Autometer 2300 Tach ebody placement #3023855
03/14/22 09:09 AM
03/14/22 09:09 AM
PA
dixie2bird Offline OP
PA
I just finished replacing my restored dash in my 72 Cuda and want to install my Tachometer but don't want to put any holes in the dash. It's the larger Autometer tach which I haven't found many mounting bracket ideas. I thought about replacing it with a smaller one, but I've had it for ever and I really like the larger size. Anyone got any pics they can share? Thanks!
1972 Cuda 340 4-speed
2015 Challenger SRT 392
2015 Jeep Wrangler Unlimited Willy's
Re: Autometer 2300 Tach ebody placement [Re: dixie2bird] #3023920
03/14/22 12:03 PM
03/14/22 12:03 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Can you mount it on the A pillar using an existing screw hole? I used that spot a number of times on my A bodies.
Re: Autometer 2300 Tach ebody placement [Re: dixie2bird] #3023926
03/14/22 12:14 PM
03/14/22 12:14 PM
Kirkland, Washington
Pacnorthcuda Offline
Twice I’ve mounted them on 70 Cuda’s by hanging them from the dash light bracket in the underside of the dash pad, right in front of the stock tach in rallye dash cars, that way I avoid the horrible band clamp on the steering column. But if you’re dealing with a standard dash that’s not an option.
Re: Autometer 2300 Tach ebody placement [Re: stumpy] #3023928
03/14/22 12:19 PM
03/14/22 12:19 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Mostly street car? Race car?
For something that hits the track, somewhere in your line of sight.
If you only need to glance at it occasionally, off the side of the column or at the bottom of the dash should be fine.
Isn't the 2300 the 3 3/4" tach?
For a column mount, the bracket can be clamped to the column; you can use a large worm-drive HVAC hose clamp, trim the tail, and put heat-shrink tubing over it.
Should be some existing holes @ underside of dash if you want it there.
Re: Autometer 2300 Tach ebody placement [Re: topside] #3023947
03/14/22 01:00 PM
03/14/22 01:00 PM
PA
PA
I did have it hanging under my dash lights originally, but for racing, yes, it's hard to see so I then moved it to on top of the dash and ran it through the crack in the top speaker and used velcro to secure it to the dash. But now, that's all been fixed up. I am looking at my A pillar which has one screw in it. I think it would look good there and would be in pretty good sight. I'll just have to make sure I line up on the left side of the tree. I'd be curious to see any pictures of it attached this way. I took the base off and I guess I'll have to get creative on how to attach it. And yes, it's the 3 3/4" tach. Thanks!
Re: Autometer 2300 Tach ebody placement [Re: Pacnorthcuda] #3023972
03/14/22 01:54 PM
03/14/22 01:54 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Mine has been that way forever.
Re: Autometer 2300 Tach ebody placement [Re: dixie2bird] #3023976
03/14/22 02:04 PM
03/14/22 02:04 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I've done the A-pillar location, too, but that was easy with a downbar there.
You could get a 2nd molding and drill it, saving the original one.
Bottom line though, mount it low enough, and it won't interfere with seeing the tree.
It's easy enough to know your staging RPM by ear that I'd only check/verify on occasion.
Re: Autometer 2300 Tach ebody placement [Re: topside] #3023998
03/14/22 04:18 PM
03/14/22 04:18 PM
PA
PA
Depends on who's staged next to you if I can hear it or not laugh2
Re: Autometer 2300 Tach ebody placement [Re: dixie2bird] #3024045
03/14/22 07:53 PM
03/14/22 07:53 PM
Grand Prairie,Texas
Grand Prairie,Texas
Re: Autometer 2300 Tach ebody placement [Re: dixie2bird] #3024636
03/16/22 05:48 PM
03/16/22 05:48 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
In my 71 Challenger convertible, I mounted an Autometer tach in the hole where the factory tach used to live. My car didn't come with a Rallye dash, but I put it in when I redid the car in the early 90's. Been a few minutes, and I don't remember a lot of details, but I took the factory tach out of the gauge cluster, scribed the plastic Lense, and then used a soldering iron to melt the hole out for the new Autometer tach to go through. The new tach fit perfect thru the hole in the woodgrain bezel and the ring on the front of the tach stopped it against the bezel. I put a piece of foam around the tach on the inside of the bezel and used a big hose clamp over the foam and right against the back of the bezel to hold it in place. I ran the wires out of the back of the cluster to hook them up to where each one went.
The tach I used was probably a 3 3/8 round one and may not be as big as what you'd like, but it always worked great for me. I ran the snot out of the convertible at the strip for years, so it wasn't just for looks. It's sitting out in the garage covered up for the winter, but I could get you a pic of what it looks like if you want. It only looks cobbled up to total purists, but a lot of E body guys have asked about it over the years.
Re: Autometer 2300 Tach ebody placement [Re: dixie2bird] #3024760
03/17/22 06:52 AM
03/17/22 06:52 AM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
I've abandoned the use of a traditional tach and will be using a shift light with digital readout. The only reason I'll care to know RPM is on the starting line and will use the shift light accordingly. No worrying about mounting some monster tach anywhere in a cramped e body dash, still functions just the same, doesn't look gawdy.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: Autometer 2300 Tach ebody placement [Re: A39Coronet] #3028257
03/28/22 08:35 AM
03/28/22 08:35 AM
PA
PA
So here's what I've come up. It seems pretty stable. I like the placement. Very visible!!
Re: Autometer 2300 Tach ebody placement [Re: dixie2bird] #3028331
03/28/22 12:13 PM
03/28/22 12:13 PM
Grand Prairie,Texas
Grand Prairie,Texas
Re: Autometer 2300 Tach ebody placement [Re: stumpy] #3030077
04/02/22 08:32 PM
04/02/22 08:32 PM
GA
roadrunninMark Offline
GA
You can also use a tach that goes into the standard dash where the clock is (or if you just have a space filler). Here is the tach... https://www.classicindustries.com/product/1971/plymouth/barracuda/parts/me1316.html
Kind of pricey though....
Re: Autometer 2300 Tach ebody placement [Re: roadrunninMark] #3030145
04/03/22 05:53 AM
04/03/22 05:53 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
Why not get a rally dash with a tach?
Re: Autometer 2300 Tach ebody placement [Re: Moparite] #3030221
04/03/22 12:30 PM
04/03/22 12:30 PM
Grand Prairie,Texas
Grand Prairie,Texas
Putting the tach on the A pillar makes it easier to see while racing. It is in eyesight without having to take your eyes off of straight ahead on the track. No having to look down to see it.
Re: Autometer 2300 Tach ebody placement [Re: stumpy] #3030352
04/03/22 06:20 PM
04/03/22 06:20 PM
PA
PA
iagree
But wait there's more ... made it glow green punkrocka. Now it matches the rest of the cluster!
