68 383 Barracuda air cleaner #3021553
03/07/22 04:02 PM
03/07/22 04:02 PM
Oakwood Ont Canada
340mouse Offline OP
340mouse  Offline OP
Oakwood Ont Canada
What is the correct air cleaner for a 68 Barracuda 383. Thanks Dave
Re: 68 383 Barracuda air cleaner [Re: 340mouse] #3021643
03/07/22 08:45 PM
03/07/22 08:45 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Same as 340 with a different pie tin. I'm not sure if the pie tin I put on the 383 is the correct one. And, no, you could not get AC with a 383. That's an original 273 car.
Also, those are 273 valve covers on the 340.
Re: 68 383 Barracuda air cleaner [Re: Jim_Lusk] #3021762
03/08/22 02:41 AM
03/08/22 02:41 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
early 1968 cars used "left-over" '67 air cleaners with the AVS (VS. AFB) base
RED pie tin with TURQUOISE engine
Re: 68 383 Barracuda air cleaner [Re: 6bblgt] #3021902
03/08/22 01:10 PM
03/08/22 01:10 PM
Oakwood Ont Canada
340mouse Offline OP
340mouse  Offline OP
Oakwood Ont Canada
Thanks, I have seen both and this makes sense now, My 68 383 is an August 18th build date so likely should be the 67 style, Thanks again for your help.
Re: 68 383 Barracuda air cleaner [Re: 340mouse] #3022983
03/11/22 05:40 PM
03/11/22 05:40 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
here's my aug 27th built 383 formula S ragtops engine
