Re: Dealer Techs , ABS light on a 98 ram 2500 [Re: trw1982] #3021028
03/05/22 11:33 AM
03/05/22 11:33 AM
U.S.S.A.
JohnRR Online rolleyes OP
JohnRR  Online Rolleyes OP
U.S.S.A.
Originally Posted by trw1982
if i recall, those codes usually show up when antilock ecu is bad. again if i recall those ecu's are not avail new or from dealer. usually a bone yard and it is a crap shoot getting a good one. might be differeny now but that was how it used to be.
That is my thought , it just flashes the ABS light only, continually as soon as you turn on the ignition. Used is my only source , fingers crossed I can find a good one .
There are many on ebay , the problem is unless I can find one from a truck like the truck i have , dana 70 and 245 65 16 tires , i need to reprogram it .
thanks for everyones help so far.
Re: Dealer Techs , ABS light on a 98 ram 2500 [Re: JohnRR] #3021320
03/06/22 04:24 PM
03/06/22 04:24 PM
Central NY
GarageDodge Offline
GarageDodge  Offline
Central NY
Abs ecu is bad common problem in those trucks.
Re: Dealer Techs , ABS light on a 98 ram 2500 [Re: GarageDodge] #3021386
03/06/22 09:03 PM
03/06/22 09:03 PM
U.S.S.A.
U.S.S.A.
I believe this is the case , I learned more about how the system interacts with the PCM accidently .
Yesterday while trying to trouble shoot it I pulled out the CAB and tried to open it up , which was unsuccessful. I gave up tryingto open it without damaging it and just tossed it on the front seat of the truck and cleaned up to go out to dinner. This morning I went out in the truck and noticed the ABS light was still on , same as if the fuses were pulled , but this time the brake warning light was also on , it's never been on other than during the cluster self check, but I suddenly noticed that the speedo was not reading , what the ?? I did pull the rear end sensor to check for debris or damage but I never unplugged it , once I got to a safe place to stop I reinstalled the CAB unit , the speedo is now working again and the abs light and the brake light are on solid, I did not reconnect the solenoid unit. when I got to where I was going I reconnected the solenoid unit and the brake light went off and the abs light was once again flashing. This is telling me the solenoid is good and the CAB is the problem.
Now to find another cab and hopefully not have to pay a dealer 152 dollars to reset the rear end and tire size codes .
Re: Dealer Techs , ABS light on a 98 ram 2500 [Re: JohnRR] #3021406
03/06/22 10:14 PM
03/06/22 10:14 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
Does the truck have a posi rear?
Re: Dealer Techs , ABS light on a 98 ram 2500 [Re: SALEM1912] #3021470
03/07/22 10:49 AM
03/07/22 10:49 AM
U.S.S.A.
U.S.S.A.
limited slip ... yes
