Re: 489 case help
[Re: hulmule]
#3024415
03/15/22 10:34 PM
03/15/22 10:34 PM
Posts: 1,757 Phila
PhillyRag
Phila
So i had a shop rebuild my 489 and made it a posi. So now i go to put the bolts in the yoke and one is really loose/bad . Guess i should have checked before i sent out. So i figure i'll drill it deeper and use a longer grade 8 bolt. WELL the tap broke off and aint getting it out. Trust me i know , my father was a machinist and i was going easy ...Bottom line now is i need to change the yoke. The rear end is all together really to go in... So can i change the yoke out ? 489 is a crush sleeve correct? Is there a way i can get it off and put a another yoke on? Check with shop first & find out which method they used for the setup. Crush sleeve or otherwise.
Re: 489 case help
[Re: Moparteacher]
#3024467
03/16/22 08:43 AM
03/16/22 08:43 AM
Posts: 1,413 northeast ohio
hulmule
northeast ohio
Thanks ! going to give it a try . Will call shop and see what he did. Thanks for the info.
1969 Dodge Coronet R/T Convertible 1979 LiL Red x2 2012 Yellow Jacket 2006 mega cab 1977 Trailduster 1979 Trailduster
Re: 489 case help
[Re: PhillyRag]
#3024512
03/16/22 11:11 AM
03/16/22 11:11 AM
Posts: 75,126 A Banana Republic near you.
JohnRR
So i had a shop rebuild my 489 and made it a posi. So now i go to put the bolts in the yoke and one is really loose/bad . Guess i should have checked before i sent out. So i figure i'll drill it deeper and use a longer grade 8 bolt. WELL the tap broke off and aint getting it out. Trust me i know , my father was a machinist and i was going easy ...Bottom line now is i need to change the yoke. The rear end is all together really to go in... So can i change the yoke out ? 489 is a crush sleeve correct? Is there a way i can get it off and put a another yoke on? Check with shop first & find out which method they used for the setup. Crush sleeve or otherwise. This , get another yoke , check to make sure the bolt holes are good , and have the shop swap the yoke. It can be done with a crush sleeve but you have to know what you are doing ...
Re: 489 case help
[Re: TJP]
#3024882
03/17/22 02:01 PM
03/17/22 02:01 PM
JohnRR
Another approach would be to ditch the sleeve, buy a spacer kit, and reinstall with shims. That should have been done originally , to do it now requires pulling the differential out because the crush sleeve is bigger than the outer bearing size .
Re: 489 case help
[Re: cudaman1969]
#3024932
03/17/22 05:09 PM
03/17/22 05:09 PM
Posts: 21,855 Kirkland, Washington
Pacnorthcuda
Take it off l, install the new one with lock tight on the nut. The process is just preloading the bearings, you don’t even need a crush sleeve if the nut stays tight, it ain’t rocket science. The problem is that if the pinion nut isn’t tightened SLIGHTLY (and I mean slightly) more then the pinion has an even better opportunity to slam the crush sleeve during operation, which it does anyway.
Re: 489 case help
[Re: Pacnorthcuda]
#3024969
03/17/22 07:31 PM
03/17/22 07:31 PM
hulmule
northeast ohio
done fixed , and on to the next project with the Gen3 72 Cuda.
Re: 489 case help
[Re: Pacnorthcuda]
#3024998
03/17/22 08:43 PM
03/17/22 08:43 PM
Posts: 8,376 fredericksburg,va
cudaman1969
fredericksburg,va
Take it off l, install the new one with lock tight on the nut. The process is just preloading the bearings, you don’t even need a crush sleeve if the nut stays tight, it ain’t rocket science. The problem is that if the pinion nut isn’t tightened SLIGHTLY (and I mean slightly) more then the pinion has an even better opportunity to slam the crush sleeve during operation, which it does anyway. The only purpose of the sleeve is to torque the nut to 250 ft lbs (so it won’t come lose) not hold bearings apart. Besides under power the pinion is forced forward.
Re: 489 case help
[Re: hulmule]
#3025082
03/18/22 09:08 AM
03/18/22 09:08 AM
Posts: 10,778 North Dakota
6PakBee
North Dakota
done fixed , and on to the next project with the Gen3 72 Cuda. So what was your solution?
