Side exhaust cover test model #3031313
04/06/22 04:19 PM
04/06/22 04:19 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I wanted to see if I could come up with something that looked a LITTLE better more than function and it would be full length to the back tire.I could make the cover straight up/down along the pipe and not below the bottom of the pipe.I figure I would ask risking criticism.(be kind)
Re: Side exhaust cover test model [Re: Clanton] #3031357
04/06/22 06:53 PM
04/06/22 06:53 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I think I would make it two piece, one that would attach under the rocker, maybe at the pinch weld, then extend out from under the rocker as far as needed, then bend down 90 degrees. The 2nd part would attach to the first part, then extend straight down as far as needed with a 45 - 90 degree bend back under the exhaust at the bottom. Mounting the 1st piece could be a pain, but I think it would look better.
What you have now looks like a quick coverup, and I don't like the idea of the visible screws into the rockers.
Was that kind enough? up Gene
Re: Side exhaust cover test model [Re: poorboy] #3031364
04/06/22 07:10 PM
04/06/22 07:10 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Most covers like that have holes in them to allow the heat to escape otherwise the underside of the car gets hot.
Problem might be finding a prepunched sheet thick enough.
Re: Side exhaust cover test model [Re: Clanton] #3031369
04/06/22 07:30 PM
04/06/22 07:30 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I appreciate the info and ideas. The 1/2" pinch in the rocker to mount the shield I have not been able to clip on a body clip to screw into.I am trying to use holes that are there and not make new 1s to hold up the shield keeping it simple.
ps:I wonder if I can just bolt something to the exh pipe itself.1 more thing the ss perferated cover like on a Vette that bolts to the pipe is too much $$ I think it was over 100$ a side so that is out but I could make an aluminum 1.
Re: Side exhaust cover test model [Re: Clanton] #3031538
04/07/22 11:49 AM
04/07/22 11:49 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Maybe you could use something like a muffler clamp around the pipe at the front and the back, then have holes in the cover that fit onto the U bolt threads. A longer U bolt, like threaded rod bent around the pipe to fit into the steel bracket part of the clamp with a couple nuts on that holding the clamp firmly in place on the pipe, then slide the cover over the U bolt, and add a couple of those stainless acorn nuts to hold the cover. If you bolt the cover to the pipe, a simple curved piece would probably work out pretty well. At least 2, and maybe 3 clamps per side would work, the hard part would be to position it so the cover is level to the rockers, front to back. The nice part of a cover bolted to the pipe is you can make the cover as long as you want it.
As far as the cover, thicker aluminum might work OK, as long as its not right against the pipe, my concern with thin aluminum would be its ability to withstand the heat and keep the form. I would think the aluminum wouldn't hold up as well as the stainless, and probably wouldn't look as good as long, but it would probably be better looking then the pipe. You may want to consider looking into plain perforated steel painted high temp silver or high temp black. I would think the steel would hold up to the heat and keep the form better then thin aluminum, and you may have more choices with the steel.
None of that perforated metal is cheap these days, heck, not even simple 20 gauge sheet metal is cheap anymore. Gene
Re: Side exhaust cover test model [Re: poorboy] #3031559
04/07/22 12:45 PM
04/07/22 12:45 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Thanks for the reply/idea.Yes the angle is hard with a bolt on and is why I tried the rocker 1st.I can make a strap that would bolt to the top/bottom of the cover and clamp that maybe like you said and make the strap so the cover is level to the rocker.I have a 4x8'sheet of steel and a 48" box/pan brake to bend things nothing to roll with so why I have angles.I will look to copy the ss covers for sale mounting 1st.
Thanks again
Re: Side exhaust cover test model [Re: Clanton] #3031605
04/07/22 03:04 PM
04/07/22 03:04 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
I'd redo the bottom part of exhaust with SS oval tubing and a Supertrapp or a nascar style muffler and try to fancy it up vs trying to hide it with a panel attached to the rocker.
Re: Side exhaust cover test model [Re: Neil] #3031654
04/07/22 06:00 PM
04/07/22 06:00 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Thanks but if I redo it I would run it inside the frame like a normal header exhaust.
