68---69 IGNITION SWITCH #3028435
03/28/22 06:18 PM
03/28/22 06:18 PM
WV
JohnH Offline OP
JohnH  Offline OP
WV
Is the ignition switch on a 68 Charger shorter than a 69 Charger?? If so why the difference.... Thanks!!
Re: 68---69 IGNITION SWITCH [Re: JohnH] #3028470
03/28/22 08:05 PM
03/28/22 08:05 PM
massachusetts U.S.A.
1969ronnie Offline
1969ronnie  Offline
wave Hi John , 1968 and older to 1960 ignition switches are the same . 1969 is ALL on its own . a 1970 on up are starting on the column . easy to just google pictures to see the big difference from a 1968 to a 1969 switch . drive Ronnie
Re: 68---69 IGNITION SWITCH [Re: 1969ronnie] #3028476
03/28/22 08:16 PM
03/28/22 08:16 PM
WV
JohnH Offline OP
JohnH  Offline OP
WV
thanks for info
