Page 3 of 4 1 2 3 4
Re: 572 B1 engine install [Re: B1MAXX] #3035414
04/20/22 05:36 PM
04/20/22 05:36 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
One thing I will add is when I use aluminum covers on them I use a split lock on the bolts and overly tighten them. I know I'm getting a little off topic. sorry.
It could be a shaft failure, too hardened.
Re: 572 B1 engine install [Re: 440Jim] #3035417
04/20/22 05:45 PM
04/20/22 05:45 PM
AndyF Offline
AndyF  Offline
Use a long hex rod to check the feel of the oil pump once it has been torqued onto the block. Sometimes the oil pump housing will distort and bind up the gears. In your case it should be fine since you had run it before, but who knows. Might have been a bit of extra resistance coupled with a weak shaft.
Kind of scary, that little hex tip is what keeps a $20,000 engine from eating itself.
Re: 572 B1 engine install [Re: AndyF] #3035420
04/20/22 05:51 PM
04/20/22 05:51 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
It would be interesting to know what the hardness is. I bet there's a way to check it. Probably in my old Machinery handbook.
Re: 572 B1 engine install [Re: 440Jim] #3035421
04/20/22 06:04 PM
04/20/22 06:04 PM
Anchorage, Alaska
metallicareload Offline
Anchorage, Alaska
Awesome effort! Sorry, dumb question, but it looks like the hex end was too short? At least based on how that broken off part looks in that picture?
440, 4-Speed, 3.54
1968, when Dinosaurs ruled the Earth
Re: 572 B1 engine install [Re: 440Jim] #3035471
04/20/22 09:34 PM
04/20/22 09:34 PM
NC
440Jim Offline OP
440Jim  Offline OP
NC
Originally Posted by 440Jim
I will try to get a better picture of the break with my Olympus camera instead of my phone.
A better picture, for whatever it is worth. (Yea its broke and needs to be replaced)
I agree it is a strange looking break. More a brittle fracture than a malleable twist. But the tip should have some hardness, just not brittle.
And it was running after the break, so the ends may have touched, if the broken tip didn't fall farther into the pump recess. It doesn't look like they rubbed.
I will drain the oil pan into a clean plastic tub and look for any engine debris there.
Re: 572 B1 engine install [Re: metallicareload] #3035472
04/20/22 09:39 PM
04/20/22 09:39 PM
NC
440Jim Offline OP
440Jim  Offline OP
NC
Are you looking at the "Before/After" picture, or the picture with the measurements & specs?
I think it looks normal length. shruggy
Re: 572 B1 engine install [Re: AndyF] #3035473
04/20/22 09:44 PM
04/20/22 09:44 PM
NC
440Jim Offline OP
440Jim  Offline OP
NC
I think you are mentioning a possible block error (like Al ) that the oil pump machined pad isn't perfectly aligned with the shaft/bushing in the block.
I have primed the engine many times in the past couple weeks with the oil pump bolted up and the drill "felt" normal turning the pump.
Re: 572 B1 engine install [Re: 440Jim] #3035480
04/20/22 09:53 PM
04/20/22 09:53 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
During mock up, did you install the oil pump drive and tighten down the distributor to check to make sure the oil pump shaft had some clearance? I have seen more than one that bottomed out into the gears.
Joe
Without Data, you’re just another guy with an opinion.
Re: 572 B1 engine install [Re: sr4440] #3035484
04/20/22 10:16 PM
04/20/22 10:16 PM
ohio
dragon Offline
dragon  Offline
ohio
I broke one when I changed a oil pump to a different brand the shaft was too long and I did not notice the distubuter was not seated all the way tighten it down when I started motor made noise found shaft broke because it was too long
Re: 572 B1 engine install [Re: 440Jim] #3035496
04/20/22 11:25 PM
04/20/22 11:25 PM
Cab_Burge Online work
Cab_Burge  Online Work
I had one twist off on the engine after running it to warm the oil up on the dyno after 10 to 15 minutes, this was a new World iron block that had not been machined correctly on the oil pump mount pad, it had a tiny ring (.0003 to .0009 or so) that was sticking out around the oil pump drive hole but not enough to see or feel until using a straight edge across it trying to find out why it broke that shaft off while dyno testing that motor in Boise ,ID for a customer who lived and race there.
