1969 GTS Vinyl Roof #3031979
04/08/22 08:50 PM
04/08/22 08:50 PM
North Dakota
6PakBee Online content OP
6PakBee  Online Content OP
North Dakota
I was going through the Legendary website looking for a vinyl roof for my '69 GTS. And I find they list both a 43" center deck and a 38" center deck. Which one is correct? There are no remnants of the original vinyl roof so I can't just go out and measure the old one.
Re: 1969 GTS Vinyl Roof [Re: 6PakBee] #3032067
04/09/22 11:10 AM
04/09/22 11:10 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
My '69 Dart GTS 440 M-code vinyl roof has been removed but on one side it is still visible where the "seam" was located. The width of the GTS's roof at the front of the door up from the point of the vent window is 50" across. The visible "seam" line is 6 inches inboard of the edge of the roof on both sides or 12".
50" - 12" = 38" on my '69 GTS. If the "center deck" is the space between the two "seams" then mine is 38". Hope this helps.
Re: 1969 GTS Vinyl Roof [Re: A12] #3032075
04/09/22 11:28 AM
04/09/22 11:28 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
You might be able to use these photos as reference points to measure on your GTS to get an idea??
The last photo looks like the "seam" would be the 43" center deck as it appears to be less than my GTS and less than the other three photos I posted??
2103_6_low_res.jpg23623_141trs2.jpg23629_141trs8.jpg69 Dart 440 art Mopar Action pg 2.jpg
Re: 1969 GTS Vinyl Roof [Re: A12] #3032107
04/09/22 01:42 PM
04/09/22 01:42 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Not that it matters, but the wider seam spacing in those photos looks better-proportioned to me.
I've owned a '69 and a '73 with VT but can't recall the seam spacing very well decades later.
Re: 1969 GTS Vinyl Roof [Re: topside] #3032124
04/09/22 02:34 PM
04/09/22 02:34 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
I wonder if it is LA VS. Hamtramck production shruggy
Re: 1969 GTS Vinyl Roof [Re: 6bblgt] #3032138
04/09/22 03:28 PM
04/09/22 03:28 PM
North Dakota
North Dakota
Thank you, thank you, thank you!!!! I appreciate the photos and dimensions as they nail down the situation. As to which was correct, it seems the answer is that they both could be. 6bblgt's comment about the assembly plant is intriguing. Unless something else more definitive is unearthed, I think I'll go with the 43".
Re: 1969 GTS Vinyl Roof [Re: 6PakBee] #3032186
04/09/22 06:11 PM
04/09/22 06:11 PM
oregon
greendart408 Offline
oregon
My original paint 69, 340 la built swinger is I believe 43. I would have to measure it again, left that part on the car.
As I’m in process of restoring it. So I would know what to order when time comes. All original car
Update
I just measured it, most definitely 38”. Hope this helps someone.
Re: 1969 GTS Vinyl Roof [Re: greendart408] #3032199
04/09/22 08:00 PM
04/09/22 08:00 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Looks like 38" with the distance of the "seam" from the edge of the roof. Compare yours to the green Darts above. The T7 or bronze Dart 440 looks to be the 43" center between the seams. But it will be great for you to measure yours up
Re: 1969 GTS Vinyl Roof [Re: A12] #3032487
04/10/22 10:05 PM
04/10/22 10:05 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I always used the 38" seam. I do have a couple of Western Sport Special's but don't remember if there is anything left of the vinyl tops, they are both parts cars...
JB Rhinehart, Realist
A-Body's RULE!
