Burnt crankshaft #3019617
02/28/22 10:08 AM
02/28/22 10:08 AM
an8sec70cuda Offline OP
I have 2 crankshafts that were stored in a building that burned to the ground. Both had been machined and were ready to use.
Obviously they need cleaning, machined again, etc.
My question is are they useable if they can be turned again (not bent)? I'm no metallurgist, but would the heat from the fire have caused any irreparable damage?
They are a forged 440 crank and an old crank from a mid/late '50s Chevy 283.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Burnt crankshaft [Re: an8sec70cuda] #3019624
02/28/22 10:32 AM
02/28/22 10:32 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Meh, that'll buff-out. Honestly though, hard to know what kind of temperature conditions they were subject to including possible rapid thermal shock from a extinguisher. That said, if it checks out at the crank shop....good to go! I'd tap it and see if they 'ring' before delivering for machining FWIW.
Re: Burnt crankshaft [Re: HardcoreB] #3019643
02/28/22 11:32 AM
02/28/22 11:32 AM
I don't know how hot it got, but there was nothing left of that building but metal and concrete. Anything aluminum was reduced to a puddle on the floor.
Guess I'll clean them up and see how they look. up
CHIP
Re: Burnt crankshaft [Re: an8sec70cuda] #3019650
02/28/22 11:54 AM
02/28/22 11:54 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Probably junk.
They can be thermally normalized , and re-treated for temper.
Then re-machined.
By the time you spend that money , you are pretty close to a decent new piece.
Re: Burnt crankshaft [Re: tubtar] #3019677
02/28/22 12:49 PM
02/28/22 12:49 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Toss them in the scrap bin...
69 GTX 68 Road Runner
Re: Burnt crankshaft [Re: JERICOGTX] #3019683
02/28/22 01:12 PM
02/28/22 01:12 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I bet there warped.
Re: Burnt crankshaft [Re: FastmOp] #3019686
02/28/22 01:17 PM
02/28/22 01:17 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Probably no good anymore. Sorry man.
Rich H.
Esse Quam Videri
Re: Burnt crankshaft [Re: ZIPPY] #3019699
02/28/22 01:44 PM
02/28/22 01:44 PM
Thanks yall, I'll scrap them along w/ everything else. Fires suck.
Luckily this was the worst damage to a car...
CHIP
Re: Burnt crankshaft [Re: an8sec70cuda] #3019700
02/28/22 01:45 PM
02/28/22 01:45 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
way too close for comfort....................someone up there digs MoPars too.
Re: Burnt crankshaft [Re: an8sec70cuda] #3019701
02/28/22 01:46 PM
02/28/22 01:46 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Is that your car?
Re: Burnt crankshaft [Re: JERICOGTX] #3019702
02/28/22 01:48 PM
02/28/22 01:48 PM
Is that your car?
Yes. This is the first car my Dad and I fixed up. I put the old Indy headed motor that used to be in my cuda into it. Just never completely finished it to race, but it does run and drive.
CHIP
Re: Burnt crankshaft [Re: an8sec70cuda] #3019704
02/28/22 01:50 PM
02/28/22 01:50 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
Those cranks are way to easy and cheap to come by to take a chance. Just my two cents.
Re: Burnt crankshaft [Re: an8sec70cuda] #3019723
02/28/22 02:47 PM
02/28/22 02:47 PM
Is there a shop nearby that can test them for hardness?
If so I would have them check before tossing them twocents wrench
Re: Burnt crankshaft [Re: an8sec70cuda] #3019730
02/28/22 03:02 PM
02/28/22 03:02 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Is that your car?
That hurts. I'm so sorry that happened.
Rich H.
Esse Quam Videri
Re: Burnt crankshaft [Re: ZIPPY] #3019736
02/28/22 03:10 PM
02/28/22 03:10 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Is that your car?
Darn right that hurts. Chip i HOPE that is the only car damage you received? Demon, and Cuda good?
Re: Burnt crankshaft [Re: JERICOGTX] #3019762
02/28/22 04:52 PM
02/28/22 04:52 PM
Thanks yall. It could have been a LOT worse. My dad's house wasn't damaged at all. His '69 road runner (the 4 speed 6 pack car) was parked at his house, so it is fine.
The cuda and the Demon were in the shop and they are perfectly fine...as is the shop. The fire burned around it...somehow.
We had 3 trailers all parked side by side, right beside the shop. My enclosed car trailer only had one tire damaged by fire, my open car trailer burned completely (all 4 tires burned to the rim, leaf springs flattened, deck plates buckled, etc.), and my dads smaller utility trailer suffered the same fate.
The '73 new yorker and the "old" '69 road runner were parked at the barn. The taillights will need replaced on both cars and the paint blistered on the road runner, but that's it.
Lawnmowers, three Honda 300 fourtrax 4 wheelers, and a bunch of car stuff got burnt up in the barn. Game room is a complete loss...pool table, weight set/workout equipment, more car stuff, etc.
My old Ford tractor and Case backhoe are fine. One front tire burnt up on the backhoe.
Luckily a family friend saw it and called me at work. I had that big Duramax running down the highway that afternoon! I work about 25 miles from home and I'm not sure how I didn't get a speeding ticket. I saw the smoke from about 8 miles away and my heart sank. You can't imagine the relief I felt when I saw the shop was ok.
CHIP
Re: Burnt crankshaft [Re: an8sec70cuda] #3019771
02/28/22 05:29 PM
02/28/22 05:29 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
[quote=an8sec70cuda]Thanks yall, I'll scrap them along w/ everything else. Fires suck.
Is that your car?
Yes. This is the first car my Dad and I fixed up. I put the old Indy headed motor that used to be in my cuda into it. Just never completely finished it to race, but it does run and drive. [/quote
Tell the insurance company they were both Windbergs
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Burnt crankshaft [Re: B3422W5] #3019804
02/28/22 07:55 PM
02/28/22 07:55 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
What started the fire?. Sorry there was stuff lost. Glad there was stuff that survived.
Doug
Re: Burnt crankshaft [Re: dvw] #3019834
02/28/22 09:52 PM
02/28/22 09:52 PM
Illinois
gearhead01 Offline
gearhead01  Offline
Illinois
It does not take a lot of heat to warp a crank. I spun a rod bearing (#3) on my 440, which is close to the center main/thrust cap. Crank is discolored at this journal area.
In disassembling, there was a tight spot when rotating the crank. I pulled the center main cap, and the thrust bearing inserts. Tight spot when away.
I left the front and rear caps on, and put an indicator on the center crank journal. I had 0.010 run-out on the center journal.
I have not had it checked out yet, but my thought is it will probably take as much to fix it, than buy a new crank.
John
1971 Satellite Sebring Plus - 14.46 @ 95.43
1977 Road Runner - N/B 11.02@ 119 Drag Radials
Re: Burnt crankshaft [Re: B3422W5] #3019895
03/01/22 09:35 AM
03/01/22 09:35 AM
B3422W5...LOL, it's a shame my "spare" aluminum block was right beside these cranks and melted! laugh
DVW...possibly from a battery tender that was on a lawnmower.
Gearhead...you're probably right. Cost prohibitive.
CHIP
