Re: valve cover breather for 5.9 mag valve covers?
[Re: Sniper]
#3028652
03/29/22 11:57 AM
03/29/22 11:57 AM
Posts: 667 Los Osos, Ca
CKessel
Los Osos, Ca
For sure not running a valve can be detrimental. Something for you to check on. Some of the later than 2000's, 4.0 Jeeps and some others didn't use a valve but had a metered orifice in the hardline going into the throttle body or manifold. Think of a carb jet in the line. Called it the CCV system if I remember correctly. You need something along that line to extract the gasses that collect in the crankcase and run them through. Keeps the engine clean on the inside, keeps oil cleaner etc.
Carl Kessel
[Re: CKessel]
#3028671
03/29/22 01:02 PM
03/29/22 01:02 PM
Posts: 3,054 N.W. Florida
Fat_Mike
N.W. Florida
I'll (hopefully) attach photos of my 2001, driver and passenger sides. The passenger side "PCV" is merely a hollow elbow, and the rubber hose is just a rubber hose; no valve in there. Hope this helps.
[Re: Andrewh]
#3028683
03/29/22 01:23 PM
03/29/22 01:23 PM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
I run a PCV valve on my stroked 5.9 Magnum, and run the hose from it through a traditional compressed air water trap and then into the intake manifold. It sure does fill the trap up quickly when doing short trips during the winter.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: Andrewh]
#3028812
03/29/22 08:14 PM
03/29/22 08:14 PM
Guitar Jones
Are you still running the stock intake? If so the plenum gasket may be leaking.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
