Late-B Stable Key-On 12v? #3027886
03/26/22 08:33 PM
03/26/22 08:33 PM
here.
Remy-Z Online confused OP
Remy-Z  Online Confused OP
here.
Car: 1976 Charger Daytona, 360ci.
Issue: I have an electric in-tank fuel pump instead of the engine-driven pump assembly...prep for an eventual engine swap to a Magnum 360 on Holley Terminator X. When running, this pump is more than enough for a stock 360 (350 LPH). The problem is just that...when it is running. I'm finding that this pump cuts in and out at random times. It has been very difficult to diagnose. The pump has a power wire from Battery Positive and is grounded at both the front passenger fender ground and at one of the two fuel fill tube bolts inside of the trunk. I'm suspecting key-on 12v power is my issue. Right now, that is sourced from the electric choke connector (CE 14 per the book) because that was the only actual point of key-on 12v power I could locate. When the car is colder and as long as it doesn't drive too far or too hard, it's fine. But drive it hard, or try to take a roadtrip and eventually the car will choke out like the alternator died and the battery went flat. Let it sit a few minutes, it'll start up and move.
In preparation of the new engine, trans and ECU, I'm looking to see if there's a better key-on 12V source under the hood I can use instead of the choke's power supply. I was looking at the starter relay for a minute, but I only see 12v hot at the top terminal, 12V to solenoid for cranking and 12v ignition. I do not want to put a hard-mounted switch into this car. Am I missing any other key-on 12v sources?
Re: Late-B Stable Key-On 12v? [Re: Remy-Z] #3027906
03/26/22 09:21 PM
03/26/22 09:21 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Issue:...when it is running. I'm finding that this pump cuts in and out at random times. It has been very difficult to diagnose. The pump has a power wire from Battery Positive and is grounded at both the front passenger fender ground and at one of the two fuel fill tube bolts inside of the trunk.
The above is confusing as you are identifying two different 12v sources confused
Are you using a relay with the electric choke as a signal wire to "activate" the relay? If i am not mistaken the choke power is run through a timer or sensor to control it's temperature. might be wrong on that but I remember something to that effect with the choke on the mid to late 70's cars. If that's the case you may be on the wrong side of the controller. Regardless, A better source may be the IGN power TO the ballast resistor with a relay and fused battery lead beer
Re: Late-B Stable Key-On 12v? [Re: Remy-Z] #3027918
03/26/22 10:07 PM
03/26/22 10:07 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Wire it up and fuse and protect dedicated circuits. The under hood circuit you chose will draw very little to activate it,
Re: Late-B Stable Key-On 12v? [Re: NITROUSN] #3028104
03/27/22 04:40 PM
03/27/22 04:40 PM
S.E.Ohio
Magnumguy Offline
Magnumguy  Offline
S.E.Ohio
I think you using the chock power is timed. It may not be constant, nor 12V.
Maybe tie into the bulkhead connector for the ignition? I'm a wiring ignoramous so I'm just guessing as what I'd do. Maybe ballast resistor feed wire? That should be 12V too?
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: Late-B Stable Key-On 12v? [Re: Magnumguy] #3028105
03/27/22 04:42 PM
03/27/22 04:42 PM
N
NITROUSN Offline
NITROUSN  Offline
N
He can use the 12 volt choke feed to activate a properly wired relay.
Re: Late-B Stable Key-On 12v? [Re: NITROUSN] #3028161
03/27/22 08:45 PM
03/27/22 08:45 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Agreed, which is why I stated
Quote
beer
but good to reiterate incase he missed that part beer
Re: Late-B Stable Key-On 12v? [Re: TJP] #3028192
03/27/22 10:44 PM
03/27/22 10:44 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Quote
beer
To many possibilities. It is either it is or it is not. Could be a tank full of crap choking off the pumps suction. Who knows.
Re: Late-B Stable Key-On 12v? [Re: NITROUSN] #3028300
03/28/22 10:58 AM
03/28/22 10:58 AM
here.
here.
