Page 3 of 3 1 2 3
Re: New 3.0L Inline 6 from Chrysler, 500hp [Re: hemi70se] #3029584
04/01/22 03:25 PM
04/01/22 03:25 PM
Benton, IL.
DaveRS23 Online rolleyes
Special needs idiot
DaveRS23  Online Rolleyes
Special needs idiot
Benton, IL.
Originally Posted by hemi70se
I've had this idea for years now... with all the technology that has gone into modern engines why can't they design a NEW engine that has computer controlled solenoids to open the valves. This could eliminate the camshaft, timing gears and timing chains which are frequent cause of needed engine wear repairs/ failures.
It has already been tried: Koenigsegg Freevalve camless engine
www.youtube.com/watch?v=S3cFfM3r510
www.youtube.com/watch?v=tAqP7o_ZdK0
www.youtube.com/watch?v=Qjtvp0lUTdk
Master, again and still
Re: New 3.0L Inline 6 from Chrysler, 500hp [Re: DaveRS23] #3029587
04/01/22 03:35 PM
04/01/22 03:35 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
And BMW had system that varied valve lift to do the work of throttle bodies.
- Stu Harmon
Re: New 3.0L Inline 6 from Chrysler, 500hp [Re: feets] #3029687
04/01/22 05:49 PM
04/01/22 05:49 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
GM also has a variable lift system. Camless engines may very well go mainstream. As mentioned Koenigsegg has been playing with them for some time. I believe he was using pneumatic solenoid to open valves and springs to close them. Electric solenoids to open them against spring pressure would likely require more voltage than 12 volts so I can see them in some kind of Hybrid where high voltage is readily available. Infineatly adjustable valve timing with no valvetrain......talk about broad torque curves and big RPM!!! eek
Re: New 3.0L Inline 6 from Chrysler, 500hp [Re: Dcuda69] #3029696
04/01/22 06:09 PM
04/01/22 06:09 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I think the Konesigg uses air to close and solenoid to open but I could be wong.
Re: New 3.0L Inline 6 from Chrysler, 500hp [Re: HotRodDave] #3029807
04/01/22 11:07 PM
04/01/22 11:07 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
A good read:
https://www.topgear.com/car-news/fu...segg-gemeras-600bhp-camless-engine-works
Re: New 3.0L Inline 6 from Chrysler, 500hp [Re: Dcuda69] #3029851
04/02/22 06:45 AM
04/02/22 06:45 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
That Freevalve setup from Koensisengigin or whatever is pretty amazing. It's amazing all the possibilities that limitless valve activation can do.
68 Barracuda Formula S 340
Re: New 3.0L Inline 6 from Chrysler, 500hp [Re: feets] #3029855
04/02/22 07:17 AM
04/02/22 07:17 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
A question that has been endlessly debated in internet forums is:
should the gasoline engine throttle be mostly closed (high vacuum)
or mostly open ( low vacuum)
for best fuel economy?
The (complicated) answer is:
there should be no throttle and the intake valve movements should adjust cylinder filling to suit load.
It should be more discussed that:
a particular type of engine used to have no throttle (diesel)
and thanks to the EPA
most new diesels now have throttles
and diesel fuel economy has gone down
putting more CO2 out into the atmosphere
( and slightly less NOx)
Re: New 3.0L Inline 6 from Chrysler, 500hp [Re: 360view] #3029913
04/02/22 09:56 AM
04/02/22 09:56 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
I don't think it really matters to most if not all manufactures because the most important goal is to meet the emissions regulation using the FTP (EPA/CARB Federal Test Procedure) which the CAFE fuel economy results are derived from. They have to meet the FTP emissions reg and cannot put "ringers" into a fuel economy test that would be "tuned" for best MPG and then peg the NOX or HC or any other pollutant that's why the CAFE results are from the manufacture's FTP certification results. And all of the certification data is "Public Record" for EVERYONE to see at any time including all of the other manufactures, greenies and just plain you and me. Here's all of the information down to axle ratios, weight HC and everything else:
2022 EPA FTP and CAFE emissions and fuel economy results
And here from 2022 all the way back to 1984 (ironically the year of "Big Brother" laugh2 ) https://www.epa.gov/compliance-and-fuel-economy-data/data-cars-used-testing-fuel-economy
Re: New 3.0L Inline 6 from Chrysler, 500hp [Re: A12] #3029944
04/02/22 12:05 PM
04/02/22 12:05 PM
USA
3
360view Offline
360view  Offline
3
USA
I agree reading the actual EPA results can be interesting.
Years ago I used to eat breakfast at a coffee shop near the EPA lab complex in Research Triangle Park NC
(thank you Senator Jesse Helms)
I met a lot of EPA engineers and perhaps even more employees at Contractors to the EPA.
At least half of these people were “gearheads” and not radicals.
They showed me how to get EPA database test results,
and at least twice alerted me that the EPA had set up equipment in nearby parking lots where the public was allowed to have their vehicles (confidentially) tested.
I have written here on Moparts that the research paper (1998?) where they converted a I4 VW diesel in house
to sparkplugs and port fuel injection (Holley injectors atomized best)
to run on alcohols at the same compression ratio
was one of the most interesting I have ever read.
The EPA employee authors compared the thermal efficiency of the fuels at the same compression ratio,
and also played around with using varying EGR amounts to control power output.
I miss that coffee shop.
Re: New 3.0L Inline 6 from Chrysler, 500hp [Re: 360view] #3029947
04/02/22 12:16 PM
04/02/22 12:16 PM
NotRussia
2
2fast4yourBrain Offline
Whack top Dodger
Whack top Dodger
2
NotRussia
At least they're still offering an ICE engine.
I'm quite surprised they are, given the push for EVs.
I like it, and I'm sure you'll be able to hot rod this with bigger turbo(s)/boost.
Re: New 3.0L Inline 6 from Chrysler, 500hp [Re: 2fast4yourBrain] #3030115
04/02/22 11:28 PM
04/02/22 11:28 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Just because they can make it so that it's modular with the four cylinder, doesn't mean I want one. I'll take a Hemi any day. Doesn't look like I'll be buying any new trucks in the future.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: New 3.0L Inline 6 from Chrysler, 500hp [Re: 360view] #3030164
04/03/22 08:56 AM
04/03/22 08:56 AM
USA
3
360view Offline
360view  Offline
3
USA
The IC Engines of our future may be on
the small trailers we tow behind our battery electric trucks to give them useful range?
If that is the sad future
a tiny multi-fuel high horsepower I6
connected to an inverter type electric generator
that can output multiple voltages and phases (including aircraft style 400 Hertz 3 phase )
can be thought of as an advance
The FSM for such an I6 will probably be 8000 pages long.
Set it by the toilet and read 8 pages a sitting.
Chandler Six
are you ashamed of your great grandchildren?
Page 3 of 3 1 2 3
