Re: What's the right carb for my combo? Street/Strip
[Re: ZIPPY]
#3020137
03/02/22 01:31 AM
03/02/22 01:31 AM
Posts: 10,766 Central Valley, CA.
Quicksilver440
Central Valley, CA.
I'd try a Proform / Brawler "950" race carb w/ 1.45v x 1.75t simply because they're more affordable and more tuneable. Liked that one so much I bought a second one of them for later tunnel ram use. All it needs is the transfer slot holes tapped and restrictors/jets added. Brawler also has a street carb marketed as an 850DP with electric choke, but the primary venturi measures out smaller than standard. Bought a main body of one of those to build up later for my C body. Was surprised to see that. It seems like a sound idea. hopefully get a chance to try it. For an 850, the BG annular booster model I had was so much more responsive than the two regular 4781s that I had, it killed them both so I sold them. Zippy…super interested in a electric choke carb with smaller venturis…seems like a great idea. I’ll check that out! I must apologize, I didn't remember the brand correctly. Your reply made me go check. I thought it was a QFT Brawler, but it is actually a QFT Proform. Pics below. I'm coming up with 1.465(P) and 1.554(S) using basic dividers and a dial caliper. Proform doesn't advertise the spec (that I have been able to easily find,anyway), whereas Brawler advertises 1.570 P/S. If the Brawler marketing is correct then the carbs are definitely not the same in spite of how badly I might mix them up. https://www.holley.com/products/fuel_systems/carburetors/street/parts/BR-67214https://www.proformparts.com/produc...odel-850-cfm-mechanical-secondaries-typeVery helpful zippy…definitely don’t want the larger Venturi! Thanks for double checking!
[Re: Quicksilver440]
#3020159
03/02/22 08:46 AM
03/02/22 08:46 AM
Posts: 3,916 usa
lewtot184
usa
a lot of good single carb info here, but i have to wonder if the manifold is best for the combo? it could be fine and i know it's had some good press but what "IF"? i don't care for single carb stuff much anymore, especially when cost is factored in. i'd open the door to a lot of options. the worst that looking could do is send you back to what you have. Manifold is a Holley Street Dominator…ran really well with the 800 DP I used to have. I also have a new Victor that I’ve never ran…but I bought it to run with Fuel injection that I never ended up finishing. i was just wondering if the manifold would complement the ported heads or hinder them. if the heads are 300+cfm and the manifold is 280-290cfm would spending a bunch of money on a carb make a noticeable difference? just asking. would the victor manifold, which can make more power, and a better carb add growth plus performance? i think maybe i'd try the victor first and spend money on a carb second. as far as losing some performance goes a lot of factors play in. driver, weather, track, old tires, fuel delivery degradation, maybe a combo of all? i think i'd try to look at a broader picture.
[Re: lewtot184]
#3020178
03/02/22 10:37 AM
03/02/22 10:37 AM
Posts: 4,852 Wichita
GY3
Wichita
a lot of good single carb info here, but i have to wonder if the manifold is best for the combo? it could be fine and i know it's had some good press but what "IF"? i don't care for single carb stuff much anymore, especially when cost is factored in. i'd open the door to a lot of options. the worst that looking could do is send you back to what you have. Manifold is a Holley Street Dominator…ran really well with the 800 DP I used to have. I also have a new Victor that I’ve never ran…but I bought it to run with Fuel injection that I never ended up finishing. i was just wondering if the manifold would complement the ported heads or hinder them. if the heads are 300+cfm and the manifold is 280-290cfm would spending a bunch of money on a carb make a noticeable difference? just asking. would the victor manifold, which can make more power, and a better carb add growth plus performance? i think maybe i'd try the victor first and spend money on a carb second. as far as losing some performance goes a lot of factors play in. driver, weather, track, old tires, fuel delivery degradation, maybe a combo of all? i think i'd try to look at a broader picture. We run ported 300-ish cfm heads and also run a Holley Street Dominator. Streetwize (Bobby) here on the board ported this SD and compared to an as-cast, it picked up a tenth on the dragstrip. Translated to about 12 hp as I recall. We also run an 850 Demon for a carb. For a heavy street car it runs pretty well and has great drivability.
'63 Dodge 330
11.19 @ 121 mph Pump gas, n/a, through the mufflers on street tires with 3.54's. 3,600 lbs.
9.92 @ 135mph with a 350 shot of nitrous and 93 octane pump. 1.43 60 ft. 3,750 lbs.
