dodge B300 mpg
#302823
04/29/09 09:24 AM
04/29/09 09:24 AM
Posts: 149 switzerland
denizch
switzerland
okay i have a dodge B300 van with a 318 in it with has a 2barrel carb that needs a rebuild . my goal is get the best mpg as possible and may a little bit more power from my van . Now i wonder whit which car and cam i should go to reach my goal , i thought about a 500cfm edelbrock carb but have no idea which cam would be the best for me , or should i even stay with my 2 barrel carb and just change my cam and rebuild the old carb? if i go with 4 barell i would go with a edelbrock intake for low rpms. What do you would do in my case?
a hi from switzerland
Re: dodge B300 mpg
[Re: denizch]
#302824
04/29/09 09:43 AM
04/29/09 09:43 AM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
Lock up 727 or overdrive.
SP2P Eddie intake, or Offy Dual Port, stock iron spreadbore intake, Eddie Performer.
Summit RV grind, I have a 252H-10 Comp cam in my B200 with an Offy DP.
Thermoquad or Mopar Quadrajet carb.
Flat top pistons. 302 heads with a MPG R/V type port and polish job.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: dodge B300 mpg
[Re: Rug_Trucker]
#302825
04/29/09 10:38 AM
04/29/09 10:38 AM
denizch
switzerland
i dont know which tranny i have , i guess it is a regular 727 3 speed no overdrive or lockup. the heads i like to leave stock, i am more concerned if i shoud stay with the two barrel or if a 4 barrel is better for mpg?
Re: dodge B300 mpg
[Re: Rug_Trucker]
#302826
04/29/09 10:47 AM
04/29/09 10:47 AM
Posts: 12,481 Chino Valley
RodStRace
Chino Valley
That must be some sight in Switzerland! I won't say the smarty stuff like chop and channel. Build a good tight engine that performs well in the RPM range you use the van in. Do all the other usual stuff, like air up the tires, keep the weight down (remove unneeded stuff inside), and get it aligned. There was an article many years ago where they did wind testing of a van using different aftermarket parts. Front spoiler, side skirts, rake (lowered front), rear spoiler and rear wing (the kind that diverts air on to the back windows). IIRC, the best was a level ride height and the front spoiler. The side skirts were a wash, unless they extended so far down they were unsuitable on the street, and anything on the rear made it worse.
Re: dodge B300 mpg
[Re: RodStRace]
#302827
04/29/09 10:59 AM
04/29/09 10:59 AM
denizch
switzerland
i dont plan any changes i only like to get a bit better mpg via carb , cam or/and intake
Re: dodge B300 mpg
[Re: Rug_Trucker]
#302830
04/29/09 07:14 PM
04/29/09 07:14 PM
Posts: 9,065 Milwaukee, WI
In_The_Pink
Milwaukee, WI
A small (600cfm or less) 4-bbl and 4-bbl intake manifold will give you slighty better mpg than a 2-bbl, all else being equal. As suggested, use a mild cam which gives good torque in your desired rpm range, and a low restriction exhaust system is also a good idea. Please see my signature line for the link to the Mopar B-van forum, too. ![](/ubbthreads/images/graemlins/thumbs.gif)
Re: dodge B300 mpg
[Re: buildanother]
#302831
04/29/09 08:56 PM
04/29/09 08:56 PM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
A 300 van will have some heavy duty axles-hubs suspension etc, I don't know if it will ever get good mpg, only decent highway mpg maybe. And I have never found improvement on mpg going from the tiny 2 bbl to a 4 bbl. I'd rebuild the carb, check timing etc and see how it does.
![](/ubbthreads/images/graemlins/iagree.gif) The biggest factors in fuel economy are vehicle weight, and driving habbits.
Tune it the best you can, and drive it gently. Cams and manifolds will only cost you money, and likely make no change in mpg.
The only other thing I would consider on a van, is trying to fab up a cold air intake tube. Under hood temps are terrible on vans. If you can get the air from in front of the radiator, you will see an improvement. I used CAC(cold air charge tubes) from a ford super duty diesel, to go over the rad on my 440 winnibago.(dual snorkel)
