Ceramic coating
#3034983
04/19/22 11:09 AM
04/19/22 11:09 AM
Posts: 11,716 Portage,michigan
B3422W5
Portage,michigan
Anyone had a car ceramic coated by a reputable shop Thoughts?
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
Re: Ceramic coating
[Re: TJP]
#3035177
04/19/22 11:03 PM
04/19/22 11:03 PM
B3422W5
Portage,michigan
It most definitely isn’t slick 50. You should get out more..lol
Re: Ceramic coating
[Re: B3422W5]
#3035350
04/20/22 02:03 PM
04/20/22 02:03 PM
Posts: 15,401 Omaha Ne
TJP
Omaha Ne
It most definitely isn’t slick 50. You should get out more..lol Apparently so, but I ask again why wouldn't the major manufacturers be using in on new vehicles to prevent warranty claims on paint problems? Any studies other than by the sellers of the product to prove it's claims? not trying to be an a-s but with an engineering background I like testing and results? Also any particular product seem better ?
Re: Ceramic coating
[Re: B3422W5]
#3035932
04/22/22 09:53 AM
04/22/22 09:53 AM
Posts: 7,491 Minnesota
Hemi_Joel
Minnesota
Back in 2017 I had my Hemi GTX convertible done in ceramic at a detail shop. First I had a guy touch up a few paint chips, then the detail shop clay barred the car and applied a ceramic coating. The whole process really woke up the paint. I have no way of knowing whether the clay bar, or the ceramic coating, or a combination was key in bringing out the results. But I think it looks pretty good for 50-year-old paint. As far as longevity, It still looks just as good 5 years later. But that doesn't necessarily mean much, because the car is kept indoors under a cover when I'm not driving it so it doesn't get much long-term exposure to the elements.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
Re: Ceramic coating
[Re: TJP]
#3035988
04/22/22 12:11 PM
04/22/22 12:11 PM
Posts: 1,061 Atlanta, GA
mgoblue9798
Atlanta, GA
It most definitely isn’t slick 50. You should get out more..lol Apparently so, but I ask again why wouldn't the major manufacturers be using in on new vehicles to prevent warranty claims on paint problems? Any studies other than by the sellers of the product to prove it's claims? not trying to be an a-s but with an engineering background I like testing and results? Also any particular product seem better ? Ok I will bite. Problem with OEM paint over the years has been delamination. Wax, ceramic, nor any other coating is not going to help with that problem. The problems have been largely fixed now for a long time at any rate, and there are very few paint warranty issues now. The "good" ceramic coating applied by dealers is legit. I thought it would be snake oil when it first came out, but it works well. No more waxing and the car will stay cleaner longer in between washes. Has a wet look to it all the time. It also provides more protection against small scratches than wax. I know a guy through my work connections that does this as a full time business and have personally seen dozens of cars with the process done. Guys that work in the shops have it done to their own higher end personal rides and love the results. Sorry I don't have any insight into any particular brand being better than the rest. Just my two cents.
Re: Ceramic coating
[Re: mgoblue9798]
#3035996
04/22/22 12:25 PM
04/22/22 12:25 PM
Posts: 2,255 IL
furious70
IL
I wasn't sure but got the ceramic coating at cost (well, 1/2 of what they quoted at first anyway) done before delivery on my Hellcat. The hydrophobic qualities are pretty impressive. It's white, so a simple hose off doesn't actually clean it completely, but if I had gotten a medium or dark color it probably would. I can literally just hose it off with water after being a filthy pig with road grime on it and the stuff comes right off such that I can then use a waterless cleaner for the trouble spots.
I haven't tried the DIY stuff but if I don't have to wax this thing for the 5-7yrs I'm not supposed to have to, and rinse off works like this for that long, it will have been worth the $
70 Sport Fury 68 Charger 69 Coronet 72 RR
Re: Ceramic coating
[Re: TJP]
#3036002
04/22/22 12:41 PM
04/22/22 12:41 PM
Posts: 271 Anchorage, Alaska
metallicareload
Anchorage, Alaska
FWIW I noticed Toyota offers ceramic coating on factory ordered cars, and when I got my car washed on Tuesday the place had a “ceramic” option
440, 4-Speed, 3.54 1968, when Dinosaurs ruled the Earth
Re: Ceramic coating
[Re: metallicareload]
#3036017
04/22/22 01:01 PM
04/22/22 01:01 PM
B3422W5
Portage,michigan
The guy who runs the detail shop we use( who is the one who would be doing mine) told me he would do it for 400 bucks. That is exactly 1/2 what they normally charge. Pretty hard to pass that up. My Dart is A4 silver, he says it will really pop.