Re: Side exhaust cover test model [Re: Clanton] #3031850
04/08/22 01:25 PM
04/08/22 01:25 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
under the rocker test fit,look. This version looks like I can mount it to the seem and I will work on the outer edge holding it up on the rocker better as well as holding the pipe up.
Re: Side exhaust cover test model [Re: Clanton] #3031961
04/08/22 07:37 PM
04/08/22 07:37 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
That would work. You could clamp it in place and drill 3 or 4 holes through the flange to run bolts through. Once the holes are drilled, you could put the bolts through the cover, and weld them in place, then stick the bolts through the holes in the rocker flanges, and slide on a washer and spin on a nut for each bolt from the back side where access is easy. You might not want that bottom bend to be quite 90 degrees, so water that might get in there can run out. I can't see how far under the pipe that bottom piece is, but you might not want it too wide (maybe about 1/2 the diameter of the pipe wide), the heat could escape better with a narrow bottom flange. Paint them with high temp paint, they could get hot through the summer.
Re: Side exhaust cover test model [Re: poorboy] #3032087
04/09/22 12:31 PM
04/09/22 12:31 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I didn'thave a way to trim the bottom so I just left it for later and I will angle it down ty.I have been using 1/4"20thread bolts on the current hanger(3/4" strap about 14" long) so I will use the same hole,bolt/nut nyloc.I have a 3 1/2" exh because my engine has a blower(8-71 700 to 1k hp when I want)Thank you for your input!I need to start putting my blower back on so I will be working on the exh as I go.
Re: Side exhaust cover test model [Re: Clanton] #3032247
04/10/22 12:04 AM
04/10/22 12:04 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Looks like that will work. Post up pictures of the finished product, please.
Re: Side exhaust cover test model [Re: poorboy] #3032292
04/10/22 10:25 AM
04/10/22 10:25 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
Why not just use side pipes?
Re: Side exhaust cover test model [Re: Moparite] #3032327
04/10/22 12:49 PM
04/10/22 12:49 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
There is no kit with 2 1/4 pri 3 1/2"collector pipesI looked at them at summit if that is what you are asking.I did buy some and test fit and didn't like the fit and returned them.
Re: Side exhaust cover test model [Re: Neil] #3037484
04/27/22 02:32 AM
04/27/22 02:32 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
iagree
Another option would be to have the exhaust you already have Ceramic Coated.
A buddy just did that on the fenderwell headers on his big block Dart.
They looks awesome, and they were used crusty headers..
I've been thinking about having it done on the exhaust on our 69 Dart with fenderwell headers, the portion under the car looks really similar to what yours looks like other than flowmaster type mufflers.
This is the place that did his, I'm planning on seeing what it would cost.
Obviously not close to you, but it would be an idea of cost.
https://www.jcmmachineandcoatings.com/
Re: Side exhaust cover test model [Re: SNK-EYZ] #3037552
04/27/22 10:31 AM
04/27/22 10:31 AM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
A few thoughts:
1. That outlet location seems problematic that close to the driver's window: not only noise, but fumes.
2. I'd want to hide the exhaust rather than double-down on the visual focus.
3. Changing the collector so its exit is under the car may not be possible, and I don't know if exhaust gets frequently removed.
4. Using that collector, you could do a system similar to how the Maxies were: exhaust coming from collector a bit upstream of a capped-off collector exit.
Re: Side exhaust cover test model [Re: topside] #3037933
04/28/22 11:40 AM
04/28/22 11:40 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
The noise is music to me and I get enough flow at idle to push air away and a little race gas smell is no bother. I do mostly test drives and a few track days with the car and take it off and on for testing so the side pipes help with access and I am not re doing the collector to move the exh or I would have done it by now.My focus is on keeping it running for now but thank you for your input!
Re: Side exhaust cover test model [Re: poorboy] #3143062
05/07/23 03:51 PM
05/07/23 03:51 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
This is what I went with for now.I had trouble finding sheet metal sold to public during covid-19 Metal supermarket on Granger rd near Cleveland,Ohio
Re: Side exhaust cover test model [Re: Clanton] #3171579
08/30/23 09:50 AM
08/30/23 09:50 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I think I'd use perforated stainless sheet for that.
