I have a lot on my plate, and next year my world changes drastically as I relocate south. So 5.90 is just an incremental goal I have wanted to hit, but would love to win another points season championship.The car works well, so, if I keep finding ways to lighten it, or better parts for the engine, we might hit my goal this year. There is about 50lbs of weight I know if I work at it, I can remove. Maybe more intake porting....And we have brand new slicks...
I will build another 543 I think this fall as a backup....For the money, I think that is one of the best combo's a person can build....After that, I have to finish up my Cuda and then collect parts for the Barracuda and bu then, it will be time to move south.
Re: Lets talk Heads..... [Re: AndyF] #3036172
04/22/22 11:16 PM
04/22/22 11:16 PM
Apollo, PA.
B1MAXX Online content
B1MAXX  Online Content
Apollo, PA.
Originally Posted by AndyF
My 470 made 750 hp with the TF270 head and pump gas compression but it was a really serious build. I had to test multiple cams before finding one that worked just right. That engine also had a Wilson ported intake, Jesel belt drive, external oil pump, etc. It was more expensive than a typical bracket race engine. I probably had about $20,000 in that engine. I think it could be duplicated for less but a person would need to make all the correct choices.
The easiest way to make more power is to add compression. The 10.7 compression is going to really box you in. You can make big power with that compression but you get forced into a narrow power range and a very specific camshaft.
What did it run et wise ? just curious about these heads.
I built a 12 to 1 511 rb with used SR's and a flat tappet cam for 4500$ its been 9.60's
Re: Lets talk Heads..... [Re: B1MAXX] #3036178
04/22/22 11:43 PM
04/22/22 11:43 PM
AndyF Offline
AndyF  Offline
That engine never went in a car. Sold the top end to one guy, the short block to someone else and the oil system got parted out to a bunch of different guys.
Re: Lets talk Heads..... [Re: AndyF] #3036182
04/23/22 12:15 AM
04/23/22 12:15 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
If I was building a wedge I would look up Andy F's builds and copy one. He knows how to milk a wedge.
2011 Drag Pak Challenger
Re: Lets talk Heads..... [Re: Dragula] #3036187
04/23/22 01:05 AM
04/23/22 01:05 AM
gregsdart Offline
gregsdart  Offline
So reliability is a must, to win a championship. Low maintenance, long life motor.
Re: Lets talk Heads..... [Re: AndyF] #3036218
04/23/22 08:51 AM
04/23/22 08:51 AM
Apollo, PA.
Apollo, PA.
Thanks, I am curious if this would be new territory for that head. I my book 5.90's is pretty fast. Kinda like the 10.0 to 9.9, but the next step.
Re: Lets talk Heads..... [Re: AndyF] #3036223
04/23/22 09:13 AM
04/23/22 09:13 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Exactly. So you will never know how it ran. Dyno = bullsh!t if it don't run a number
Re: Lets talk Heads..... [Re: FastmOp] #3036225
04/23/22 09:20 AM
04/23/22 09:20 AM
Apollo, PA.
Apollo, PA.
Yeah, now you have me thinking that with all the variables in these dynos, was it actually 750hp work
Re: Lets talk Heads..... [Re: B1MAXX] #3036256
04/23/22 10:25 AM
04/23/22 10:25 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
“In theory”, a 5.90 in the 1/8 is about a 9.25 in the 1/4.
At 2950lbs the Moroso slider shows 705hp, uncorrected....... as it sits on the starting line.
So, figure you’ll need somewhere around 6-10% more STP corrected dyno HP to end up with that figure in typical upstate NY summer air.
775hp seems like a big ask for a bread and butter bracket race pump gas 511.
Re: Lets talk Heads..... [Re: fast68plymouth] #3036264
04/23/22 10:39 AM
04/23/22 10:39 AM
Dragula Offline OP
Dragula  Offline OP
Yeah, typically this combo runs 6.20's......We have been 6.14 on pump gas with an almost identical combo....But as I mentioned, we have made a few small changes to it. That combo had a basic 295 head with 2.19 valves, and this will have a 325 with 2.25 valves, and this new cam is bigger too, and the free'r flowing headers this time, fresh slicks...and maybe 50lbs less weight....We are trying to hit it without sacrificing reliability. Last two seasons, we lashed the valves once, and we were good for the season. Good valve train = happy engine with good tuning.
The other thing I can do, is go higher launch and shift rpm....
Re: Lets talk Heads..... [Re: Dragula] #3036273
04/23/22 11:10 AM
04/23/22 11:10 AM
So. Burlington, Vt.
So. Burlington, Vt.
Using the same factor that shows a 5.90 in the 1/8 as a 9.25 in the 1/4, shows a 6.14 in the 1/8 to be a 9.63 in the 1/4.
