Assistance needed identifying wire harness
#3034327
04/17/22 09:44 AM
04/17/22 09:44 AM
Posts: 1,562 Macomb, MI
vinnyd76
Macomb, MI
Anyone know what this harness is for? I believe it was removed from a 69 GTX.
Re: Assistance needed identifying wire harness
[Re: vinnyd76]
#3034352
04/17/22 11:03 AM
04/17/22 11:03 AM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
Dome light. Socket is not grounded. Bulb must be chassis ground isolated and just fed by the ground source provided by the door jam switches ( yellow wire ). Pink is constant batt positive.Both are fed to the bulb contacts, nothing to the base. Bulb #1004 The spring bracket on to the socket clips into the dome light housing https://www.ebay.com/itm/303774553644
