Re: How many runs
[Re: wildcargo]
#303546
04/30/09 07:56 AM
04/30/09 07:56 AM
Posts: 52,972 Romeo MI
MR_P_BODY
A couple of things would come into play... how many revs does he turn it to and has it lost power or smoking. I have about 250 passes on my W-9 now and its still running the same ET as it did new. I take a leak down reading when its new for a reference then a couple times a year take another reading... if its not dropping its still doing good. I would say he's doing REAL GOOD with that number of passes but I would at least check the spring pressures
Re: How many runs
[Re: wildcargo]
#303550
05/01/09 10:39 AM
05/01/09 10:39 AM
Thumperdart
State of confusion
I have between 140-150 runs and a few thousand street miles on my 470 and the eagle rods and cap screws are over 8 years old. I run an off-set ground 413 crank w/stock caps and studs and have been 7500 rpm`s and am now changing my generic valve springs out for some spintron tool room iskys to see if it runs better since my springs measured pretty low.
Re: How many runs
[Re: Thumperdart]
#303551
05/01/09 11:08 AM
05/01/09 11:08 AM
Posts: 19,385 Las Vegas
Al_Alguire
Las Vegas
Mine will get freshened at 100+- runs. Rods will be replaced probably pistons and rings and bearing, a bit more compression and cam as I still have some left on the table there. New springs at 50 runs.
Re: How many runs
[Re: wildcargo]
#303556
05/01/09 02:51 PM
05/01/09 02:51 PM
Posts: 3,060 Western New York
sixpackbee
Western New York
I freshen rod bearings and rings at around 80. Valve springs are junk at around 40 or so.
1959 Bugeye Sprite 1967 Charger Black L code 1967 Coronet R/T Convert Green 440 auto bought from original owner 1968 Charger R/T Bronze 440 4 spd console AM/FM 1969 Super Bee WM21H B5 A40 D21 N96 1969 Barracuda Formula S 340 Convert pilot car 1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85 1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96 1970 Road Runner RM21N B3 V1X D13 1971 MG Midget 1971 Road Runner RM23H GW3, A57 1972 Road Runner RM23P FY1, D21
Re: How many runs
[Re: sixpackbee]
#303557
05/01/09 05:35 PM
05/01/09 05:35 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
RB based 493 stroker. With the same short block, same bearings/rings, but ran with several different head, and intake combos. Lets see. About 75-100 runs in the Coronet with hard 5-6K street miles. Then over in the Dakota for 3 seasons, probably a easy 200+ runs. Now sits between the frame rails of a Mud racer, with two seasons, with the original bearings etc. The guy who has it now picked it off a good friend, he came to me and I pulled the pan and looked it over, we put the pan right back on it. No bearing changes. Eagle Crank, and Off shore H-beam rods, and Probe pistons. Stock oiling system, stock main caps, and arp bolts through out. I built the engine in "04".
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
Re: How many runs
[Re: Al_Alguire]
#303560
05/05/09 09:12 AM
05/05/09 09:12 AM
Posts: 5,406 Diego-Town, CA
Diego_Ted
Diego-Town, CA
Why so often, 100 runs. We run our W9 Stuff longer than at in the 8's at 2700.
Herb Jr
Ted the springs are not a huge issue for me. Helps when your brother in law is a higher up at PAC racing.
Ahhh the Bro-Deal!! Grasshopper now understands!! LOL