On the Moroso slider, a 9.25@2950lbs shows it would require 85hp more than a 9.63@3000lbs.
The Wallace 1/8 mile calculator shows 69hp more to go from 6.14@3000lbs to 5.90@2950.
Nonetheless, sounds like you have a plan...... which we’ll look forward to you sharing the results from.
Re: Lets talk Heads..... [Re: fast68plymouth] #3036275
04/23/22 11:10 AM
04/23/22 11:10 AM
AndyF Offline
AndyF  Offline
I agree, 775 isn't going to happen from a bracket race pump gas 511. Those typically make right at 700 on the dyno. Everything has to be just right to get the extra 10% which means you have to be willing to spend a bunch more money on parts and dyno time. Most guys just make a few pulls on the dyno to verify the build and then go racing.
Re: Lets talk Heads..... [Re: rickseeman] #3036283
04/23/22 12:04 PM
04/23/22 12:04 PM
gregsdart Offline
gregsdart  Offline
I just caught rhe part about pumpgas. Seriously, you need cubes and airflow for that . What parts do you have to throw at a 4.5 bore aluminum block? Maybe $ 6600 to get one in hand (BME) , ready to assemble, and750 to 800 pumpgas hp will be a whole lot easier to do. The block should turn out to be a one time investment, and 100 pounds off the nose is huge . How much would it cost to replace two broken stockblocks? A lot more than just blocks and machine work.
Re: Lets talk Heads..... [Re: gregsdart] #3036305
04/23/22 01:05 PM
04/23/22 01:05 PM
Apollo, PA.
Apollo, PA.
So it sounds like the 325 is the "correct" choice
Re: Lets talk Heads..... [Re: gregsdart] #3036334
04/23/22 02:30 PM
04/23/22 02:30 PM
UK
rb446 Offline
rb446  Offline
UK
Mega Block 589 cubes 4.565 bore x 4.500, just 10:1cr, 5/64 ring pack pistons, tiny Herbert street s/roller, .625/.625" 260/270@.050, 572-13 365cnc heads, 440-2, old 950hp carb, =695 dyno hp@5500-5900, how hard to get another 100hp from that spec upping the CR etc.,and still keeping it pump..... it has gone 10.3@130 with a 727 with a street converter in a 3800lbs RR in full street trim on a 10x29" Hoosier tyre on a no wind day at Santa Pod. Take 850lbs out of the car and it would go>
60 Foot E.T. : 1.31 Seconds
1/8 Mile E.T. : 5.95 Seconds
1/8 Mile Trap Speed : 114.22 MPH
1/4 Mile E.T. : 9.43 Seconds
1/4 Mile Trap Speed : 142 MPH
Just an example.
1969 'Cuda 446ci, best 9.96@133.9 in 1990
1971 340 'Cuda, best 11.01@122.8 in 1987
Re: Lets talk Heads..... [Re: rb446] #3036347
04/23/22 03:02 PM
04/23/22 03:02 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
You dyno and horsepower guys kill me. Lol. Get the damn thing to the race track and put in some work. My little 422 with a solid lifter cam has gone a best of 5.98 and a boat-load of low 6.00’s. Not at some coastal super track either. Off the shelf pistons, no vacuum pump, no special ring packs, and a bracket sized tire 4 inches bigger than needed. Sure it’s 2880 pounds but yours could be too.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Lets talk Heads..... [Re: pittsburghracer] #3036355
04/23/22 03:18 PM
04/23/22 03:18 PM
UK
rb446 Offline
rb446  Offline
UK
it has gone 10.3@130 with a 727 with a street converter in a 3800lbs RR in full street trim on a 10x29" Hoosier tyre on a no wind day at Santa Pod. if that was aimed at me John?......I don't hold much on dyno's either but this time this one was on the money EDA is the company.
Re: Lets talk Heads..... [Re: rb446] #3036357
04/23/22 03:22 PM
04/23/22 03:22 PM
PA.
"Little"John
"Little"John
PA.
it has gone 10.3@130 with a 727 with a street converter in a 3800lbs RR in full street trim on a 10x29" Hoosier tyre on a no wind day at Santa Pod. if that was aimed at me?......I don't hold much on dyno's either but this time this one was on the money EDA is the company.
No it wasn’t aimed at you. Why did you think it was. Maybe I hit reply like most people do from the post above it.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Lets talk Heads..... [Re: pittsburghracer] #3036358
04/23/22 03:22 PM
04/23/22 03:22 PM
UK
rb446 Offline
rb446  Offline
UK
ok John, no worries what you do is cool man.
Page 2 of 4 1 2 3 4
