Grille/headlight surround screws
#3033260
04/13/22 05:03 PM
04/13/22 05:03 PM
Posts: 1,467 Martinsville, IN
cdwmotorsports
Martinsville, IN
I’m looking for new screws for my headlight bezels/surrounds for a 72 Dart/Demon. I believe there are (6) 1” long fine thread Phillips head screws with a tapered/pointed end and then (2) similar shaped and thread screws that are right at 3” long. They are black but at this point I can’t paint them if need be.
eBay-cdwmotorsports
Re: Grille/headlight surround screws
[Re: stumpy]
#3033389
04/13/22 10:44 PM
04/13/22 10:44 PM
cdwmotorsports
Martinsville, IN
Once they are installed no one will ever know the difference. False, I’ll know.
eBay-cdwmotorsports
[Re: MOPARMIKE69]
#3033544
04/14/22 02:21 PM
04/14/22 02:21 PM
Posts: 20,916 A collage of whims
topside
A collage of whims
Thinking about it, I don't recall any of the screws being 3" long on the '70-'72s. Maybe I'm wrong, as I presume the OP measured them. You can try this guy: https://www.ebay.com/itm/144496709892?Not the pitch requested, but search his store. I've bought hard-to-find stuff from them before, no problems.
[Re: topside]
#3033615
04/14/22 04:50 PM
04/14/22 04:50 PM
cdwmotorsports
Martinsville, IN
Thinking about it, I don't recall any of the screws being 3" long on the '70-'72s. Maybe I'm wrong, as I presume the OP measured them. You can try this guy: https://www.ebay.com/itm/144496709892?Not the pitch requested, but search his store. I've bought hard-to-find stuff from them before, no problems. They’re longer than 2 3/4” not quite 3” but close enough that I called it 3”. I’ll take a look there and at R/T specialties. As a heads up top outer screw is the “3” inch one. The other three are each the “1” inch screws
eBay-cdwmotorsports
[Re: MOPARMIKE69]
#3033617
04/14/22 05:03 PM
04/14/22 05:03 PM
cdwmotorsports
Martinsville, IN
[align:left][/align] Thank you very much. Tom at R/T Specialties had exactly what I needed. The screws are located in a kit, I didn’t need the other stuff in the kit but I ordered two kits anyway. The kit number for anyone looking is 1000179 1972 Dart grille fasteners. 72 Grille Fastener kit
eBay-cdwmotorsports
