Who's Lifters
#3029284
03/31/22 05:25 PM
03/31/22 05:25 PM
Posts: 5,762 Hot Rod Ridge
FastmOp
Hot Rod Ridge
Putting Ka-Blue-E back together one last time as a wedge. Trying to have a fresh bullet but lifters need replaced. I finally spread the comp lifters after years of great service. Thumbs up Comp lifters I'm looking for longevity. The Comp lifters laster 6 years lol not bad for a hot rod. Standard lifter hole I guess. Indy block. Prefer to keep the pushrod location the same as the Comps but I prolly need to upgrade pushrods as well lol.
Re: Who's Lifters
[Re: dvw]
#3029492
04/01/22 11:51 AM
04/01/22 11:51 AM
Posts: 1,127 Loudoun County, VA
Brad_Haak
Loudoun County, VA
BAM Pro series w/ offset intake pushrod on right; older IMM-branded lifters made by same company in MI that made (makes?) some of COMP's lifters on left. BAM bodies measured consistently around .9038" IIRC, which was almost .005" wider than the other lifters.
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Who's Lifters
[Re: Brad_Haak]
#3029494
04/01/22 11:52 AM
04/01/22 11:52 AM
Brad_Haak
Loudoun County, VA
Re: Who's Lifters
[Re: FastmOp]
#3029497
04/01/22 11:57 AM
04/01/22 11:57 AM
Posts: 43,174 Bend,OR USA
Cab_Burge
I like and use Crower Ultra in my wedge race motors without pushrod oiling : scope: 619-661-6477
Re: Who's Lifters
[Re: Brad_Haak]
#3029498
04/01/22 11:58 AM
04/01/22 11:58 AM
Posts: 2,917 A shed in England
Tig
A shed in England
BAM Pro series w/ offset intake pushrod on right; older IMM-branded lifters made by same company in MI that made (makes?) some of COMP's lifters on left. BAM bodies measured consistently around .9038" IIRC, which was almost .005" wider than the other lifters. Just for info, you may find you can't fit those BAM lifters in a KB block, Indy block or an early Megablock as (IIRC) they have much taller lifter bosses than stock.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
Re: Who's Lifters
[Re: Brad_Haak]
#3030233
04/03/22 01:05 PM
04/03/22 01:05 PM
Posts: 14,498 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Brad, do you have a dimension for the BAM lifters from the bottom of the wheel to the bottom of the tie bar?
The Comps are: 829-16 = 2.560” 87019-16= 2.780”
I have used 829’s in Indy, MP/World, and Megablock, and of course stock blocks. I’ve only used the 87019’s in a World aluminum block.
Re: Who's Lifters
[Re: fast68plymouth]
#3030322
04/03/22 04:35 PM
04/03/22 04:35 PM
Brad_Haak
Loudoun County, VA
Unfortunately, no other measurements and the engine's buttoned up.
I can provide a few pics showing how they sit in an OEM RB block w/ bushed lifter bores, FWIW
Re: Who's Lifters
[Re: Brad_Haak]
#3030324
04/03/22 04:35 PM
04/03/22 04:35 PM
Brad_Haak
Loudoun County, VA
