Dana 60 in a Challenger R/T drive shaft length ??? #303057
04/29/09 03:41 PM
04/29/09 03:41 PM
Bel Air Maryland USA 21014
wmwalden Offline OP
wmwalden  Offline OP
I will be installing an ebody dana 60 in my 71 Challenger R/T.
The engine is in the stock location as well as the trans. The rear will be placed on the factory leaf spring pins. My question is ???
what should the drive shaft measure from center of u-joint to center of u-joint? I want the shaft in hand so the swap will only take a few hours.
Thanks Moparts
Bill
Re: Dana 60 in a Challenger R/T drive shaft length ??? [Re: wmwalden] #303058
04/29/09 03:46 PM
04/29/09 03:46 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
According to the 70-71 Parts Book.
44.60" ctr-ctr
Re: Dana 60 in a Challenger R/T drive shaft length ??? [Re: Snoopy] #303059
04/29/09 03:57 PM
04/29/09 03:57 PM
wmwalden Offline OP
wmwalden  Offline OP
Thank You
I love this place....
Re: Dana 60 in a Challenger R/T drive shaft length ??? [Re: wmwalden] #303060
04/29/09 04:55 PM
04/29/09 04:55 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
What trans?
Re: Dana 60 in a Challenger R/T drive shaft length ??? [Re: Challenger 1] #303061
04/29/09 05:49 PM
04/29/09 05:49 PM
BDW Offline
BDW  Offline
Re: Dana 60 in a Challenger R/T drive shaft length ??? [Re: BDW] #303062
04/29/09 06:01 PM
04/29/09 06:01 PM
Snoopy Offline
Snoopy  Offline
http://www.autohobbydigest.com/tables.php?17_driveshafts_slip_yoke
Many variables
How may variables do you see for a 71 Challenger with a 9 3/4" rear axle?
Re: Dana 60 in a Challenger R/T drive shaft length ??? [Re: Snoopy] #303063
04/29/09 07:02 PM
04/29/09 07:02 PM
Morris County NJ
Rustydog Offline
Rustydog  Offline
Morris County NJ
A Dana 60 in place of an 8-3/4 Requires that the driveshaft be shortened exactly One Inch.
Re: Dana 60 in a Challenger R/T drive shaft length ??? [Re: Snoopy] #303064
04/29/09 07:08 PM
04/29/09 07:08 PM
Cincinnati, Ohio
Cincinnati, Ohio
Many variables
Rustydog
Re: Dana 60 in a Challenger R/T drive shaft length ??? [Re: Snoopy] #303065
04/29/09 08:50 PM
04/29/09 08:50 PM
BDW Offline
BDW  Offline
He might have a SB, he didn't say.
Re: Dana 60 in a Challenger R/T drive shaft length ??? [Re: BDW] #303066
04/30/09 09:59 AM
04/30/09 09:59 AM
Morris County NJ
Rustydog Offline
Rustydog  Offline
Morris County NJ
Big Block or Small Block, It doesn't matter.
If the driveshaft for the 8-3/4 was correct then you switch to a Dana 60 the driveshaft will need to be shortened exactly One inch.
Re: Dana 60 in a Challenger R/T drive shaft length ??? [Re: Rustydog] #303067
04/30/09 03:57 PM
04/30/09 03:57 PM
wmwalden Offline OP
wmwalden  Offline OP
oops sorry guys. its a 512 with 727.
thank you
