Re: Acceptable Gear Pattern?
[Re: Tim B]
#3027327
03/25/22 10:23 AM
03/25/22 10:23 AM
Posts: 149 Albert Lea, MN
GTX5877
Albert Lea, MN
IMHO, I would try a .033-.035 shim. The drive side could be closer to the 'toe' on the drive side, which should bring your coast side more towards the middle of the tooth.
1967 Dart GTS 426 Gen III Hemi 1968 Hemi Cuda 572 SS/AH Clone 1988 Chrysler LeBaron Coupe S/S 2003 Dodge Ram 1500 4dr SLT lowered 2012 Ram 1500 2wd Lowered 1970-1/2 Camaro Z-28 1974 VW Karman-Ghia
[Re: fourgearsavoy]
#3028808
03/29/22 07:58 PM
03/29/22 07:58 PM
Posts: 7 Auburn, PA
Tim B
Auburn, PA
Okay, got it all buttoned up. About 18-19 in/lbs pinion turning torque.
Does 29-30 in/lb turning torque with the center section fully assembled sound right? I'm right at .006-.007" backlash.
[Re: Tim B]
#3028845
03/29/22 09:45 PM
03/29/22 09:45 PM
Posts: 10,559 Rittman Ohio
fourgearsavoy
Rittman Ohio
Does 29-30 in/lb turning torque with the center section fully assembled sound right? I'm right at .006-.007" preload. Sounds about right for a 742 case but a 489 should have a little less pre load than that. I'm not sure why though Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
