Distributor for engine test run stand
#3035023
04/19/22 01:00 PM
04/19/22 01:00 PM
Posts: 2,645 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I want to buy a engine test run stand. Normally I would use a DC distributor/chrome box in a street car and a MSD pro-billet/7AL-2 in a race car. But this test stand won't have a box to drive the ignition. What would be a good self contained distributor for this application? That would make things easier. And I would like to buy a stand alone AFR gauge for the mixture but I don't know if any are better than the rest. Thanks.
2011 Drag Pak Challenger
Re: Distributor for engine test run stand
[Re: rickseeman]
#3035048
04/19/22 01:53 PM
04/19/22 01:53 PM
Posts: 13,362 Marion, South Carolina [><]
an8sec70cuda
I used a stock distributor that had a Pertronix electronic module in it on the last 440 I had on my test stand. Nice and clean setup.
I normally use an MSD setup though.
[Re: rickseeman]
#3035055
04/19/22 02:46 PM
04/19/22 02:46 PM
Posts: 421 montana
BANDIT
montana
I have a old MSD 6 box on mine. I made an adapter wire that goes between the MSD distributor/crank trigger to the Mopar electronic distributor. That way I don’t need a different self contained distributor for tall, low, small blocks, or the Chevy motors my buddies bring over. If you only plan on running one particular engine, then carry on. Jim
64 Dodge Coronet 440. In progress 1998. Dodge Avenger. 8.35@165. 4400 DA 250” Neil and Parks Slip Joint. 7.36@183. 4600 DA 242" Mullis Dragster. 6.90@ 200mph
[Re: old_racer]
#3035180
04/19/22 11:07 PM
04/19/22 11:07 PM
Posts: 7,489 Minnesota
Hemi_Joel
Minnesota
I agree on points. I'd use a dual point, nothing starts faster than a dual point, and it is so simple and foolproof.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#3035194
04/20/22 01:49 AM
04/20/22 01:49 AM
Posts: 43,157 Bend,OR USA
Cab_Burge
When I first switch from the old Mopar race chrome with the blue heat sink ECU to an early MSD 4040B ECU with the matching coil my 426 street Hemi stocker started way easier and quicker, a BUNCH quicker
