Grille/headlight surround screws #3033260
04/13/22 05:03 PM
04/13/22 05:03 PM
Martinsville, IN
cdwmotorsports Offline OP
Martinsville, IN
I’m looking for new screws for my headlight bezels/surrounds for a 72 Dart/Demon. I believe there are (6) 1” long fine thread Phillips head screws with a tapered/pointed end and then (2) similar shaped and thread screws that are right at 3” long. They are black but at this point I can’t paint them if need be.
eBay-cdwmotorsports
Re: Grille/headlight surround screws [Re: cdwmotorsports] #3033279
04/13/22 05:54 PM
04/13/22 05:54 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
For an application where the screws don't have to be OEM correct, and you're screwing into the plastic bushings, a regular-pitch screw works.
I've had to do that when a previous owner either lost the OEM screws or used regular ones, and the car was never gonna be a correct restoration again.
Re: Grille/headlight surround screws [Re: topside] #3033286
04/13/22 06:05 PM
04/13/22 06:05 PM
Martinsville, IN
Martinsville, IN
I understand that, but I’m looking for the correct screws
eBay-cdwmotorsports
Re: Grille/headlight surround screws [Re: cdwmotorsports] #3033385
04/13/22 10:37 PM
04/13/22 10:37 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Once they are installed no one will ever know the difference. shruggy
Re: Grille/headlight surround screws [Re: stumpy] #3033389
04/13/22 10:44 PM
04/13/22 10:44 PM
Martinsville, IN
Martinsville, IN
False, I’ll know.
eBay-cdwmotorsports
Re: Grille/headlight surround screws [Re: cdwmotorsports] #3033496
04/14/22 11:56 AM
04/14/22 11:56 AM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
Try R.T. specialties
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: Grille/headlight surround screws [Re: MOPARMIKE69] #3033544
04/14/22 02:21 PM
04/14/22 02:21 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Thinking about it, I don't recall any of the screws being 3" long on the '70-'72s.
Maybe I'm wrong, as I presume the OP measured them.
You can try this guy:
https://www.ebay.com/itm/144496709892?
Not the pitch requested, but search his store.
I've bought hard-to-find stuff from them before, no problems.
Re: Grille/headlight surround screws [Re: topside] #3033615
04/14/22 04:50 PM
04/14/22 04:50 PM
Martinsville, IN
Martinsville, IN
They’re longer than 2 3/4” not quite 3” but close enough that I called it 3”. I’ll take a look there and at R/T specialties. As a heads up top outer screw is the “3” inch one. The other three are each the “1” inch screws
eBay-cdwmotorsports
Re: Grille/headlight surround screws [Re: MOPARMIKE69] #3033617
04/14/22 05:03 PM
04/14/22 05:03 PM
Martinsville, IN
Martinsville, IN
[align:left][/align]
Thank you very much. Tom at R/T Specialties had exactly what I needed. The screws are located in a kit, I didn’t need the other stuff in the kit but I ordered two kits anyway. The kit number for anyone looking is 1000179 1972 Dart grille fasteners.
72 Grille Fastener kit
eBay-cdwmotorsports
