55-56 Dodge Plymouth Rear Axle width #3019233
02/26/22 10:00 PM
02/26/22 10:00 PM
AZ
Mike P Offline OP
Mike P  Offline OP
AZ
Does anybody happen to have the flange to flange width of a 1955-56 Dodge or Plymouth rear axle handy?
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold
1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold
1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears)
Re: 55-56 Dodge Plymouth Rear Axle width [Re: Mike P] #3019375
02/27/22 12:33 PM
02/27/22 12:33 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Housing width or drum-to-drum (overall) width?
The drum-to-drum width for the '55-'56 Dodge/Plymouth is 59 15/16". The spring perch centers are 41".
Re: 55-56 Dodge Plymouth Rear Axle width [Re: John_Kunkel] #3019388
02/27/22 12:57 PM
02/27/22 12:57 PM
AZ
Mike P Offline OP
Mike P  Offline OP
AZ
Thanks John. Overall width, the info was just what I was looking for.
Re: 55-56 Dodge Plymouth Rear Axle width [Re: Mike P] #3020836
03/04/22 04:02 PM
03/04/22 04:02 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If you're looking for a later model to swap in, the '65-'67 B-body is 59 1/2" with 44" perch centers.
Re: 55-56 Dodge Plymouth Rear Axle width [Re: John_Kunkel] #3020887
03/04/22 07:38 PM
03/04/22 07:38 PM
AZ
Mike P Offline OP
Mike P  Offline OP
AZ
Thanks again John.
I’ve been kind of looking for a 55-56 Dodge or Plymouth to wrap the 1st Gen Hemi I’m building with. No luck so far but something will probably turn up.
I figure if I stumble on a rear end (or just housing and axles) the right width and price I’ll probably pick it up just to have it on hand. While I’d prefer an 8 ¾” I don’t think I’d pass up a 9” Ford if I stumble across one. I did a quick check on the prices for the parts I’ll need to set either one up and they run about same.
We have a swap meet coming up in a couple of weeks so I’ll throw the tape measure in my pocket LOL.
Re: 55-56 Dodge Plymouth Rear Axle width [Re: Mike P] #3020891
03/04/22 07:55 PM
03/04/22 07:55 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Lot of people use the Ford 8.8 out of an Explorer in these applications. 1991-2003 Ford Explorer 8.8-Inch Axle - 59.625 inches
Re: 55-56 Dodge Plymouth Rear Axle width [Re: Sniper] #3021223
03/06/22 11:05 AM
03/06/22 11:05 AM
Buckeye Lake
56_Royal_Lancer Offline
My Mouth Is Shut II
My Mouth Is Shut II
Buckeye Lake
I ran a 8 3/4 from a mid-'60's (I think '65) B- Body in my 440-powered '56. Moved the perches and it worked great.
Re: 55-56 Dodge Plymouth Rear Axle width [Re: 56_Royal_Lancer] #3021304
03/06/22 04:32 PM
03/06/22 04:32 PM
Long Island, New York
57Fury440 Offline
57Fury440  Offline
I have the same set up in my '57. Works great and the 8 & 3/4 rear is easy to work on.
Re: 55-56 Dodge Plymouth Rear Axle width [Re: 57Fury440] #3021443
03/07/22 09:23 AM
03/07/22 09:23 AM
AZ
Mike P Offline OP
Mike P  Offline OP
AZ
“…….Lot of people use the Ford 8.8……..”
For the last few years that’s kind of been one of the hot setups, and I’ve got to admit their becoming a lot easier to find than the 8 ¾ and 9”. I like the idea of using a rear end with a drop out center section for this project however. I’ve narrowed the rear end ratio I’ll be using to 3 choices; 4.10, 4.30 and 4.56. The final decision will be left until I figure out what tire size I stuff under the rear end. If I choose poorly and want to change, it’s a whole lot easier with a drop out center section.
“……I have the same set up in my '57. Works great and the 8 & 3/4 rear is easy to work on……”
I’m running a 9 ¼ with the cone type sure-grip of unknown origin in my 57. Fortunately I’m happy with the 4.10s and A833 overdrive transmission. You’re right about the 8 ¾ being easy to work on, especially a gear change. Relocating spring perches, setting pinion angles, plumbing and emergency brakes, even building a drive shaft if necessary are not really hard jobs but they are time consuming and something you only want to do once on a project. Once you have it done you pretty much live with the housing you’ve built. Doing a gear or carrier change at that point gives you 2 options; pull the whole housing to make it easier to work on or fight doing it in car. I’m getting older and neither option is real appealing………course it might be a good time to teach my grandson all about rear ends work
“…….I ran a 8 3/4 from a mid-'60's (I think '65) B- Body in my 440-powered '56…….”
