Homemade lo-buck Cam Doctor #3032561
04/11/22 11:09 AM
04/11/22 11:09 AM
Washington
hemienvy Online content OP
hemienvy  Online Content OP
Washington
With a degree wheel and a notepad, I don't see why you couldn't measure your cam profile yourself.
My only question is what kind of follower would you use ?
It should not matter at all what kind of follower the cam was designed for,
what you are measuring is simply lobe lift at a degree position.
Re: Homemade lo-buck Cam Doctor [Re: hemienvy] #3032564
04/11/22 11:18 AM
04/11/22 11:18 AM
Texas
Chief Offline
Chief  Offline
Texas
I disagree.. The follower has different contact area which alters where on the lobe you are measuring..
Look at this degree tool kit, specifically the followers. You will see what I'm talking about.
Degree Tool Kit
Dave Covey
Re: Homemade lo-buck Cam Doctor [Re: Chief] #3032566
04/11/22 11:23 AM
04/11/22 11:23 AM
Texas
Chief Offline
Chief  Offline
Texas
I'll also add your homemade setup will not measure ramp design without a lot of notebook space. Not sure how many calculations it would take to accomplish.
You could get rudimentary numbers, no problem.
It would be nice if it were that simple.
My opinion though..
Dave Covey
Re: Homemade lo-buck Cam Doctor [Re: Chief] #3032567
04/11/22 11:27 AM
04/11/22 11:27 AM
Kirkland, Washington
Pacnorthcuda Offline
Degree Tool Kit
An issue with flat tappets, yes. Not with rollers.
Re: Homemade lo-buck Cam Doctor [Re: Pacnorthcuda] #3032580
04/11/22 12:14 PM
04/11/22 12:14 PM
Washington
Washington
What does the actual Cam Doctor use for a follower ?
I guess I could look that up.
Re: Homemade lo-buck Cam Doctor [Re: Pacnorthcuda] #3032588
04/11/22 12:28 PM
04/11/22 12:28 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Degree Tool Kit
Crane Cams had a tech article on effect on duration w/ increase in roller wheel diameter from standard .750" to .810":
Example from R280/500
.020 = 0.8
.050 = 1.3
.100 = 1.6
.200 = 1.7
.300 = 1.4
.400 = 0.9
Lifter wheel diameter absolutely has an impact on the motion translated at the pushrod.
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Homemade lo-buck Cam Doctor [Re: Brad_Haak] #3032589
04/11/22 12:31 PM
04/11/22 12:31 PM
Washington
Washington
Yes the follower has an impact on valve lift.
I just want to measure lobe lift.
Re: Homemade lo-buck Cam Doctor [Re: hemienvy] #3032601
04/11/22 01:10 PM
04/11/22 01:10 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
There is no better fixture than the block itself !!
Re: Homemade lo-buck Cam Doctor [Re: Stanton] #3032611
04/11/22 01:25 PM
04/11/22 01:25 PM
Washington
Washington
Stanton, my thoughts exactly.
Re: Homemade lo-buck Cam Doctor [Re: hemienvy] #3032627
04/11/22 02:20 PM
04/11/22 02:20 PM
Washington
Washington
https://www.youtube.com/watch?v=cNy6iK_f0_4
It looks like the machine has a roller follower.
Re: Homemade lo-buck Cam Doctor [Re: hemienvy] #3032631
04/11/22 02:41 PM
04/11/22 02:41 PM
Washington
Washington
I'm not sure I could measure lobe separation. But maybe.
But measuring one lobe profile should be doable.
Re: Homemade lo-buck Cam Doctor [Re: hemienvy] #3032632
04/11/22 02:57 PM
04/11/22 02:57 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Measure one lobe then the other. Compare.
If you want the lobe info then measure the lobe directly. Use a small round tip on your dial indicator to minimize angularity error due to contact being slightly off to one side of the tip. Plot the results on graph paper.
- Stu Harmon
Re: Homemade lo-buck Cam Doctor [Re: Pacnorthcuda] #3032677
04/11/22 05:31 PM
04/11/22 05:31 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Degree Tool Kit
Roller wheel size has a large impact on transferred motion from the lobe. Most lobe catalogs address this.
Re: Homemade lo-buck Cam Doctor [Re: TRENDZ] #3032679
04/11/22 05:36 PM
04/11/22 05:36 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
If you use the block, cam, and tappet that you will be using, you can measure pretty close to anything you want. Bonus if your lifter bores are not true you will see exactly what dimensions the engine is running at.
Doug
Re: Homemade lo-buck Cam Doctor [Re: hemienvy] #3033108
04/13/22 11:39 AM
04/13/22 11:39 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Done it using the block and lifters, and manually recording Intake and exhaust lift every degree for 720 degrees, or 1440 data points. Pretty time consuming.
I though about building a rotary encoder type degree wheel and using two indicators with the data outputs for each lobe measurement, and have all the data logged into a computer which would record each lobe lift for each increment of the encoder output.
