Page 3 of 9 1 2 3 4 5 6 7 8 9
Re: 269/275 solid roller install [Re: mopar dave] #3018968
02/25/22 11:18 PM
02/25/22 11:18 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Doesn't look like i get enough clearance with this cam unless i install it at 108, straight up. Not gonna do that. I put the cam in at 106 and still cant get enough on the exhaust to be safe. .064" just is not enough and i found a new issue, a bent exhaust valve. It doesn't take much to bend these. So, now the head needs to come off to get that fixed and a new cam will need to be ordered or i take the opportunity to upgrade to 440-1 heads.
Re: 269/275 solid roller install [Re: mopar dave] #3018981
02/26/22 12:05 AM
02/26/22 12:05 AM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
May have missed it but why not cut the pistons for clearance? What is target/current compression ratio?
Re: 269/275 solid roller install [Re: INTMD8] #3018985
02/26/22 12:42 AM
02/26/22 12:42 AM
Mt Morris Michigan
Mt Morris Michigan
Not interested in cutting the notches. Its currently 12.5:1, would like to keep it around 12.
Re: 269/275 solid roller install [Re: mopar dave] #3018987
02/26/22 12:47 AM
02/26/22 12:47 AM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
Ok, good luck up
Re: 269/275 solid roller install [Re: mopar dave] #3019000
02/26/22 04:41 AM
02/26/22 04:41 AM
Isky offers a piston notching kit that you can use with the pistons in the block at TDC to remove as little or as much you want to.
I bought the guides and cutters years ago for 3/8, 11/32 and 5/16 guides and two sies of intake and exhaust valve size cutters, work great up wrench.
I tape off the top of the pistons to the block and ran a vacuum cleaner hose to the port I wasn't using to suck most of the cuttings out as soon as the cutter cut them, work great with no real problems afterwards up work scope
I'm not sure how much a 2.20 cutter removing .045 from the piston top makes measures in CC but I bet it isn't much work scope
Re: 269/275 solid roller install [Re: Cab_Burge] #3019016
02/26/22 09:52 AM
02/26/22 09:52 AM
Mt Morris Michigan
Mt Morris Michigan
Cab, im using the ICON pistons with a 12cc dish. I don't think they are the best quality piston to do that with, not sure. That sounds like too much trouble for me, but thanks for that idea guys. Cab, didn't you have a set on these same E max wedge victor heads that never performed to your liking? I'm really contemplating new heads. Might fix all my woes with these heads. Will see.
Re: 269/275 solid roller install [Re: mopar dave] #3019031
02/26/22 10:26 AM
02/26/22 10:26 AM
Washington
madscientist Offline
Washington
How much piston to head clearance do you have? Whatever that is, is all you need for P/V. I’ve run as close as .040 but I run a gear drive. Your .064 on the intake wouldn’t bother me in the least.
Re: 269/275 solid roller install [Re: madscientist] #3019044
02/26/22 11:01 AM
02/26/22 11:01 AM
St.Pete,Florida
lancer493 Offline
lancer493  Offline
St.Pete,Florida
Dave, what is the intended usage of your vehicle? I've looked at both of your threads and can't seem to find that info. Don't want to respond to your posts without that info. Also , about what was the hp gain you were looking to achieve? It's hard to visualize the big picture without that knowledge. I have a B3 geometry correction kit that further plays w/effective rocker arm ratio and actual valve lift. Bill
Re: 269/275 solid roller install [Re: madscientist] #3019046
02/26/22 11:04 AM
02/26/22 11:04 AM
Mt Morris Michigan
Mt Morris Michigan
With the cam in at 106, I have .044 on intake and .064 on exhaust with my last measures.
Re: 269/275 solid roller install [Re: lancer493] #3019048
02/26/22 11:13 AM
02/26/22 11:13 AM
Mt Morris Michigan
Mt Morris Michigan
Street/Strip. Looking at my Moroso slide rule, it shows my hp at 650hp(3500#@134mph) , that is with a single dominator. A 511 with 12.5:1 should be making 700+ hp, so it looks mine is lacking somewhere. Too many people have reported disappointment in these E victor max wedge heads. I want to make as much power as possible and drive on the street as well. No power anything in the car, its a weekend toy with a full interior and cage. Thanks
Re: 269/275 solid roller install [Re: mopar dave] #3019055
02/26/22 11:46 AM
02/26/22 11:46 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
What is the intake lobe lift at TDC?
Re: 269/275 solid roller install [Re: mopar dave] #3019057
02/26/22 11:48 AM
02/26/22 11:48 AM
So. Burlington, Vt.
