Re: Nitrous Express Mainline System
[Re: lancer493]
#3020500
03/03/22 01:49 PM
03/03/22 01:49 PM
Posts: 4,689 Wichita
GY3
Wichita
I did the Mainline kit but it was for the 4150 carb. I wanted the basics and that's what this kit provides. We've used all the jetting from 100 to 250 and it's dead on! Very happy with it.
I would recommend something like the Leash electronics single stage board to compliment it. It makes wiring super easy and comes with relays, etc. Very reasonably priced as well.
[Re: lancer493]
#3020581
03/03/22 07:27 PM
03/03/22 07:27 PM
GY3
Wichita
GY3, thank you sir, I am glad to hear this. Frills cost money,. Sure sounds like this system is just what I am looking for. Anything more and I may just drive thru the convertor. Thank you again! Bill A couple of extras you might want to add. We have a bottle heater powered by a DeWalt battery in the trunk. Mainly to just maintain pressure and not draw on the main battery. Personally, I like using an infrared temp gun to monitor the bottle temp as I find it a little easier and more accurate than a gauge. Coldfusion makes a budget bottle heater with a pressure switch that is adjustable. You can really go down a rabbit hole buying accessories for nitrous.
[Re: GY3]
#3020603
03/03/22 09:16 PM
03/03/22 09:16 PM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
If you are a Milwaukee M18 type of fellow PM me. We sell a base and everything you need for an automatic bottle heater. The transducer we use holds pressure within 25-50 psi.
For the controller I suggest the NOS mini progressive because it has a window switch, delay, and can monitor you bottle pressure through the handheld for about $200 extra. The NOS mini progressive is just over $200.
[Re: Jeremiah]
#3020630
03/03/22 10:30 PM
03/03/22 10:30 PM
GY3
Wichita
For the controller I suggest the NOS mini progressive because it has a window switch, delay, and can monitor you bottle pressure through the handheld for about $200 extra. The NOS mini progressive is just over $200. I should probably get a controller at some point rather than just hitting all of it off the line.
[Re: GY3]
#3020635
03/03/22 10:41 PM
03/03/22 10:41 PM
Jeremiah
Rogue River, OR
I'd like leave on a 200 and ramp it to 300 eventually. Need mo tire and a Dana!
The window switch and bottle pressure read out seal the deal for me. It's a must have IMO.
What you need is a 4 speed!
Do you apray it off the line on an unprepped surface?
[Re: Jeremiah]
#3020654
03/04/22 12:57 AM
03/04/22 12:57 AM
GY3
Wichita
Do you apray it off the line on an unprepped surface? I don't race any unprepped or "street" events anymore (a '63 Dodge isn't as plentiful and expendable as a Fox body) and rarely use nitrous on the street now with it on the 250 shot tune-up. We did do a hard tire race last year and I reduced the shot to 150 as I recall. Got out a little ways, got over eager and hit the button. Tires erupted and it was a pedal fest. Almost caught him at the line but lost by a bunper. LOL. The hard tire is like driving on ice with the torque this thing makes naturally aspirated. I did some changes over the winter to get some more power n/a, but also eyeing a plate and solenoid change...
[Re: GY3]
#3020660
03/04/22 01:31 AM
03/04/22 01:31 AM
GY3
Wichita
As for index racing, we tried the 6.50 index a couple of years back after a friend talked us into it. With a 200 shot the car ran a 6.52 earlier in the night. Figured close enough. This was before the bottle heater so I figured any temp change would be offset by bottle temp/pressure dropping a little. I left late and ran a 6.489. Ugh! Fastest the car had ever been with a 1.37 60 ft. footbraking, LOL! Lots of fun and learned a lot that night about what the car wanted. We're the first pair in the video. https://youtu.be/vbXjkCLaNz8
[Re: Cab_Burge]
#3020682
03/04/22 08:10 AM
03/04/22 08:10 AM
GY3
Wichita
Nothing like being dead late You can do better Yep, had a sandwich and a nap before I left.
[Re: lancer493]
#3020745
03/04/22 11:33 AM
03/04/22 11:33 AM
Jeremiah
Rogue River, OR
I find it humorous that 200+ hp nitrous shot is considered conservative.
The jug is rowdy lol. Looking forward to seei g you meet your goals mr Bill!
Keep us in the loop with any updates.