[Re: GY3]
#3020380
03/03/22 12:05 AM
03/03/22 12:05 AM
Quicksilver440
Central Valley, CA.
a lot of good single carb info here, but i have to wonder if the manifold is best for the combo? it could be fine and i know it's had some good press but what "IF"? i don't care for single carb stuff much anymore, especially when cost is factored in. i'd open the door to a lot of options. the worst that looking could do is send you back to what you have. Manifold is a Holley Street Dominator…ran really well with the 800 DP I used to have. I also have a new Victor that I’ve never ran…but I bought it to run with Fuel injection that I never ended up finishing. i was just wondering if the manifold would complement the ported heads or hinder them. if the heads are 300+cfm and the manifold is 280-290cfm would spending a bunch of money on a carb make a noticeable difference? just asking. would the victor manifold, which can make more power, and a better carb add growth plus performance? i think maybe i'd try the victor first and spend money on a carb second. as far as losing some performance goes a lot of factors play in. driver, weather, track, old tires, fuel delivery degradation, maybe a combo of all? i think i'd try to look at a broader picture. We run ported 300-ish cfm heads and also run a Holley Street Dominator. Streetwize (Bobby) here on the board ported this SD and compared to an as-cast, it picked up a tenth on the dragstrip. Translated to about 12 hp as I recall. We also run an 850 Demon for a carb. For a heavy street car it runs pretty well and has great drivability. Nice! Might just be my 850 is crap.
[Re: ZIPPY]
#3020968
03/05/22 12:20 AM
03/05/22 12:20 AM
Quicksilver440
Central Valley, CA.
I'd try a Proform / Brawler "950" race carb w/ 1.45v x 1.75t simply because they're more affordable and more tuneable. Liked that one so much I bought a second one of them for later tunnel ram use. All it needs is the transfer slot holes tapped and restrictors/jets added. Brawler also has a street carb marketed as an 850DP with electric choke, but the primary venturi measures out smaller than standard. Bought a main body of one of those to build up later for my C body. Was surprised to see that. It seems like a sound idea. hopefully get a chance to try it. For an 850, the BG annular booster model I had was so much more responsive than the two regular 4781s that I had, it killed them both so I sold them. Zippy…super interested in a electric choke carb with smaller venturis…seems like a great idea. I’ll check that out! I must apologize, I didn't remember the brand correctly. Your reply made me go check. I thought it was a QFT Brawler, but it is actually a QFT Proform. Pics below. I'm coming up with 1.465(P) and 1.554(S) using basic dividers and a dial caliper. Proform doesn't advertise the spec (that I have been able to easily find,anyway), whereas Brawler advertises 1.570 P/S. If the Brawler marketing is correct then the carbs are definitely not the same in spite of how badly I might mix them up. https://www.holley.com/products/fuel_systems/carburetors/street/parts/BR-67214https://www.proformparts.com/produc...odel-850-cfm-mechanical-secondaries-type Zippy..you got me thinking and researching those proforms…especially the mainbody you listed. Found this awesome chart that includes venturi sizes of various carbs…thought I would share. https://www.quickfueltechnology.com.au/content/Quick%20Fuel%20Carb%20Size%20with%20details-AUST.pdf
#3021052
03/05/22 02:00 PM
03/05/22 02:00 PM
Posts: 43,915 Bend,OR USA
Cab_Burge
[quote=Quicksilver440][quote=lewtot184]a lot of good single carb info here, but i have to wonder if the manifold is best for the combo? it could be fine and i know it's had some good press but what "IF"? i don't care for single carb stuff much anymore, especially when cost is factored in. i'd open the door to a lot of options. the worst that looking could do is send you back to what you have. We run ported 300-ish cfm heads and also run a Holley Street Dominator. Streetwize (Bobby) here on the board ported this SD and compared to an as-cast, it picked up a tenth on the dragstrip. Translated to about 12 hp as I recall. We also run an 850 Demon for a carb. For a heavy street car it runs pretty well and has great drivability. Nice! Might just be my 850 is crap. All of them can be fixed by you or someone else
[Re: Cab_Burge]
#3021102
03/05/22 05:59 PM
03/05/22 05:59 PM
Quicksilver440
Central Valley, CA.
[quote=Quicksilver440][quote=lewtot184]a lot of good single carb info here, but i have to wonder if the manifold is best for the combo? it could be fine and i know it's had some good press but what "IF"? i don't care for single carb stuff much anymore, especially when cost is factored in. i'd open the door to a lot of options. the worst that looking could do is send you back to what you have. We run ported 300-ish cfm heads and also run a Holley Street Dominator. Streetwize (Bobby) here on the board ported this SD and compared to an as-cast, it picked up a tenth on the dragstrip. Translated to about 12 hp as I recall. We also run an 850 Demon for a carb. For a heavy street car it runs pretty well and has great drivability. Nice! Might just be my 850 is crap. All of them can be fixed by you or someone else Cab…very true. Might spend some more time soaking this one and running all the passages. Something has to be clogged.
