Re: Power steering tension bolt - anything under the head?
[Re: Montclaire]
#3031286
04/06/22 03:01 PM
04/06/22 03:01 PM
Posts: 19,388 north of coder
moparx
i always use a dab of loctite 567 teflon paste. that stuff is perfect for sealing almost everything that involves threaded fittings ! EXCEPT brake lines !
[Re: Montclaire]
#3031315
04/06/22 04:23 PM
04/06/22 04:23 PM
Posts: 75,004 U.S.S.A.
JohnRR
U.S.S.A.
Saginaw pump and bracket on a 440. For the lower bolt that locks the swing, do you use anything under the head? I did a quick search and didn’t see anything. Thanks Nothing is required , nothing is speced in the FSM ... as far as I know ...
[Re: Montclaire]
#3031453
04/07/22 12:49 AM
04/07/22 12:49 AM
Posts: 1,908 Nebraska
4406bbl
Nebraska
Saginaw pump and bracket on a 440. For the lower bolt that locks the swing, do you use anything under the head? I did a quick search and didn’t see anything. Thanks If you are talking about the adjuster bolt that sits on top of the adjusting slot it had a flat washer under the bolt head.
[Re: 4406bbl]
#3031917
04/08/22 05:03 PM
04/08/22 05:03 PM
Posts: 7,982 Scranton, PA
Montclaire
Scranton, PA
Saginaw pump and bracket on a 440. For the lower bolt that locks the swing, do you use anything under the head? I did a quick search and didn’t see anything. Thanks If you are talking about the adjuster bolt that sits on top of the adjusting slot it had a flat washer under the bolt head. That’s the one. I have an ARP flat washer, 3/8” id by 5/8” od, that should do the trick. Thanks
