Re: Plumbers - Stuck ball valve
[Re: Stanton]
#3024355
03/15/22 07:17 PM
03/15/22 07:17 PM
Posts: 6,306 nowhere
Sniper
nowhere
Loosen the nut just a tad and try turning. The packing may have gone hard or caused a bit of corrosion that's causing things to bind. Those things are solid brass so its unlikely its "rusted" open.
FWIW, isn't the meter the city's responsibility? I'd call them first. Worst they can say is "no". Here, it depends on where the valve is located, the meter and everything upstream belongs to the city, downstream of the meter it's mine to deal with. With the comment about the street side of the meter I suspect the valve is the city's issue to deal with if thw OP wants to deal with the city. Might even be illegal for him to touch it.
[Re: Sniper]
#3024362
03/15/22 07:37 PM
03/15/22 07:37 PM
Posts: 8,902 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Might even be illegal for him to touch it. I was thinking that too.
[Re: fastmark]
#3024461
03/16/22 08:14 AM
03/16/22 08:14 AM
Posts: 3,389 St. Charles, MO
wingman
Uncreative Title
Uncreative Title
St. Charles, MO
If it’s before the meter, it’s the city’s problem. If after it’s yours. Not in every municipality... In ours everything downstream from the main (excluding the meter itself and meter shutoff valves) is mine to deal with. DAMHIK.
1969 Dodge Coronet Super Bee 383 A4 1970 Plymouth Road Runner 440 FC7 (sold)
[Re: wingman]
#3024472
03/16/22 08:57 AM
03/16/22 08:57 AM
Posts: 10,750 North Dakota
6PakBee
North Dakota
If it’s before the meter, it’s the city’s problem. If after it’s yours. Not in every municipality... In ours everything downstream from the main (excluding the meter itself and meter shutoff valves) is mine to deal with. DAMHIK. Yup. In my town the city is responsible up to the curbstop. After that everything, including the meter, is the homeowner's responsibility.
[Re: 6PakBee]
#3024545
03/16/22 12:51 PM
03/16/22 12:51 PM
Posts: 2,412 Massachusetts
Faust
Massachusetts
If it’s before the meter, it’s the city’s problem. If after it’s yours. Not in every municipality... In ours everything downstream from the main (excluding the meter itself and meter shutoff valves) is mine to deal with. DAMHIK. Yup. In my town the city is responsible up to the curbstop. After that everything, including the meter, is the homeowner's responsibility. The last time I had them shut it off at the street, they broke the curbstop. That cost me $1500 in 1990 dollars.
[Re: Faust]
#3024620
03/16/22 04:37 PM
03/16/22 04:37 PM
Sniper
nowhere
If it’s before the meter, it’s the city’s problem. If after it’s yours. Not in every municipality... In ours everything downstream from the main (excluding the meter itself and meter shutoff valves) is mine to deal with. DAMHIK. Yup. In my town the city is responsible up to the curbstop. After that everything, including the meter, is the homeowner's responsibility. The last time I had them shut it off at the street, they broke the curbstop. That cost me $1500 in 1990 dollars. Video it, then make them eat the cost if they do it again.
