Re: Homemade lo-buck Cam Doctor
[Re: hemienvy]
#3032564
04/11/22 11:18 AM
04/11/22 11:18 AM
Posts: 201 Texas
Chief
Texas
I disagree.. The follower has different contact area which alters where on the lobe you are measuring.. Look at this degree tool kit, specifically the followers. You will see what I'm talking about. Degree Tool KitDave
Dave Covey
[Re: Chief]
#3032566
04/11/22 11:23 AM
04/11/22 11:23 AM
Posts: 201 Texas
Chief
Texas
I'll also add your homemade setup will not measure ramp design without a lot of notebook space. Not sure how many calculations it would take to accomplish.
You could get rudimentary numbers, no problem. It would be nice if it were that simple.
My opinion though..
Dave Covey
[Re: Chief]
#3032567
04/11/22 11:27 AM
04/11/22 11:27 AM
Posts: 21,844 Kirkland, Washington
Pacnorthcuda
I disagree.. The follower has different contact area which alters where on the lobe you are measuring.. Look at this degree tool kit, specifically the followers. You will see what I'm talking about. Degree Tool KitDave An issue with flat tappets, yes. Not with rollers.
[Re: Pacnorthcuda]
#3032588
04/11/22 12:28 PM
04/11/22 12:28 PM
Posts: 1,166 Loudoun County, VA
Brad_Haak
Loudoun County, VA
I disagree.. The follower has different contact area which alters where on the lobe you are measuring.. Look at this degree tool kit, specifically the followers. You will see what I'm talking about. Degree Tool KitDave An issue with flat tappets, yes. Not with rollers. Crane Cams had a tech article on effect on duration w/ increase in roller wheel diameter from standard .750" to .810": Example from R280/500 .020 = 0.8 .050 = 1.3 .100 = 1.6 .200 = 1.7 .300 = 1.4 .400 = 0.9 Lifter wheel diameter absolutely has an impact on the motion translated at the pushrod.
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: hemienvy]
#3032632
04/11/22 02:57 PM
04/11/22 02:57 PM
Posts: 28,069 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I'm not sure I could measure lobe separation. But maybe.
But measuring one lobe profile should be doable. Measure one lobe then the other. Compare. If you want the lobe info then measure the lobe directly. Use a small round tip on your dial indicator to minimize angularity error due to contact being slightly off to one side of the tip. Plot the results on graph paper.
[Re: Pacnorthcuda]
#3032677
04/11/22 05:31 PM
04/11/22 05:31 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
I disagree.. The follower has different contact area which alters where on the lobe you are measuring.. Look at this degree tool kit, specifically the followers. You will see what I'm talking about. Degree Tool KitDave An issue with flat tappets, yes. Not with rollers. Roller wheel size has a large impact on transferred motion from the lobe. Most lobe catalogs address this.
