Machine shop scaling back; sign of the times
#3033465
04/14/22 10:20 AM
04/14/22 10:20 AM
Posts: 1,201 Loudoun County, VA
Brad_Haak
Loudoun County, VA
Yesterday I dropped by the local machine shop who's been doing my bottom end work over the years, while PRH has been handling my cylinder heads.
It's down to just the owner now and all he's doing is basic block and head machine work: - he doesn't do assembly any longer - his balancing work was done by an older guy who has stopped working due to health issues - and the local crank specialist to whom he'd farm out his crank grinding has also retired
My purpose for stopping by was to introduce him to a long-time friend about an hour west of me who was looking for someone to do some basic block & head machine work, so he's still good to cover that. I'd also wanted to check with him about balancing my backup engine's rotating assembly, only to find out I'll need to find someone else.
These guys are the last of a dying breed and replacing them is gonna be tough.
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Machine shop scaling back; sign of the times
[Re: Dragula]
#3033499
04/14/22 12:05 PM
04/14/22 12:05 PM
Posts: 4,993 new jersey usa
11secdart
new jersey usa
Yes it is a sign if the times these guys are getting older . Both of the machine shops I have used recently have stated they are going to be scaling back and not taking in any new work except special circumstances or work for really good past customers .
[Re: Neil]
#3033541
04/14/22 02:13 PM
04/14/22 02:13 PM
Posts: 10,050 MN
JERICOGTX
MN
My machinist is "retired". His shop is so full he is no longer taking in new customers. He asked if I will be assembling my own engine, as he doesn't really have time. No big deal to me, as I like doing that part. He will also tell current customers that if you bring him something now, it will be at least a year and a half. He turns down work daily. I have no clue where I'll go, when he decides he's had enough.
69 GTX
68 Road Runner
[Re: jwb123]
#3033614
04/14/22 04:49 PM
04/14/22 04:49 PM
Posts: 494 IL
EchoSixMike
IL
I'm in the process of opening a machine shop, south central Wisconsin. Trying to capture some of that knowledge before the old geezers all die off ![wink wink](/ubbthreads/images/graemlins/custom/wink.gif) More or less directly instigated by nobody being able to grind a crank for **** unless you want to ship it to Moldex/Crankshaft Specialists/Marine crank/Winberg/etc. I'm 46 and pretty much the "young guy." Unfortunately a lot of these old shops have equipment just as used up and tired as the people operating them. It's hard to justify spending $50k+ on new machines, and especially tooling and fixturing when the break even on the investment is going to be years and years. And that was when it was available, with the Brandon/COVID shutdown of everything, everyone is monthes and years to delivery. Sunnen flat out tells you it'll be a year before you can get a honing machine from them. All this for a hobby industry. S/F....Ken M
[Re: EchoSixMike]
#3033649
04/14/22 07:39 PM
04/14/22 07:39 PM
Posts: 31,109 Oregon
AndyF
I'm in the process of opening a machine shop, south central Wisconsin. Trying to capture some of that knowledge before the old geezers all die off ![wink wink](/ubbthreads/images/graemlins/custom/wink.gif) More or less directly instigated by nobody being able to grind a crank for **** unless you want to ship it to Moldex/Crankshaft Specialists/Marine crank/Winberg/etc. I'm 46 and pretty much the "young guy." Unfortunately a lot of these old shops have equipment just as used up and tired as the people operating them. It's hard to justify spending $50k+ on new machines, and especially tooling and fixturing when the break even on the investment is going to be years and years. And that was when it was available, with the Brandon/COVID shutdown of everything, everyone is monthes and years to delivery. Sunnen flat out tells you it'll be a year before you can get a honing machine from them. All this for a hobby industry. S/F....Ken M This what I see in the industry also. Most of the "old time" shops have worn out equipment. There isn't enough money in the business for shops to buy new equipment every 10 years so the equipment just wears out. The owner's plan is to retire when the equipment all wears out since he can't afford to replace it all. It would cost $1M to set up a new engine shop with all new equipment and it would take forever to pay it off. Crate motors make more sense economically since they can be produced in a factory setting with lower prices, but cheaper crate motors killed off a lot of "mom and pop" machine shops since they couldn't compete.
