Crank tight #3030724
04/04/22 09:07 PM
04/04/22 09:07 PM
Ct
W
Wirenut Offline OP
Wirenut  Offline OP
W
Ct
Hi all tried to search this before I posted .
Mega block , eagle crank that has just had the mains cut .010 . Machine shop checked clearance while they had the block and the crank. Said .0025 . Torqued the caps one at a time . #2 torqued to 100 stopped the crank from turning . All others ok , thrust sets fine .006 . Back #2 off to 50 ftlb and it turns. Planning on pulling the crank back out tomorrow night to check clearances myself. Anything I might be missing ?
Re: Crank tight [Re: Wirenut] #3030739
04/04/22 09:39 PM
04/04/22 09:39 PM
Pull all the main caps and check for run out on all 5 main bearing journals on the crankshaft scope twocents
if it is straight take the block with the crank in it loose back to the machine shop and show them your problem twocents
Been there, done that more than once with bad parts down whiney
Re: Crank tight [Re: Wirenut] #3030804
04/05/22 03:39 AM
04/05/22 03:39 AM
s. e. pa.
calrobb2000 Online content
calrobb2000  Online Content
s. e. pa.
might try a diff bearing , might have a defective one ?
look for dirt / chips also ?
try some bluing to find thr tight spot ?
Re: Crank tight [Re: calrobb2000] #3030806
04/05/22 04:55 AM
04/05/22 04:55 AM
Ct
W
Wirenut Offline OP
Wirenut  Offline OP
W
Ct
Thanks for the replies.
Checked run out before the crank was cut but not after , so will do . This is a freshen up after losing the thrust bearing . Only change is bearings and crank was cut .
Re: Crank tight [Re: Wirenut] #3030817
04/05/22 06:53 AM
04/05/22 06:53 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Cap is in the correct location? Not swapped or backward? Bearing isn't stamped for undersize? I know when mine spun the bearing and broke the rod, it bent the crank .010" when measured at #3 journal.
Doug
Re: Crank tight [Re: dvw] #3030819
04/05/22 07:18 AM
04/05/22 07:18 AM
Ct
W
Wirenut Offline OP
Wirenut  Offline OP
W
Ct
Doug
Caps are correct. The lower shell is stamped .010 but in all honesty I didn’t check the others. Will do .
Re: Crank tight [Re: Wirenut] #3030829
04/05/22 08:22 AM
04/05/22 08:22 AM
an8sec70cuda Offline
Swap the bearing from another journal and see if the problem is still there. Very well could be a bad bearing.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Crank tight [Re: an8sec70cuda] #3030831
04/05/22 08:29 AM
04/05/22 08:29 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
anymore i torque the main caps down without bearings and check the bore sizes with a dail bore gauge. sometimes the results will freak you out when you compare them against specs.
Re: Crank tight [Re: Wirenut] #3030836
04/05/22 09:06 AM
04/05/22 09:06 AM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
You need to check the line bore of the block. Easy to do if you have a round straight edge, just lay it in the bore and use a feeler gauge should not be able to slip a .001 under the straight edge.
Re: Crank tight [Re: jwb123] #3030893
04/05/22 12:14 PM
04/05/22 12:14 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I’d pull all the bearing shells out of the block except 1 and 5.
Then check for journal runout.
If the crank checked okay, then I’d remove the crank/bearings and torque up the caps and check main bore sizing with a dial
dial bore gauge.
Or you can pull everything out and do those checks in the reverse order.
Re: Crank tight [Re: fast68plymouth] #3030903
04/05/22 12:34 PM
04/05/22 12:34 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I have had better luck mixing King coated bearings in my builds over any Sealed Power/Federal Mogul or Clevite bearings. Not knocking any of the brands as I use all 3. King Bearings however have given me the clearance desired that I couldn't get out of the other at times.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Crank tight [Re: 6PKRTSE] #3030905
04/05/22 12:39 PM
04/05/22 12:39 PM
Ct
W
Wirenut Offline OP
Wirenut  Offline OP
W
Ct
Thank you for all the suggestions. Will play with it tonight if I have the energy.
Re: Crank tight [Re: Wirenut] #3033431
04/14/22 08:52 AM
04/14/22 08:52 AM
Ct
W
Wirenut Offline OP
Wirenut  Offline OP
W
Ct
So just some update and looking for thoughts before I bring it elsewhere .
Took block , crank and bearings to the shop that is helping with this. This is a small shop that an old friend runs that helps me out a bit with the race car. his abilities are limited , meaning he does not have line honing or line boring equipment .
checked crank runout and it is less than .001.
checked crank journals. 2.739
put my bearings and crank in another block , torqued down and turns fine.
measured clearances with bearings torqued down in my block and all are +.002 .
all of the main bores are the same size and exactly at spec . FYI the test block that all worked in is about .001 + over spec.
Had a set of lightly used bearings and put those in my block , and its tight but turns . These bearing were about 1/2 a thou thinner than my new kings .
My next move would be to bring it to a shop that has line boring equipment .
I think what I'm having a hard time with is why ?? This was a running engine that ate the thrust bearing . Had the crank thrust repaired , and consequently the main journals cut .010 . So why would I need to get the block modified ?
Could this block have had an issue that went unnoticed until the crank was cut and this made it show itself ?
In the past this motor was hard on bearings until I started using King standard x to get a little more clearance.
Thanks for looking
Re: Crank tight [Re: Wirenut] #3033433
04/14/22 08:56 AM
04/14/22 08:56 AM
I'd be narrowing it down to which bearing or bearings specifically were causing it to be tight. Then look for burrs on the caps or block.
Even a small burr will cause a problem.
CHIP
Re: Crank tight [Re: an8sec70cuda] #3033438
04/14/22 09:21 AM
04/14/22 09:21 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Heat cycling
Re: Crank tight [Re: an8sec70cuda] #3033500
04/14/22 12:06 PM
04/14/22 12:06 PM
Ct
W
Wirenut Offline OP
Wirenut  Offline OP
W
Ct
Any bearing or combination of bearings (the new kings) in the number 2 locks it up at full torque.
Even without any main caps except number 2 .
Re: Crank tight [Re: FastmOp] #3033501
04/14/22 12:07 PM
04/14/22 12:07 PM
Ct
W
Wirenut Offline OP
Wirenut  Offline OP
W
Ct
Originally Posted by FastmOp
Heat cycling
Hmm . It’s a 20 year old mega block . Hundreds of passes
Re: Crank tight [Re: Wirenut] #3033506
04/14/22 12:28 PM
04/14/22 12:28 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Bore gauge the torqued mains I bet you find out of round. A line hone will fix it up right. I had a 396 one time that the # 5 was almost .009 too wide at one position. You probably have a tight one.
Re: Crank tight [Re: B1MAXX] #3033525
04/14/22 01:39 PM
04/14/22 01:39 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Did you dial bore the individual Main bores without bearings? Either A; there are burrs in the #2 bearing bore B; the #2 bore is small or out of round. C; the #2 bore isn't in line with the other 4 bearing bores. Why? good question. Figure out if it's A, B , or C first. Your sure you are tang to tang on the bearings and the cap isn't marked wrong?
Doug
Re: Crank tight [Re: dvw] #3033613
04/14/22 04:47 PM
04/14/22 04:47 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
you mentioned "hard on bearings" most likely line bore is off
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
