Re: Big cam big miles
[Re: T-bar]
#3023465
03/13/22 07:16 AM
03/13/22 07:16 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
Good question? On my Victor MW heads, the short valve spring install height, and weak rocker shaft pedestals cast into the head were problem areas. I ended up milling off the pedestals and using max wedge type rocker shaft blocks. T&D now offers paired shaft rockers that would be a better solution. If going to custom rocker system, I would use valves with longer stems to make it easier to get more spring install height, then relocate the rockers for best geometry. If looking for 0.800"+ lift I would use a 1.7:1 intake rocker arm, and for long life, a more gentle cam lobe profile that can be controlled with a lower rate valve spring. An aggressive cam profile is going to want a high spring rate, which makes things harder on the valve train. On my current setup, I believe my exhaust profile (Comp HXL) with 1.6:1 rockers is too aggressive. I have though of using a 1.5:1 ratio rocker arm, and a slower opening exhaust lobe profile to take strain off the valve train. I like the idea of the bushed lifter bores with keyway roller lifters, but have no idea on how they would do with many miles on them? The keyed lifters should be lighter in weight (than the taller roller lifters with the cross bar) making the valve train more stable. I'm running the PAC 1326 valve springs, but only 0.726" lift. It is 275 seat pressure and 663 spring rate. They list as 805 open pressure @ 0.800"
If you have room for a 1.625" diameter spring, something like the PAC-1328 installs at 2.100" with 280 pounds, and has a spring rate of 629, and at 0.900" lift the pressure is 847 pounds, if that will work with your cam selection?
You would want good oil cooling of the springs too.
[Re: T-bar]
#3023484
03/13/22 09:31 AM
03/13/22 09:31 AM
Posts: 12,385 Taxes & Virus's R-US, NY
Dragula
I have been pushing street car boundaries for years with a big cam and cubes, except I am only at .750 lift in a 605 Hemi.....But even there, it has its price. New Titanium lash caps every year cause they mushroom....Really have to keep an eye on the pushrod tips and oil spray...I used to burn up pushrods all the time. ...Hot springs is another issue...You have to have enough oil on the springs to not eat them up as well....A big pan and pump are really necessary when doing this. I have eaten more valve train parts than most race shops over the years..A wedge would be way better than a Hemi for big cube street engine.Preferably a Predator head on Hemi block... Good Vid https://www.youtube.com/watch?v=PptxPDvbWsg
[Re: T-bar]
#3023556
03/13/22 12:12 PM
03/13/22 12:12 PM
Posts: 31,000 Oregon
AndyF
Hello, who does or knows someone that can do big highway miles with .800"+ lift and big spring pressures? What's the problems that will arise? Spring failure, lifters? Big cube mopar motor. Drag week style events etc. You'll wants lot of oil up there for freeway driving. I'm not sure what those guys do but something like adjustable spray bar oilers might be the trick. Turn up the volume for street driving, turn it down for high rpm drag racing.
[Re: AndyF]
#3023583
03/13/22 01:07 PM
03/13/22 01:07 PM
Posts: 4,564 Motor City
6PKRTSE
Motor City
I run a .805/.815 on the street in my 528" Hemi with Barton rocker system with spray bar oilers with no issues.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#3023599
03/13/22 02:09 PM
03/13/22 02:09 PM
Posts: 14,493 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I run a .805/.815 on the street in my 528" Hemi with Barton rocker system with spray bar oilers with no issues. With??
[Re: fast68plymouth]
#3023606
03/13/22 02:30 PM
03/13/22 02:30 PM
Posts: 2,855 Pattison Texas
CSK
Pattison Texas
From what I have seen is they put small ratio rockers on to make the street trips, like 1.2 ratio, & put the big ratio rockers on to race.
[Re: 6PKRTSE]
#3023629
03/13/22 03:24 PM
03/13/22 03:24 PM
Dragula
I run a .805/.815 on the street in my 528" Hemi with Barton rocker system with spray bar oilers with no issues. That's what I probably need to go to...Better check your lash caps though..