That can be ruled out. The tank was dropped, emptied, flushed and prepared when the electric fuel pump went in.
Re: Late-B Stable Key-On 12v? [Re: TJP] #3028301
03/28/22 11:02 AM
03/28/22 11:02 AM
here.
here.
Fair enough. Let's see if I can make it clearer:
*12v hot from battery positive to relay
*12v key-on signal from the choke's power-feed wire to relay
*Relay ground to passenger fender ground point
*Relay's 12v hot wire to pump positive
*Pump ground to trunk interior, grounded at bolt that holds fuel tank fill pump tube
Re: Late-B Stable Key-On 12v? [Re: Remy-Z] #3028307
03/28/22 11:20 AM
03/28/22 11:20 AM
N
NITROUSN Offline
NITROUSN  Offline
N
You Should have a pod in the tank to prevent cavitation. Keeping it over 1/2 should eliminate that possibility. Where exactly are you hooked on at the choke? You could make up a simple light at the tank and run it somewhere visible in the car to monitor power. When it acts up if the light goes out its a power supply. If it stays on its the pump.
Re: Late-B Stable Key-On 12v? [Re: NITROUSN] #3028341
03/28/22 12:36 PM
03/28/22 12:36 PM
here.
here.
The tank has been topped off during testing. The fuel gauge is about as accurate as a blind, drunk man throwing a dart. On a stock 2-bbl 360, there's a blue wire that feeds power to what I can best describe as a circuit board that transfers power to the choke's element. I'm tapped into that power supply coming from the main engine harness, before the power gets to the choke's "circuit board". I'll add a picture later this evening if needed.
Re: Late-B Stable Key-On 12v? [Re: NITROUSN] #3028345
03/28/22 12:51 PM
03/28/22 12:51 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
up great idea wink Anybody wanna take bets ??? beer
Re: Late-B Stable Key-On 12v? [Re: TJP] #3028366
03/28/22 01:41 PM
03/28/22 01:41 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
there is a field load relay under rt fender for alternator, it has a key on 12v source
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: Late-B Stable Key-On 12v? [Re: Remy-Z] #3028427
03/28/22 05:57 PM
03/28/22 05:57 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Back when I put Holley Projection on Warhammer I did what you are doing, hung an electric pump on the end of the pickup.
Now the factory did that to feed a carb and deal with vapor lock issues, but with fuel injection it doesn't work well. As someone mentioned, at half a tank it'd suck air as the fuel sloshed away and it'd kill the engine when I made a spirited turn. The lower the fuel level got the more it appeared. Now I know you said the tank is full and probably isn't the issue, but I went thru a couple of burned out pumps dealing with this. If you get it on the road you might want to put in a hydramat on the end of the pump, at least. I ended up going with a fuel sump fed by the mechanical pump, that in turn fed the electric pump. Something to keep in mind is all.
As for you original question, use the ballast feed (12v side) to trigger your pump relay. Since if that is flaky your ignition would turn off too and it doesn't sound like your having an ignition issue.
Re: Late-B Stable Key-On 12v? [Re: Sniper] #3028638
03/29/22 11:19 AM
03/29/22 11:19 AM
here.
here.
There is a Hydramat on the end of that pump assembly. Wasn't going to pass up the opportunity to score one of those. This engine hasn't made a "spirited" run yet in my hands...nothing wilder than a 70mph Interstate cruise. Turns out I'm chasing a voltage regulation issue. I've seen the battery terminal reading as high as 17.1 volts at idle with lights on. New alternator is in, picking up new voltage regulator today.
Re: Late-B Stable Key-On 12v? [Re: Remy-Z] #3028834
03/29/22 09:26 PM
03/29/22 09:26 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
voltage too high can be as bad as voltage too low. Some items get flaky in operation when the voltages exceed it's expectations.
Re: Late-B Stable Key-On 12v? [Re: Remy-Z] #3028949
03/30/22 11:17 AM
03/30/22 11:17 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Once you get you voltage problem corrected you should recheck you fuel pressure settings wink
