The old car would vary close to 1/2 second and 4-5 MPH between spring / fall conditions and peak summer heat & humidity. I expect the 1320 to behave accordingly after what I've seen from a 1200+ difference in DA between the two test sessions.
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
