Re: sonic cleaner
[Re: sogtx]
#3028896
03/30/22 07:59 AM
03/30/22 07:59 AM
Posts: 6,252 nowhere
Sniper
nowhere
I have one, nice and large. I cleaned several parts with it, including a complete, but disassembled carb. Heat and time are important, I think I had it going for 4 hours or so. I used Simple Green. Not quick, but it worked great for me. You can see the before and after pictures here http://www.yourolddad.com/carb-rebuild
Re: sonic cleaner
[Re: sixpakdodge]
#3029001
03/30/22 02:37 PM
03/30/22 02:37 PM
Posts: 21,508 N.E. OHIO, USA
A12
N.E. OHIO, USA
I use a Harbor Freight sonic cleaner with Evaporust for cleaning steel stuff. Sometimes it takes a couple cycles, but the stuff comes out looking like brand new. The HF ultrasonic cleaner is a little too small IMO for some of the things automotive and even motorcycle. Had one at a place where I was doing Stihl and other small engine repair and service and couldn't fit some cylinders and other components into it. Plus it was plastic and because it got almost daily use it only lasted about 14 month and quit. Replaced it with an Amazon sourced stainless 6 liter version for only about $60 bucks more than the HF. Don't get me wrong the Harbor Freight worked really well and is a great bargain for the $89 price but it turned out to be a little too small and the reliability or lack of was only due to the fact that it was being used as a daily overworked commercial applications. For home use and small items I would bet it would still be working today. If you're going to try and fit a 4-barrel carb into one you're going to need a much larger ultrasonic tank for that.
Re: sonic cleaner
[Re: A12]
#3029010
03/30/22 03:10 PM
03/30/22 03:10 PM
Posts: 4,101 Yes
sixpakdodge
Yes
I use a Harbor Freight sonic cleaner with Evaporust for cleaning steel stuff. Sometimes it takes a couple cycles, but the stuff comes out looking like brand new. The HF ultrasonic cleaner is a little too small IMO for some of the things automotive and even motorcycle. Had one at a place where I was doing Stihl and other small engine repair and service and couldn't fit some cylinders and other components into it. Plus it was plastic and because it got almost daily use it only lasted about 14 month and quit. Replaced it with an Amazon sourced stainless 6 liter version for only about $60 bucks more than the HF. Don't get me wrong the Harbor Freight worked really well and is a great bargain for the $89 price but it turned out to be a little too small and the reliability or lack of was only due to the fact that it was being used as a daily overworked commercial applications. For home use and small items I would bet it would still be working today. If you're going to try and fit a 4-barrel carb into one you're going to need a much larger ultrasonic tank for that. I fit the last AVS I rebuilt in halves in the Harbor Freight cleaner. (IE, Top, bottom halves, after taken apart.)
Re: sonic cleaner
[Re: A12]
#3029021
03/30/22 04:14 PM
03/30/22 04:14 PM
Posts: 1,825 South Bend
John Brown
South Bend
Be sure your life insurance is paid up if you're using non approved liquids in a sonic cleaner..... Are you talking about flammable liquids or toxic liquids? Specifically ones that break down and make toxic gasses. While not as readily available as it once was, Carbon Tetrachloride is what first came to mind. College chemistry classes taught that heated Carbon Tetrachloride was one that could break down and possibly form Phosgene Gas and Hydrogen Chloride. Cavitation bubbles in a sonic cleaner may increase the possibility. It's best to check whether the liquid is safe before using it.
Re: sonic cleaner
[Re: Cuda340]
#3030118
04/02/22 11:43 PM
04/02/22 11:43 PM
Posts: 7,490 Minnesota
Hemi_Joel
Minnesota
I bought one off of eBay several years ago. The interior is about 10 in by 14 in by about 10 in deep. I have found that it works really well for lots of stuff. I'm considering buying another one that is larger. I use simple green in it most of the time. Sometimes mixed with water. If I am going to clean something that's really greasy, or really oily and I don't want to contaminate all the cleaner in there that fast, I'll put the really yucky stuff in a ziplock baggie, or a plastic coffee can, put just enough cleaning liquid in with it, and then throw that in the ultrasonic. That way I limit the amount of solution that gets really dirty. I like going to swap meets and buying a pile of quality old hand tools like wrenches and sockets and stuff that are cheap because they are all super grimy and yucky looking. Then throw them in the ultrasonic and they come out looking like new. It has an electronic timer that only goes up to 30 minutes. A lot of times it takes a couple of hours to get something that's really dirty clean. So I have to keep resetting it. But it's true, stuff comes out looking like brand new.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
Re: sonic cleaner
[Re: 360view]
#3030608
04/04/22 02:50 PM
04/04/22 02:50 PM
Posts: 4,270 Morrow, OH
markz528
Morrow, OH
I have a 30 gallon. Big enough to do heads. Works great if you understand what it can and cannot do. As stated, must be hot. I target 150 degrees F. One of the biggest issues I have is that it is so strong it will destroy paint if I don't turn it way down. You have to learn its limitations.
Had a HF one. Worthless compared to a real ultrasonic cleaner.
