1978 440 Won't Run #3024786
03/17/22 09:19 AM
03/17/22 09:19 AM
Newark Valley, NY
jim6346 Offline OP
jim6346  Offline OP
Newark Valley, NY
Good Morning,
I have a 1978 440 out of a motorhome that I put in my Challenger. It will not start, just backfires once in a while
up through the carb. Engine did sit in a garage for a few years before I installed it. Ran the oil pump for about
15 minutes with a drill, seemed to have good oil pressure. Has what appears to be maybe a weak spark (put one
of those cheap inline test lights with the #1 plug).
Here are some things I have done:
Replaced the ECU, twice. Verified it is grounded. I am using an original NOS unit for a 73 Mopar.
Replaced the Dual Ballast Resistor, twice
Upgraded the coil to an Accel, then MSD Blaster
Replaced the Distributor
Verified all wiring.
Set timing to 10 BTDC without vacuum advance
At this point I am stumped.
Any help would be greatly appreciated
Thanks,
Re: 1978 440 Won't Run [Re: jim6346] #3024791
03/17/22 09:40 AM
03/17/22 09:40 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Quote
Ii either has good spark or it dose not. Should have a nice blue arc out of a plug wire 3/8 of an inch. If so verify compression, verify the distributor is at TDC compression stroke.
Re: 1978 440 Won't Run [Re: jim6346] #3024795
03/17/22 09:59 AM
03/17/22 09:59 AM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
You know the drill, compression, fuel, spark, timing, valves that aren't stuck, pushrods in place and not bent... I'd would probably run a hot wire from the battery to pos coil to see if the spark improves. You seem to have covered everything else sparkwise.
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: 1978 440 Won't Run [Re: jim6346] #3024802
03/17/22 10:27 AM
03/17/22 10:27 AM
Wills Point, Texas
Hugh Jorgan Online work
Hugh Jorgan  Online Work
Wills Point, Texas
Might have jumped a tooth on the timing chain? Nylon tipped gear. shruggy
Re: 1978 440 Won't Run [Re: Hugh Jorgan] #3024804
03/17/22 10:30 AM
03/17/22 10:30 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Dist. 180 out?
Joe
Re: 1978 440 Won't Run [Re: jlatessa] #3024885
03/17/22 02:04 PM
03/17/22 02:04 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Originally Posted by jlatessa
Dist. 180 out?
Joe
This
Re: 1978 440 Won't Run [Re: JohnRR] #3024890
03/17/22 02:23 PM
03/17/22 02:23 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Knowing I’d tdc is really tdc would be good. Worth a check.
Easy thing at this point would be to bar it over to tdc indicated, then pull distributor. Look at drove slot in the gear. Should be parallel to the crank, or in other words straight across. If it’s close but slightly off, by not much with the timing mark right on tdc, you are 180 out. Roll engine over again to the tdc mark and it should be straight across now. Then reinstall distributor and make sure your rotor is close to number 1, also great time to check firing order.
If you put can’t picture how the gear will look, this will make more sense once you see it both ways, tdc and 180 out.
I want my fair share
Re: 1978 440 Won't Run [Re: SomeCarGuy] #3024891
03/17/22 02:25 PM
03/17/22 02:25 PM
Newark Valley, NY
jim6346 Offline OP
jim6346  Offline OP
Newark Valley, NY
jlatessa called it, distributor 180 out, ugghhhh. I checked it like 3 times, never fails.
Runs smooth as hell now.
Thanks Everyone!!
jim
Re: 1978 440 Won't Run [Re: jim6346] #3024938
03/17/22 05:24 PM
03/17/22 05:24 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Just heads up. when you line the dots up on the timing markers, its on the exhaust tdc. So if we bring the dots together, piston at tdc. and put the dist. in, its 180 out.
Re: 1978 440 Won't Run [Re: JohnRR] #3024979
03/17/22 07:52 PM
03/17/22 07:52 PM
Chicago
PurpleBeeper Offline
Chicago
Dist. 180 out?
Joe
This
Yep & Yep.......OR the ever popular......firing order of plug wires are correct on the cap....but not COUNTER-clockwise like a big block. Ask me how I know this stuff? It's because I make a lot of mistakes and remember stuff smile One more tip...IF you are indeed "180 out" and you have at least a little slack on all your plug wires, then the easiest way is to move the #1 wire at the cap straight across to the other side of the cap & then move all the other wires appropriately, following the fire order, counter-clockwise. On the other hand, if you don't have any slack, you can also remove the distributor hold down, move cap/wires out of the way, lift up distributor 1", turn rotor 180-degrees, drop distributor back straight down....etc.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: 1978 440 Won't Run [Re: PurpleBeeper] #3025032
03/17/22 11:12 PM
03/17/22 11:12 PM
Keizer, Oregon U.S.A.
E
elmor353 Offline
elmor353  Offline
E
I have a 78 440 out of a motor home in my pickup. I had the same problem. There are 3 grooves in my harmonic balancer, thought I marked the right one. Couldn't get the damn thing to run. Finally pulled number one spark plug, brought it up on compression stroke and low and behold, I marked the wrong groove. Checked the distributor and it was way off. Set the distributor so the rotor was pointing at number one and it fired right off. It's the simple things that screw most of us up.
Re: 1978 440 Won't Run [Re: elmor353] #3025738
03/20/22 02:00 PM
03/20/22 02:00 PM
S.E.Ohio
Magnumguy Offline
Magnumguy  Offline
S.E.Ohio
I thought Chrysler small blocks would run 180 out, not great, but would run. True or not?
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: 1978 440 Won't Run [Re: Magnumguy] #3025751
03/20/22 02:25 PM
03/20/22 02:25 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
Nope, BTDT, not true. Well, unless you're a complete screwup and install the cam 180 degrees out, DAMHIK about that..
'69 300 Convertible
'16 300 S Hemi
