Cometic Gaskets Thickness
#3033232
04/13/22 04:37 PM
04/13/22 04:37 PM
Posts: 270 Mountain View, CA
68rrunner
Mountain View, CA
Did a quick search, didn't see much, So figured I'd ask.... Got a street 440, flat tops are .100 in the hole. Short block is used, but in good shape. Small unknown cam, 906's and factory iron 4bbl coming out/off, Hughes HUG SEH3642BL-8 hydraulic flat tappet going in, OOTB stealth's and an aluminum Eddy 4bbl manifold. The 440 source head gaskets (.051) are going to put me at 8.75:1 cr. I'd like to get into the .032-.027 range thickness, should net me a 9.07-9.15 cr. Will the Cometic MLS seal on a used deck for a street engine? Any thickness or type I should avoid?
Re: Cometic Gaskets Thickness
[Re: Pacnorthcuda]
#3033333
04/13/22 08:09 PM
04/13/22 08:09 PM
Posts: 4,701 On the parachute mount
n20mstr
We put Cometics on my sons magnum . Stock decks and they sealed 10.5 compression no problems . Alum heads stock factory deck finish
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#3033339
04/13/22 08:19 PM
04/13/22 08:19 PM
Posts: 9,883 MI, usa
dvw
MI, usa
Just use the old style steel shim gaskets you'll be good to go. From Summit. .020" thick
MR. GASKET MR. GASKET STEEL SHIM HEAD GASKET Fits 1959-1978 Chrysler 361-440 B/RB Big Block. 4.400 Inch Bore, .020 Inch Compressed Thickness
Part # 1135G Be the first to write a review In Stock YOUR PRICE $28.41
Doug
[Re: dvw]
#3033342
04/13/22 08:32 PM
04/13/22 08:32 PM
Posts: 43,317 Bend,OR USA
Cab_Burge
Doug i have used the stock style steel shim head gaskets on iron block and heads with the stock machine work with no problems using 2 or 3 light coats of Copper Coat on both sides of those gaskets ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) I've also used aluminum paint when I was out of copper coat and couldn't go buy another can of it do to the parts stores being close at night and I needed ![whistling whistling](/ubbthreads/images/graemlins/custom/whistling.gif) , I wanted to, to go racing the next morning ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif)
[Re: dvw]
#3033367
04/13/22 09:39 PM
04/13/22 09:39 PM
Posts: 16,932 NC
440Jim
NC
Doug I agree. Just for overkill I would put Permatex Copper coat head gasket sealant on it. And never look back (at that low CR).
