Re: Sagging Rear
[Re: Crosshairs]
#3031709
04/07/22 10:13 PM
04/07/22 10:13 PM
Posts: 667 Los Osos, Ca
CKessel
Los Osos, Ca
Springs, unless there is a structural or mount issue. Shock absorbers don't carry or support the load. They "absorb" the movements in the suspension to control and smooth things out.
Carl Kessel
Re: Sagging Rear
[Re: Sniper]
#3031758
04/08/22 04:38 AM
04/08/22 04:38 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
If the problem is sagging leaf springs (or wheel hop), the easy fix is to add one more long leaf to the spring assembly. That fixed my car about 40 years ago, and it is still fixed.
Re: Sagging Rear
[Re: GMP440]
#3032386
04/10/22 05:24 PM
04/10/22 05:24 PM
Posts: 15,893 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
You can compensate for that by cranking out the the torsion bar bolt to lower the left front . That will bring the right rear part of the car back up.
This is what I've found to be best compensator to even rear. I had a couple of leaf spring rear end Mopars years past that I let drive me nuts because walking up on the cars from rear you could see one end sat lower. I checked EVERYTHING. From tire pressure to leaf springs. I even went as far as switching the leafs (obviously on a car that they were identical left and right). Didn't change it. I tried adding an extra spring pad to the one side (OCD much lol). I also bought Firm Feels front mounts and mounted one side in the lower mount and the other in the upper mount. That had to have made at least a miniscule difference but probably not visible and BARELY measurable. One issue is that when you raise one side of the rear, the other side will come up too. Just take a yard stick and hold it to one side and have someone lift by hand the other side and you'll see. I finally decided the best way was to mitigate it a bit with the front as suggested. Push the one rear side down a bit by lifting the opposite front corner up. Just a tad and find a good balance. I also got a lithium battery which removed about 40 pounds from my left front and definitely helped.
Facts are stubborn things.
Re: Sagging Rear
[Re: Jeff_383]
#3033432
04/14/22 08:55 AM
04/14/22 08:55 AM
Posts: 12,141 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
The rear U clamp if you want to put it up side down so that it can't be seen.
Master, again and still
Re: Sagging Rear
[Re: topside]
#3033642
04/14/22 07:00 PM
04/14/22 07:00 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
If I understand your point, I just used the shank of a long bolt that I cut the head and threaded areas off of.
Re: Sagging Rear
[Re: 70satelliteguy]
#3033732
04/15/22 08:31 AM
04/15/22 08:31 AM
Posts: 992 rust belt
Moparite
rust belt
Shock absorbers don't carry or support the load Ever heard of Hijackers? If it where mine i would get new springs or find a place that can re arch the originals. Getting "helper" springs to fix sagging springs is just a bandaid for the original problem.
Re: Sagging Rear
[Re: Moparite]
#3033775
04/15/22 09:56 AM
04/15/22 09:56 AM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Shock absorbers don't carry or support the load Ever heard of Hijackers? If it where mine i would get new springs or find a place that can re arch the originals. Getting "helper" springs to fix sagging springs is just a bandaid for the original problem. U.S. made Hellwig helper springs are not a band-aid. And they certainly are not the equivalent of air shocks. They are basically like adding an additional leaf. Just heavier and adjustable. Many of us have had our half century old original springs re-arched only to have them sag back down. And what height they are actually re-arched to is a crap shoot. And many of the new springs suffer the same issues. I have had new springs and have had original springs re-arched. I have not been happy with the results. You are kinda stuck with whatever height comes out of the box with no way to set the height or balance that you want. The Hellwig helper springs solve all of those issues. Permanently. They also allow you to change the height should you change tires or just want a little different look. Try that with new or re-ached springs. Less than $100, American made quality, adjustable, easy install, stealthy.............what's not to like?
Re: Sagging Rear
[Re: DaveRS23]
#3033858
04/15/22 04:06 PM
04/15/22 04:06 PM
Posts: 1,548 Mattituck NY.
FJ6AAR
Mattituck NY.
Shock absorbers don't carry or support the load Ever heard of Hijackers? If it where mine i would get new springs or find a place that can re arch the originals. Getting "helper" springs to fix sagging springs is just a bandaid for the original problem. U.S. made Hellwig helper springs are not a band-aid. And they certainly are not the equivalent of air shocks. They are basically like adding an additional leaf. Just heavier and adjustable. Many of us have had our half century old original springs re-arched only to have them sag back down. And what height they are actually re-arched to is a crap shoot. And many of the new springs suffer the same issues. I have had new springs and have had original springs re-arched. I have not been happy with the results. You are kinda stuck with whatever height comes out of the box with no way to set the height or balance that you want. The Hellwig helper springs solve all of those issues. Permanently. They also allow you to change the height should you change tires or just want a little different look. Try that with new or re-ached springs. Less than $100, American made quality, adjustable, easy install, stealthy.............what's not to like? Have to agree with Dave here - been there done that over the years - re-arching is a waste of money and time and Chinese new springs - just a matter of time and will sag lower than the worn out originals. I've had good experiences with helper springs too - and as Dave said, you can change height to your liking easily much much better than Hijackers and Chinese springs.
1970 Hemi 'Cuda hard top clone
1971 Hemi 'Cuda Convertible clone