[Re: Brad_Haak]
#3033675
04/14/22 10:12 PM
04/14/22 10:12 PM
Posts: 8,510 Candler,NC / Myrtle Beach, SC
JDMopar
The guy who owns the only performance-oriented machine shop near me is 79. He can out work 2 men half his age, but he's pretty much a one man show, so he is understandably a little slow on delivery. I'm pretty lucky that he and I are pretty good friends, and he will shuffle my stuff though a little quicker. I just hope I can get a 340, 273, 451, and a 400 Poncho motor thru his shop before he decides to click off the lights and go to the house.
[Re: JDMopar]
#3033706
04/15/22 02:00 AM
04/15/22 02:00 AM
Posts: 20,228 Park Forest, IL
slantzilla
Park Forest, IL
I tried a new shop last winter for getting a crank cleaned and prepped. The guy that owns the shop is 3rd generation and a racer. Hopefully he'll be around a while.
I use Keith Long for transmissions. He's the same age as me, so hopefully he lasts as long as me too.
[Re: slantzilla]
#3033724
04/15/22 07:58 AM
04/15/22 07:58 AM
Posts: 8,038 Tulsa OK
Bad340fish
Tulsa OK
There might be more than you realize if you start asking the Locals. There is a few around here that are pretty much no sign and no advertising.
My R1 block was done by Shady Dell in 2015, the work is excellent and it sucks that place ended like it did. It was well worth the freight to send it to someone who knew small block Mopars. When that engine needs work I don't know where we will take it.
68 Barracuda Formula S 340
[Re: AndyF]
#3033726
04/15/22 08:05 AM
04/15/22 08:05 AM
Posts: 2,013 Apollo, PA.
B1MAXX
Apollo, PA.
I'm in the process of opening a machine shop, south central Wisconsin. Trying to capture some of that knowledge before the old geezers all die off ![wink wink](/ubbthreads/images/graemlins/custom/wink.gif) More or less directly instigated by nobody being able to grind a crank for **** unless you want to ship it to Moldex/Crankshaft Specialists/Marine crank/Winberg/etc. I'm 46 and pretty much the "young guy." Unfortunately a lot of these old shops have equipment just as used up and tired as the people operating them. It's hard to justify spending $50k+ on new machines, and especially tooling and fixturing when the break even on the investment is going to be years and years. And that was when it was available, with the Brandon/COVID shutdown of everything, everyone is monthes and years to delivery. Sunnen flat out tells you it'll be a year before you can get a honing machine from them. All this for a hobby industry. S/F....Ken M This what I see in the industry also. Most of the "old time" shops have worn out equipment. There isn't enough money in the business for shops to buy new equipment every 10 years so the equipment just wears out. The owner's plan is to retire when the equipment all wears out since he can't afford to replace it all. It would cost $1M to set up a new engine shop with all new equipment and it would take forever to pay it off. Crate motors make more sense economically since they can be produced in a factory setting with lower prices, but cheaper crate motors killed off a lot of "mom and pop" machine shops since they couldn't compete. Yeah, cause crate engines have great machining reputations. Some of the worst taper/tolerances/roundness, I've seen came from state of the art equip shops. It's not the machine it the operator 9/10. just my ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif)
[Re: Brad_Haak]
#3033756
04/15/22 09:12 AM
04/15/22 09:12 AM
Posts: 16,934 NC
440Jim
NC
Back in 2003, etc. when I lived in Maryland; I used this shop for crankshaft work (including my first offset grind of a factory steel crank) and I was happy. They had a few crank grinding machines, and did lots of different crankshaft work (tractors, truck diesel, race, etc.) I don't know if they are still doing crankshaft work. Martin & Otterback Shop: 301-277-4166 Upshure Ave, Bladensburg, MD Art crankshaft grinding. Rt 50, Rt 201, Kenilworth, Left on Upshure between 48th and 49th
[Re: B1MAXX]
#3033840
04/15/22 02:37 PM
04/15/22 02:37 PM
Posts: 7,499 Minnesota
Hemi_Joel
Minnesota
I have been buying old machines for years. Ever since my go to guy started talking about closing Early 2000's. He's gone now (from business). I have some of his stuff and luckily he's just a phone call away. Once you learn the machine you can produce very nice stuff.I have an old Van norman 905, and a Peterson HC-1 with a friction feed and produce bores with .0005 or better. Check some of the high end stuff. You'll know that's pretty good. I'm doing the same thing, trying to collect all of the machinery to do it myself. Then it gets done my schedule.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
