Re: 572 all aluminum headed to dyno
[Re: fast68plymouth]
#3015584
02/15/22 07:48 AM
02/15/22 07:48 AM
Posts: 10,022 MN
JERICOGTX
MN
I'd rather have a stingy dyno sheet, and a happy time slip, than a happy dyno sheet, and stingy time slip. The 572 Andy built is going to make a great bracket engine for the customer.
69 GTX
68 Road Runner
[Re: AndyF]
#3024116
03/15/22 08:59 AM
03/15/22 08:59 AM
Posts: 16,924 NC
440Jim
NC
The 572 is in the car and getting ready to go to the track. First track day here is March 26, forecast calls for rain so we'll see if it happens. They were planning to run a PG behind this engine but the Reid case has never shown up so they put the 727 back in the car. Had already built a new crossmember and loop for the PG so all of that stuff had to be cut out and redone. Sucks to be building cars when everything is on backorder. Ugh! Welded the new stuff and had to cut it out. Pain in the butt.
[Re: AndyF]
#3026561
03/22/22 09:15 PM
03/22/22 09:15 PM
Posts: 31,019 Oregon
AndyF
Finally got it running well enough that it can go to the track. The cam used in this engine was not EFI friendly! I think this was the most work I've ever had to do to get a tune dialed in. It wasn't too hard to find a happy spot for idle, but the off idle area was super difficult to nail down. The engine would die as soon as it went into gear and it wouldn't do anything when the pedal was slowly depressed. Finally figured out that this engine works okay with a lean idle, but it wants a bunch of fuel added as soon as the pedal is moved off idle. Anyway, got the tune wrapped up and then loaded the car onto the trailer so they can take it to the track on the next sunny day.
[Re: AndyF]
#3026643
03/23/22 06:03 AM
03/23/22 06:03 AM
Posts: 10,022 MN
JERICOGTX
MN
What does the car weigh race ready?
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3026709
03/23/22 11:38 AM
03/23/22 11:38 AM
AndyF
What does the car weigh race ready? Ready to run without a driver is 3000 lbs. Not sure on the distribution, I'd have to look up the scale info.
[Re: 572B1]
#3027982
03/27/22 09:07 AM
03/27/22 09:07 AM
Posts: 16,924 NC
440Jim
NC
Thats about 772 hp at the engine. going by the wallace calculator. Using 9.36 at 143 mph: Wallace at 3000 lbs: HP computed from your vehicle ET is 721. flywheel HP Wallace at 3200 lbs: HP computed from your vehicle ET is 769. flywheel HP. Adding 200 lbs for driver. It made 870 power at 6800 and 760 torque at 5400. Shifting as early as they did, it should go quicker when they are ready to rev it higher. Using 9.00 ET: Wallace at 3200 lbs: HP computed from your vehicle ET is 865. flywheel HP (about what the dyno measured).
[Re: 440Jim]
#3027993
03/27/22 09:39 AM
03/27/22 09:39 AM
Posts: 854 Brisbane Australia
572B1
Brisbane Australia
Thats about 772 hp at the engine. going by the wallace calculator. Using 9.36 at 143 mph: Wallace at 3000 lbs: HP computed from your vehicle ET is 721. flywheel HP Wallace at 3200 lbs: HP computed from your vehicle ET is 769. flywheel HP. Adding 200 lbs for driver. It made 870 power at 6800 and 760 torque at 5400. Shifting as early as they did, it should go quicker when they are ready to rev it higher. Using 9.00 ET: Wallace at 3200 lbs: HP computed from your vehicle ET is 865. flywheel HP (about what the dyno measured). Jim, my comment was as it stands 772 hp at 3200 lbs including driver. not what it may do in the future.
[Re: AndyF]
#3028089
03/27/22 04:02 PM
03/27/22 04:02 PM
Posts: 14,495 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
The Moroso chart shows a 9.40 for 143mph.
Power to weight of 4.44
#3028101
03/27/22 04:30 PM
03/27/22 04:30 PM
Posts: 570 UK
rb446
UK
Wallace> 765fwhp@3200lbs 60 Foot E.T. : 1.30 Seconds 1/8 Mile E.T. : 5.92 Seconds 1/8 Mile Trap Speed : 114.78 MPH 1/4 Mile E.T. : 9.39 Seconds 1/4 Mile Trap Speed : 143 MPH 865fwhp 3200> 60 Foot E.T. : 1.25 Seconds 1/8 Mile E.T. : 5.68 Seconds 1/8 Mile Trap Speed : 119.58 MPH 1/4 Mile E.T. : 9.01 Seconds 1/4 Mile Trap Speed : 149 MPH http://www.wallaceracing.com/accel-calc.phpalways used this for years, input weight and change hp for ET/mph at sea level numbers.
1969 'Cuda 446ci, best 9.96@133.9 in 1990 1971 340 'Cuda, best 11.01@122.8 in 1987
