Page 3 of 3 1 2 3
Re: Raising compression in a 400? [Re: MoparforLife] #303108
04/30/09 01:53 PM
04/30/09 01:53 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Rings just plain aren't going to make up for an out of round cylinder but do what you want. If you go with the tight clearance KB pistons be prepared for some piston slap too. If you are going to spend the money for new pistons do it right. For about 125 bucks you can have it bored and the pistons fit right.
Putting rings in this engine as is is just silly , the cylinder needs the proper hone finish to get the rings to seal, I don't think gapless rings come in plain cast iron as that's probably the only thing that will even remotely seal , plus now people are expecting him to breakdown the short block while it's still in the vehicle ?
Don , I wish I could get a V8 bored and honed for that cheap, around here is $300 ...
Train wreck , that's what this has been for me ....
Re: Raising compression in a 400? [Re: JohnRR] #303109
04/30/09 03:18 PM
04/30/09 03:18 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
John, I checked with the one that does a lot of the race engines around here and have been in the engine machining business for many years before I quoted the price. They do excellent work that they stand behind and also work with the people.
Re: Raising compression in a 400? [Re: MoparforLife] #303110
01/05/12 10:41 PM
01/05/12 10:41 PM
Johnstown
69dart Offline
69dart  Offline
Johnstown
Typically changing pistons will require the engine to balanced as well. Otherwise its going to shake itself apart. Also the factory head gaskets were .020 and felpros are typically .042 so milling .040 off the heads only nets a .020 gain.
I think your money would be better spent on a performer intake, carb and camshaft.
33 Plymouth Roadster - 383 - 5.90 1/8th 9.58 1/4
68 Dart - 340
66 Belvedere - 400
Windy Hollow Garage - https://www.youtube.com/@windyhollowgarage
Re: Raising compression in a 400? [Re: 69dart] #303111
01/06/12 11:14 AM
01/06/12 11:14 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Did you notice the date before dragging this CF back from the dead ?
2009 ...
Re: Raising compression in a 400? [Re: JohnRR] #303112
01/06/12 11:33 AM
01/06/12 11:33 AM
Sault Ste. Marie, Ontario, Can...
moparmike1 Offline
moparmike1  Offline
You use the "Lighten up Francis" ALMOST as much as you use the "Outside the box thing" Think up some new ones or crawl back under your rock PLEASE!!!!!!!
Do you actually have anything constructive to add , if not go back under your BRIDGE ... PLEASE ...
I really have to laugh at this, 'constructive to add'. Funny thing is, when I said the same thing your response was something along the lines of 'people not blowing sunshine and rainbows up your backside'.
Pot meet kettle x2.
This was an interesting thread that I didn't mind reading through. So what if someone brought it back from 2009? What's your point?
Mike.
Re: Raising compression in a 400? [Re: moparmike1] #303113
01/06/12 11:51 AM
01/06/12 11:51 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I see I have a new stalker ... yippee ...
add another to the LIST ...
Re: Raising compression in a 400? [Re: JohnRR] #303114
01/06/12 12:23 PM
01/06/12 12:23 PM
moparmike1 Offline
moparmike1  Offline
Thanks, that's an even bigger laugh!!
Keep trolling and adding to your 'list', you must just love the internet...
Mike.
Page 3 of 3 1 2 3
