Re: Rocker pushrod adjusters?
[Re: RATTRAP]
#3031208
04/06/22 12:06 PM
04/06/22 12:06 PM
Posts: 1,189 Loudoun County, VA
Brad_Haak
Loudoun County, VA
Are you asking for brand or configuration recommendation? Post makes no sense... ![confused confused](/ubbthreads/images/graemlins/custom/confused.gif)
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: RATTRAP]
#3031222
04/06/22 12:21 PM
04/06/22 12:21 PM
Posts: 2,123 Byron, NY
W.I.N. Racing
Byron, NY
I use with great success Manton through hole PR adjusters. stopped my cup/ball gauling issue part number 824 IIRC yoru part # may be different
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: Cab_Burge]
#3031271
04/06/22 02:29 PM
04/06/22 02:29 PM
Posts: 1,581 N/E, Michigan
RATTRAP
N/E, Michigan
It depends on the rocker arm used if you need through the pushrod oiling or through the adjuster oiling to the pushrod tip ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) Some of the high end extruded aluminum shaft mounted rocker arms use oiling through the adjuster in different ways, some have several threads missing for the oil passage and others machine it in the rocker arm adjuster hole I'm using Stage V 426 Hemi lifters and need to order the adjusting screws. Thank you Cab I understand now!
[Re: Stanton]
#3031448
04/06/22 11:46 PM
04/06/22 11:46 PM
Posts: 2,685 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I'm still confused because Stage V doesn't make lifters. I'm assuming he's talking about Stage V rockers. So if that's the case, all the Stage V rockers made in the last 10 or 15 years have oiling holes so he doesn't need to worry about it.
2011 Drag Pak Challenger
[Re: rickseeman]
#3031460
04/07/22 05:59 AM
04/07/22 05:59 AM
RATTRAP
N/E, Michigan
I'm still confused because Stage V doesn't make lifters. I'm assuming he's talking about Stage V rockers. So if that's the case, all the Stage V rockers made in the last 10 or 15 years have oiling holes so he doesn't need to worry about it. Yes Rockers My Mistake. And they do have the oil holes for the pushrods. ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
[Re: boomerodell]
#3031550
04/07/22 12:13 PM
04/07/22 12:13 PM
W.I.N. Racing
Byron, NY
The stage v rockers and adjusters I recently purchased from FHO have oil thru adjusters. manton PN 824-01 ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) In addition you need to make certain that the Lube hole in the rocker is above the top of the PR cup
[Re: W.I.N. Racing]
#3031561
04/07/22 12:51 PM
04/07/22 12:51 PM
RATTRAP
N/E, Michigan
The stage v rockers and adjusters I recently purchased from FHO have oil thru adjusters. manton PN 824-01 ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) In addition you need to make certain that the Lube hole in the rocker is above the top of the PR cup So why would you need oil thru adjuster's, if its shooting oil from the hole in the rocker onto the top of the pushrod?
[Re: RATTRAP]
#3031647
04/07/22 05:18 PM
04/07/22 05:18 PM
W.I.N. Racing
Byron, NY
The stage v rockers and adjusters I recently purchased from FHO have oil thru adjusters. manton PN 824-01 ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) In addition you need to make certain that the Lube hole in the rocker is above the top of the PR cup So why would you need oil thru adjuster's, if its shooting oil from the hole in the rocker onto the top of the pushrod? Added oil to the ball/cup interface. My seat pressure is 340 lbs and 650lbs open. Without the oil hole on the adjuster, Tuneup time and 10 passes blackened two cups and wore half of the adjusters. Replaced the adjusters only with the through hole and over 50 passes no issues starting the season with the same parts as last season.
[Re: boomerodell]
#3052869
06/24/22 06:02 AM
06/24/22 06:02 AM
RATTRAP
N/E, Michigan
The stage v rockers and adjusters I recently purchased from FHO have oil thru adjusters. manton PN 824-01 Thanks for the Suggested suppler and part#, I called Manton and was surprised on how knowable & helpful the People are there. After a brief conversation, We agreed that the part number you suggested would be the same one for my application. Also I was told that if there are any issues an exchange would not be a problem. Shipped within an hour after ordering! Kudos to Manton for their customer service. ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) Just wanted to add, That I tried my local Supplier First (TREND PERFORMANCE) The sales guy kept for some reason directing me to a cup style Adjuster, I insisted I wanted a Ball end, And was then told they are out of stock. So I ask what the lead time would be, And was told maybe January ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif)