Just curious, what are you running for a front suspension and rear springs?
Re: 55-56 Dodge Plymouth Rear Axle width [Re: Mike P] #3021444
03/07/22 09:47 AM
03/07/22 09:47 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
If you are only going to be doing this once, might be even easier to have a shop do the gear change on the 8.8. Still probably come out cheaper than finding and buying am 8 3/4 and odds are you won't be finding the ratio you want already in it so you still will be doing a gear change, unless you already have those center sections on hand and ready to go.
Not to mention disc brakes are easy to find on an 8.8. if you want them, not so much the other options mentioned.
I haven't paid for a gear change since 91, so I dunno the cost there, ymmv.
Re: 55-56 Dodge Plymouth Rear Axle width [Re: Sniper] #3021463
03/07/22 11:21 AM
03/07/22 11:21 AM
Buckeye Lake
My Mouth Is Shut II
My Mouth Is Shut II
Buckeye Lake
I went through the stock front suspension and kept it. I had the opportunity to clip the front of the frame but after the time spent building the engine, swapping drivetrain, differential and more, I was getting tired of working on it and just wanted to drive it. I'm embarrassed to say I don't recall the specifics of the rear springs, I worked with a local suspension shop and followed their recommendations. Took a ton of build pictures in case they could help some else building a similar big block 'project but none of the rear and springs. Go figure
Re: 55-56 Dodge Plymouth Rear Axle width [Re: 56_Royal_Lancer] #3021494
03/07/22 12:44 PM
03/07/22 12:44 PM
AZ
Mike P Offline OP
Mike P  Offline OP
AZ
Thanks Sniper, what you are saying makes perfect sense, and is not out of the question, based on what I can find locally. Since your original comment I have also been pricing out carriers and ring and pinion sets for the 8.8s along with the 8¾ and 9” (so far everything is pretty comparable). You right about my wish list for ratios not necessarily being factory available. Your point about disc brakes is also a consideration although conversions for the Ford 9” are pretty easy to come across, and I know they are out there for the 8 3/4 (just haven’t priced them out).
Normally I wouldn’t have given a second thought to the rearend this early in the process. Up until a couple of months ago there was an old time mom and pop junk yard nearby with a LOT of 50-60s parts cars to choose from. With the death of the original owners the kids elected to sell all the cars in the yard and they have been moved out to a couple of yards up north.
With that source gone I figured it might be a good idea start looking around now for something that will fit the car I plan to eventually end up with (55-56 Dodge or Plymouth). I still have a few local sources to check by I needed an idea on the width I’d need.
Our market out here is a bit different than back in the Mid-West. Without having the rust issues out here there are still a lot of older vehicles around and sourcing an 8 3/4 or 9” is still fairly easy. That being said, while the old cars don’t usually show up in the pick-a-part yards the vehicles with 8.8” do.
So basically everything is still on the table and I do appreciate your input.
Re: 55-56 Dodge Plymouth Rear Axle width [Re: Mike P] #3021495
03/07/22 12:44 PM
03/07/22 12:44 PM
AZ
Mike P Offline OP
Mike P  Offline OP
AZ
56 Royal that’s nice! Bet it’s fun too up
As I mentioned above, I’m looking around for a 55-56 Dodge or Plymouth to stuff a drive train I’m building in to; first Gen 354 HEMI and 46 RH transmission and a later rear end (LOL).
My original thought was the same as you, doing a front clip. After thinking on it a bit I’ve been wondering how I would like it with the stock front suspension (rebuilt of course) with disc brake and Power Steering conversions.
You are probably the perfect person to ask this question to. How do you like the stock front suspension? Do you happen to remember what you used for front springs?
Re: 55-56 Dodge Plymouth Rear Axle width [Re: Mike P] #3021506
03/07/22 01:36 PM
03/07/22 01:36 PM
Buckeye Lake
My Mouth Is Shut II
My Mouth Is Shut II
Buckeye Lake
Front springs are stock but new. Scarebird offers a disc brake conversion. https://scarebird.com/index.php?route=product/product&path=64&product_id=175
I didn't install power steering, just toughed it out with the manual set up. Actually, I liked the natural feel on the road, though parking could be challenging. I kept the original, large diameter steering wheel, so that gave me some leverage. The ride with the stock suspension was quite comfortable and controlled.