So. Burlington, Vt.
Will your headers work with the exhaust port location of a 440-1?
Re: 269/275 solid roller install [Re: mopar dave] #3019058
02/26/22 11:56 AM
02/26/22 11:56 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
With most of your time being in mid range rpm I think a smaller port than MW would be better and maybe avg tq output.Have you looked at a wider LSA in an engine program to see if that would be something to consider?
Re: 269/275 solid roller install [Re: fast68plymouth] #3019071
02/26/22 01:07 PM
02/26/22 01:07 PM
Mt Morris Michigan
Mt Morris Michigan
Im not sure what your asking Dwayne, but the lobe lift on cam is .430". I need to talk to you about that. How much different is the exhaust port on a -1 head vs my head? I believe my victor are raised .250 from stock port location.
Re: 269/275 solid roller install [Re: Clanton] #3019073
02/26/22 01:10 PM
02/26/22 01:10 PM
Mt Morris Michigan
Mt Morris Michigan
Yes, that has been my thought too. Pipemax calls for a 112-113 lobe sep. Figure most time going down track my rpm is between 6200 and 6800. I only loose 600 rpm on each shift. I have 5400 stall or maybe flash is a better term.
Re: 269/275 solid roller install [Re: mopar dave] #3019074
02/26/22 01:18 PM
02/26/22 01:18 PM
So. Burlington, Vt.
So. Burlington, Vt.
Lobe lift at TDC.
Zero indicator on base circle, bring piston to TDC during overlap period, read what the intake lobe lift is at that point.
It makes no sense that the new cam would have vastly different lobe lift(which translates to V/P clearance) during the overlap period.
The intake lobe lift at TDC, with the cams installed at the same centerline, should be within .020.
.020” lobe lift difference, x 1.65 RR = .033” difference at the valve.
If the old V/P clearance measured .118”, the new clearance should be about .085”.
The old cams intake lobe lift at TDC, installed at 106, should be .141”.
The new cam should be .155”-.160”.
440-1 exhaust ports are raised about .750”
Re: 269/275 solid roller install [Re: mopar dave] #3019084
02/26/22 02:40 PM
02/26/22 02:40 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
intake port choke calc I was checking my build and rpm of the head flow the other day and with a std port sq in of 2.7 446" 7krpm my choke on my port size was more like 2.85 sq in. for 7k rpm.I am sure I am not figuring in everything that is needed but maybe it will help
Re: 269/275 solid roller install [Re: mopar dave] #3019127
02/26/22 04:36 PM
02/26/22 04:36 PM
Apollo, PA.
B1MAXX Online content
B1MAXX  Online Content
Apollo, PA.
If you put the real springs in there and measure with clay you'll find it will add typically .030 to those numbers. I typically do it both ways every time ( unless with the checking springs I already have a ton) and that's what I have found.
The lash used was .018?
Re: 269/275 solid roller install [Re: mopar dave] #3019136
02/26/22 04:52 PM
02/26/22 04:52 PM
I did use a set of the Eddy Victor M.W. heads that had been ported all the way to the valve seats, I did have issues using them with pushrod clearances with the Hughes 1.6 ratio extrude aluminum rocker arms that came with those heads when I bought them from a member on here. I switch to a set of Harland Sharp 1.6 ratio with more offset on the intake rockers and that help a bunch along with some more grinding the heads for more pushrod clearances wrench up
On your deal with .064 exhaust to piston clearances and the little less intake clearances I would hesitate to go racing with that motor up hammer twocents
Re: 269/275 solid roller install [Re: Cab_Burge] #3019150
02/26/22 05:35 PM
02/26/22 05:35 PM
St.Pete,Florida
lancer493 Offline
lancer493  Offline
St.Pete,Florida
I agree with B1 MAX. You really should do a careful clay check with 1 cylinder outfitted with the actual valve springs and valve gear being used or considered. The system of checking with a dial indicater only checks the depths of the valve pockets. It doesn't check the valve margin's radial clearance in the valve pocket unless it is the first point of contact when checking the depth. You could have only .002" radial clearance and never know it til you fire it up and that ain't gonna be good. When I had the pistons made by Diamond I told them they were for Victor heads, they said it mattered as they were somewhat different than others. I ended up with plenty of clearance there when I assembled. Careful clay measuring is quite accurate contrary to what some believe.It is the only way I know of to see actual verifiable minimum radial clearance. I'm sure that statement will draw a lot of fire, but I'm speaking of a proceedure we could all do in our driveway or garage and feel safe with our findings. Bill
