Re: fuel sending unit sealing
[Re: 1969ronnie]
#3022850
03/11/22 12:07 PM
03/11/22 12:07 PM
Posts: 13,584 md
mopars4ever
md
I tried the double gasket thing and it leaked worse. NOS one fixed mine. I may have a good used one somewhere around if you can`t find one.
[Re: mopars4ever]
#3022862
03/11/22 12:36 PM
03/11/22 12:36 PM
Posts: 15,350 Omaha Ne
TJP
Omaha Ne
Owning a classic shop and having installed many tanks, we haven't had a lot of problems with leaks. if possible use the original ring, if not just pay close attention while tightening the ring down for any distortion if the ring. If you really wasn to be 100% sure, cap off the openings and pressurize the tank with 5-10 psi of air (NO MORE). Spray any suspected areas with soapy water and it will bubble if leaking NOTE: if using a repop sending unit you'll likely be removing it for adjustment as I have yet to find a source for accurate Sending Units. Maybe some one else will chime in A method I have used on empty tanks out of the car 1. install the S/U. measure the resistance of the S/U should be ~ 75-80 ohms. Flip the tank over and measure it again, Should read ~ 10 ohms 2. Another solution is TANKS METER MATCH
[Re: burdar]
#3023403
03/12/22 09:28 PM
03/12/22 09:28 PM
Posts: 13,584 md
mopars4ever
md
[Re: TJP]
#3023476
03/13/22 08:55 AM
03/13/22 08:55 AM
Posts: 6,241 nowhere
Sniper
nowhere
WOW FM has something on the bay under 5 bazillion $$ LOL I believe Frank passed on some years ago, the new owners seem more reasonable. I've recently bought some things for my 51 Plymouth from them ,reasonable proces, fast shipping, good service. YMMV
[Re: EW1BH27]
#3023581
03/13/22 12:58 PM
03/13/22 12:58 PM
Sniper
nowhere
I'm a bit leery about that eBay one from fmmpar . I haven't heard of this much needed part being reproduced and how did "more than 10" all of a sudden show up with 20 already sold. In "Item specifics" under Region of manufacture it says United States but the description has "Made in Canada". It sure looks similar to the cheap ones that come with sending units and NOS doesn't mean OEM or OEM like quality. I still have an unopened DMT one and the thickness is obvious when compared to the supplied ones with sending units (I have a few of those too). It's $4.00. Buy one and compare, then tell us.
[Re: Sniper]
#3023584
03/13/22 01:35 PM
03/13/22 01:35 PM
Posts: 143 Canada
EW1BH27
Canada
I live in Canada so with the dollar exchange and their shipping my cost works out to be $25.15CAD (at the current rate when this is posted.). I might have considered your suggestion but not at that price, especially since I already have several. Thought I would just share my opinion since I've had some experience with the cheap ones vs my OEM one.
[Re: EW1BH27]
#3023647
03/13/22 04:22 PM
03/13/22 04:22 PM
Sniper
nowhere
I live in Canada so with the dollar exchange and their shipping my cost works out to be $25.15CAD (at the current rate when this is posted.). I might have considered your suggestion but not at that price, especially since I already have several. Thought I would just share my opinion since I've had some experience with the cheap ones vs my OEM one. maybe someone can measure the thickness of the new style and you can measure your older ones and we can lay this to rest?
[Re: EW1BH27]
#3023724
03/13/22 08:55 PM
03/13/22 08:55 PM
TJP
Omaha Ne
I live in Canada so with the dollar exchange and their shipping my cost works out to be $25.15CAD (at the current rate when this is posted.). I might have considered your suggestion but not at that price, especially since I already have several. Thought I would just share my opinion since I've had some experience with the cheap ones vs my OEM one. if it's coming from Canada it's likely a Spectre part who BTW is in Canada
