Re: F M J Body Cars . . .
[Re: Magnumguy]
#3051077
06/16/22 07:07 PM
06/16/22 07:07 PM
Posts: 4,588 St. John's Newfoundland
440newport
I ran it with an a 727 for years but finally got the 4 speed installed in 2017 or so.
What trans did you use? It's a late 60's A body trans with a 2.66 first gear. As Sniper said it's basically a bolt in deal. In my case the hole for the clutch rod was already in the firewall, a earlier rod boot from Brewer's fit fine. The floor hump and pedals I got from a Volare. I couldn't use the pedal assembly as is because the bracket didn't fit the steering column area, as F and J bodies have a different shaped dash. So I just used the pedals themselves on the J body bracket and drilled the hole for the longer clutch pedal support rod to come through.
[Re: poorboy]
#3051256
06/17/22 12:20 PM
06/17/22 12:20 PM
Posts: 6,250 nowhere
Sniper
nowhere
The M bodies came along about 4 years after the first F body showed up. Chrysler had more money, and 4 years to correct a few issues. Harder rubber mounts, thicker upper control arm brackets with some support, and bigger sway bars. Even the later F bodies and the J bodies in between the early F & the M were better handling cars then the early F bodies were. The F body came out in 76, the M body came out in 77. Mechanically the same, cosmetically different. You might be thinking of the J body which came out in 80, again, mechanically the same, cosmetically different. As the mechanical improved they were implemented across the platforms. F/J/M. F body, the original K car.
[Re: moparx]
#3052793
06/23/22 07:36 PM
06/23/22 07:36 PM
Sniper
nowhere
how big in diameter is a K-car booster, and is it a single or dual diaphragm unit ? Depends on whether it's a stick or auto car. Rockauto has pics and dimensions https://www.rockauto.com/en/catalog/dodge,1985,aries,2.2l+135cid+l4,1069163,brake+&+wheel+hub,power+brake+booster,1884
[Re: a12rag]
#3054429
06/29/22 03:53 PM
06/29/22 03:53 PM
Posts: 1,760 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
Awesome !! . . . I do miss my '80 Caravelle . . . 2door like your Dippy . . . but just stock 318, ac, pwr wdw, . . . just all round nice driving car . . . My first very own Mopar was a '80 Plymouth Caravelle...before that it was a '78 Caravelle that my father owned...and in hindsight was crazy enough to let me "tinker" with it...on went the 4 bbl intake, Carter TQ carb, station wagon gears (2.94 vs 2.45 I think?) along with a small head deck shaving pass at his friends machine shop, and lo' and behold, we almost had a stout machine, or as he put it at that time: "too fast, I stepped on the gas and tires started to spin, smoke was coming out"...LOL! Ahh...good times, I was in highschool at that time...ahh, to be that young and carefree again...
[Re: a12rag]
#3078074
09/17/22 12:15 PM
09/17/22 12:15 PM
Posts: 1,217 Endicott, NY
bnichols
Endicott, NY
My current 79 roadrunner 24k miles not that it matters last owned by Galen Govier
2020 Gladiator 1970 Dodge Dart GT
[Re: a12rag]
#3078101
09/17/22 01:53 PM
09/17/22 01:53 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
I just stumbled onto a clean 79 aspen wagon while looking for a set of gears for my dakota, it is just way too nice to part out. It is rot free and only has a little surface rust no bondo or metal replacement needed even the interior is pretty nice. Thinking about a maaco paint job and selling it.
[Re: HotRodDave]
#3078121
09/17/22 03:01 PM
09/17/22 03:01 PM
Posts: 15,871 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Diplomat360's car is legendary to us M body crowd. A12rag that's a beauty and you are right, M's are very nice riding and decent handling to boot. My '89 AHB is an absolute pleasure to drive and I don't car what the E and B body fanatics say. It's a RWD, solid axle, leaf spring/torsion bar suspension V8 car so it's a real Mopar! Bnichols those are beauties you have too!
Facts are stubborn things.