Re: 55-56 Dodge Plymouth Rear Axle width [Re: Mike P] #3021507
03/07/22 01:38 PM
03/07/22 01:38 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I have the '65-'67 B-body rear in my '56 Plymouth with the spring perches moved inboard. The original shocks mounted on the spring perch but there's no reason why you couldn't use the later lower plates and use a longer shock.
As to the Ford rear, is the pinion offset the same as the Mopar? Worth mentioning.
Re: 55-56 Dodge Plymouth Rear Axle width [Re: John_Kunkel] #3021519
03/07/22 02:06 PM
03/07/22 02:06 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Be aware that a 57 Dodge and a 55 & 56 are different critters. The 57 was "all new" and the power steering on a 57 only fits a 57-60, and leaves a lot to be desired. The steering box is part of the steering column, (both manual and power, but the power box is huge) and it all goes in and out of the car through the car's interior. Because of the 57's torsion bars and the location of the steering box, you are very limited to other power steering options. Something you may want to keep in mind as you look for a car.
We installed an 8.8 into my son's 57 Dodge wagon (along with a 5.7 and its auto trans). The 8.8 we installed was a disc brake with a 3:73 limited slip. it was originally a coil spring rear end (I think) out of an Explorer. The wheel track was pretty narrow for the wagon, he had to get wheels with the proper off set. We also had to cut and open up the drive shaft tunnel about an inch for driveshaft clearance (I believe it was because of the driveshaft diameter rather then the pinion offset, but it was several years and several builds ago.
Re: 55-56 Dodge Plymouth Rear Axle width [Re: poorboy] #3021579
03/07/22 05:44 PM
03/07/22 05:44 PM
AZ
Mike P Offline OP
Mike P  Offline OP
AZ
“……Front springs are stock but new. Scarebird offers a disc brake conversion. https://scarebird.com/index.php?route=product/product&path=64&product_id=175
I didn't install power steering, just toughed it out with the manual set up. Actually, I liked the natural feel on the road, though parking could be challenging. I kept the original, large diameter steering wheel, so that gave me some leverage. The ride with the stock suspension was quite comfortable and controlled…….”
Thanks 56 Royal. That’s the info I was looking for. I’ve already been looking at the Scarebird conversion. They appear be the only game in town right now. AAJ used to make a kit, but I don’t think they’re in business anymore.
“….As to the Ford rear, is the pinion offset the same as the Mopar? Worth mentioning…..”
Honestly not real sure John, but something else to definitely consider (and research).
“…..Be aware that a 57 Dodge and a 55 & 56 are different critters. The 57 was "all new" and the power steering on a 57 only fits a 57-60, and leaves a lot to be desired. The steering box is part of the steering column, (both manual and power, but the power box is huge) and it all goes in and out of the car through the car's interior. Because of the 57's torsion bars and the location of the steering box, you are very limited to other power steering options. Something you may want to keep in mind as you look for a car……”
Thanks poorboy, and yes I am definitely aware of the differences between the 55-56 and the 57-60 car (actually if I’m not mistaken the same steering box was used thru 1962 on the Chryslers).
You’re right about them leaving a lot to be desired. In addition to being a PIA to get in and out the road feel is horrible……it was the reason I went with manual steering when I originally built my 57 Plymouth.
I did a “Youturn” Power steering conversion on my 57 a couple of years ago that used a Ford truck PS box. It was a fair amount of work. A large part was making some modifications for the clutch linkage as it wasn’t designed for manual shift cars. All in all it was worth it and I’m really pleased with the results. The company is now also making a PS conversion for the 55-56 Dodge and Plymouths and that’s kind of the direction I’m looking at going.
Re: 55-56 Dodge Plymouth Rear Axle width [Re: Mike P] #3021587
03/07/22 06:02 PM
03/07/22 06:02 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Rusty Hope shows a kit for the 56, I have installed one of their kits in my 51 Plymouth,
https://www.rustyhope.com/mopar-disc-brakes
Link to my write up of the install.
https://p15-d24.com/topic/56787-weekend-work/#comments
Re: 55-56 Dodge Plymouth Rear Axle width [Re: Mike P] #3022802
03/11/22 07:54 AM
03/11/22 07:54 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
I put an E-Body 8-3/4 under Kayse's 55 Desoto.
It's about an inch wider than the original rear end but the spring perches lined up perfectly on the leaf springs.
Re: 55-56 Dodge Plymouth Rear Axle width [Re: SNK-EYZ] #3022883
03/11/22 01:15 PM
03/11/22 01:15 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
In '55-'56 the Chrysler and DeSoto are different animals.