I had called my wife to have her bring me the last new one I had in stock back home in Bend and had her drive to Burns, OR (about halfway between Boise, ID and Bend)
The dyno operator found that ridge and had removed it by the time I got back and took it in to the shop the next morning wrench up
I hate Murphy rant shruggy
Re: 572 B1 engine install [Re: 440Jim] #3035506
04/21/22 12:10 AM
04/21/22 12:10 AM
Anchorage, Alaska
Anchorage, Alaska
To be honest, the intermediate shaft looked too short on the computer I saw this on. Def didn't see any measurements & specs.
440, 4-Speed, 3.54
Re: 572 B1 engine install [Re: metallicareload] #3035644
04/21/22 10:08 AM
04/21/22 10:08 AM
NC
440Jim Offline OP
440Jim  Offline OP
NC
I do remember measuring this shaft after I bought it last year (April 2021). That is when I took the "Before" picture with the MP packaging. But I can't find a record of my measurement.
As I recall, it matched the spec length. I was checking to make sure it wasn't longer for certain other Milodon pumps.
Re: 572 B1 engine install [Re: 440Jim] #3035677
04/21/22 12:00 PM
04/21/22 12:00 PM
Anchorage, Alaska
Anchorage, Alaska
Absolutely, looking at your oil pump the only way it could be too short is some type of manufacturing defect. Problem must be on my end, I missed where you measured and depending on what I view on, the broken piece looks short or “normal” shruggy sorry for the distraction and best of luck up
440, 4-Speed, 3.54
Re: 572 B1 engine install [Re: 440Jim] #3035708
04/21/22 01:40 PM
04/21/22 01:40 PM
That looks like bad metal to me rant shruggy Maybe when they forged it , it packed all the bad material in one spot confused
I've seen similar problems on other motor parts like a broken ring with a oval bubble in the material were it broke whiney
Re: 572 B1 engine install [Re: Cab_Burge] #3035716
04/21/22 02:12 PM
04/21/22 02:12 PM
an8sec70cuda Offline
iagree I'm no metallurgist, but that break looks like bad material. twocents
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 572 B1 engine install [Re: an8sec70cuda] #3035781
04/21/22 06:11 PM
04/21/22 06:11 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
too much heat treat does that to good metal.
Re: 572 B1 engine install [Re: B1MAXX] #3035802
04/21/22 07:06 PM
04/21/22 07:06 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
One time I made tapered collets for my magnetic sine vise. I made an oops on the heat treat (didn't read the instructions correctly). It broke when I dropped it to the floor - it was a really small piece.. It was rock hard with zero toughness. Brittle as all heck.
Re: 572 B1 engine install [Re: markz528] #3035931
04/22/22 09:52 AM
04/22/22 09:52 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Wow Jim! The up-side, as has been said, is that it happened where it did. Sorry. This is going to be an impressive runner when it gets out though.
Re: 572 B1 engine install [Re: 440Jim] #3036728
04/24/22 10:10 PM
04/24/22 10:10 PM
NC
440Jim Offline OP
440Jim  Offline OP
NC
I drained the oil into a clean plastic tub. Then I filtered it with a cone shaped disposable paint filter. Zero debris or anything. So it is good to know no other hidden engine wear/damage.
I don't see any pump to drive hex problems. The depth of the hex hole in the oil pump is much deeper than the bronze gear oil pump drive shaft reaches. Hole depth 1.04", and the calculated insertion is only 0.863"
I will double check my measurements.
Re: 572 B1 engine install [Re: 440Jim] #3037319
04/26/22 06:11 PM
04/26/22 06:11 PM
PA
moparacer Offline
moparacer  Offline
PA
Wow, just seen this thread. Stinks you are having trouble Jim.....
I just put a new Milodon oil pump drive in mine last week so I am a bit worried now seeing this.
How much oil pressure are you running?
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Page 3 of 4 1 2 3 4
