Drag racing slicks or Drag radials
What are the Limitations of Cast iron 833 ?? 2800lbs abody
I think the case material is arbitrary and simply use aluminim because it's easier to heave around the shop.
Bias ply now, however I have run 275 drag radial without issue on another heavier car.
The bias drive worse but are a bit more forgiving in my experience which is mostly on limited and no prep surfaces.
How much power do you have? How are you making it? I would bet a blower car would break parts before a well tuned/manipulated nitrous deal. Turbo next whjlich is my summer project for my red 66.
The 833 in my GTS was in the 66 @3700 with about 625hp naand a 125->225 shot controlled by a very crude progressive. Those nitrous maps sucked and that kit didnt hold a candle to the modern (leaned out) tune ups.
